1 Reply Latest reply on Jan 27, 2016 10:34 AM by Rick Gerard
    Trying to make 3D glass text shatter
    noemib21308544
      I am trying to make 3D glass text shatter in After Effects. I created 3D glass text following this tutorial Sexiest 3D Glass Intro Ever (Template Included) | After Effects Tutorial - YouTube
      This tutorial creates the text in Ray Traced 3D.
      Now I am trying to animate it shattering. When add the Shatter effect to the text, it doesn't do anything.
      Can anyone suggest how I may be able to do this, or point me in the direction of a youtube tutorial.
        • 1. Re: Trying to make 3D glass text shatter
          Create a new comp using the standard not the 3-D Ray-traced rendering engine.
          Drag your 3-D glass text comp into the new comp and apply shatter.
          Do not expect the 3-D text to break up like it would if you actually shattered a 3-D object. If you want to do that you will have to use a 3-D app. You should be able to do it with Cinema 4D Lite  which is included with the latest versions of AE.
          One other note, you should have received a warning when you enabled Ray-traced rendering that effects and blend modes would not work. You need to pay attention to those warnings and work around the problems they predict.
