6 Replies Latest reply on Apr 26, 2006 2:37 PM by Newsgroup_User
    PHP Increase Font
    Level 7
      Okay -
      I recieved a reply from Osgood yesterday and he referenced an article that
      taught a quick, short and clean method of using PHP as a 'style switcher.' I
      tested out the code, and it works great - however, it switches style sheets
      and rather doesn't just increase the font-size by a certain amount of
      pixels, which I've seen a great article using JavaScript do.
      Does anyone know if there is a solution to using PHP to increase the
      font-size up and up (until a *max* point) and also down and down (until a
      *min* point)?
      Again - I've seen JavaScript with the capabilities of this, but I want to
      use a server-side approach with PHP. Here is the article that accomplishes
      what I want in JavaScript:
      http://www.dyn-web.com/dhtml/sizefont/sizerdx.php .
      Shane H
      shane@NOSPAMavenuedesigners.com
      http://www.avenuedesigners.com
        • 1. Re: PHP Increase Font
          Level 7
          Hi Shane,
          I do it... just not with a max/min.
          > *min* point)?
          kim
          http://geekministry.com
          • 2. Re: PHP Increase Font
            Level 7
            Kim -
            Do you have a script that you'd be able to share? And if not - do you have a
            reference that has one?
            Shane H
            "Kim" <not@this.com> wrote in message
            news:e2o68e$smv$1@forums.macromedia.com...
            > Hi Shane,
            >> *min* point)?
            > kim
            • 3. Re: PHP Increase Font
              Level 7
              My rudimentary knowledge of PHP would do it this way. I'm sure there is a
              better way.
              The link to increase or decrease the font size is in a form that submits to
              the same page, e.g.,
              <form action="<?php $_SERVER['PHP_SELF'] ?>"....
              The field being submitted has a name like 'fontsize'.
              Above the head of the page is a test to block further PHP unless the form
              has been submitted, e.g.,
              <?php
              $multiplier=1; // initialize the value
              if (array_key_exists('submit',$_POST)) {
              $multiplier=($_POST['fontsize']=='Larger'?1.5:0.75);
              // this sets $multiplier to either 1.5 or .75 depending on whether the user
              has selected larger or smaller from a list/menu
              Then just above </head>, you have -
              <style type="text/css">
              html,body { font-size:<?php echo($multiplier * 100); ?>%; }
              </style>
              Sorta like this -
              <?php
              <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
              " http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
              <html xmlns=" http://www.w3.org/1999/xhtml">
              <head>
              <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
              <title>Untitled Document</title>
              </style>
              </head>
              <body>
              <p>Testing Testing</p>
              <form id="form1" name="form1" method="post" action="<?php
              $_SERVER['PHP_SELF'] ?>">
              <label for="fontsize">Font Size</label>
              <select name="fontsize" id="select">
              <option>Choose Size</option>
              <option>Larger</option>
              <option>Smaller</option>
              </select>
              <input type="submit" name="submit" id="submit" value="Submit" />
              </form>
              <p> </p>
              </body>
              </html>
              Murray --- ICQ 71997575
              Adobe Community Expert
              (If you *MUST* email me, don't LAUGH when you do so!)
              http://www.dreamweavermx-templates.com - Template Triage!
              http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
              http://www.dwfaq.com - DW FAQs, Tutorials & Resources
              http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
              "Shane H" <shane@NOSPAMavenuedesigners.com> wrote in message
              news:e2o953$395$1@forums.macromedia.com...
              > Kim -
              > a reference that has one?
              > Shane H
              >> Hi Shane,
              >>> a *min* point)?
              >> kim
              • 4. Re: PHP Increase Font
                Level 7
                On reflection, you could simply do something like this -
                echo(isset($_POST['fontsize'])?$_POST['fontsize']:100); ?>%; }
                and make your select like this -
                <option value="150">Larger</option>
                <option value="75">Smaller</option>
                </select>
                No need for any of the rest of the PHP stuff.
                "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
                news:e2oahs$534$1@forums.macromedia.com...
                > better way.
                > to the same page, e.g.,
                • 5. Re: PHP Increase Font
                  Level 7
                  Thanks Murray - I would like to do this will <a> links, so the user can
                  click an image and it will increase.
                  Shane H
                  news:e2ocqu$84f$1@forums.macromedia.com...
                  > </select>
                  >> a better way.
                  >> form has been submitted, e.g.,
                  • 6. Re: PHP Increase Font
                    Level 7
                    echo(isset($_GET['fontsize'])?$_GET['fontsize']:100); ?>%; }
                    <a href="pagename.php?fontsize=150"><img alt="larger" src="larger.gif"></a>
                    <a href="pagename.php?fontsize=75"><img alt="smaller" src="smaller.gif"></a>
                    news:e2ojia$gp5$1@forums.macromedia.com...
                    > Shane H
                    >> </select>
                    >>> a better way.
