4 Replies Latest reply on Feb 1, 2016 7:19 AM by gkaiseril
    Javascript to calculate the average
    gayathriv26674322
      Hi Experts,
      I have a requirement as follows.The below sheet shows the value from 1.a to 9.a
      When I select High in 1.a then the value should be 1.4 and when selecting 2.a as medium then it should multiply the value of SD 2 (15* 1.a weight), similarly for other questions too.
      1.a
      Reason1
      High
      NA
      NA
      High - Weight = 1.4
      Medium - Weight = 1.2
      Low - Weight = 1
      2.a
      Reason2
      Major
      100
      100
      Major (100) - System will be unavailable for 1 or more business days during operating hours
      Medium  (15*1.a Weight) -  System will be unavailable or experience intermittent availability for 4 hours or more during operating periods
      Minor (5*1.a Weight) - System will be unavailable or experience intermittent availability between 1 - 4 hours during operating periods
      No impact (0) - No Impact or System will be unavailable or experience intermittent availability for less than 0.5 hours during operating periods or outside operating periods
      Note: Response score is calculated using the formula Response Score * Weight of SD1 Question
      3.a
      Reason3
      SBU
      15
      20
      Enterprise (20) - Weight = 1.4;  More than 50% of population is affected, 2 or more SBU's are affected, 2 or more locations
      SBU (15) - Weight = 1.2; 1 SBU is affected, 5 or more departments, More than 25% of the population
      Department (10) - Weight = 1.1; Less than 5 Departments
      Users (0) – Weight = 1; Not applicable or  Less than 10 Users
      4.a
      Reason4
      Several Features
      6
      21
      Extensive (15 * 3.a Weight) - Changes on the user interface including change in screen flow/major functionalities. Training required.
      Several Features (5 * 3.a Weight) - No user interface changes but new functionalities may be introduced. Training required.
      Look & Feel (2 * 3.a Weight) - Cosmetic changes but the same actions/screen flow. Training not applicable.
      Minor (0) - Change not visible to the end users. Training is not applicable.
      Note: Response score is calculated using the formula Response Score * Weight of 3.a Question
      5.a
      Reason5
      Yes Major
      21
      21
      Yes Major (15 * 1.a Weight) - Degradation >= 20%
      Yes Minor (5 * 1.a Weight) - Degradation < 20%
      No (0) - No Degradation
      6.a
      Reason6
      Yes Minor
      2
      5
      Yes Major (5) - Multiple documents
      Yes Minor (2) - One document
      No (0) - No updates required
      7.a
      reason7
      No
      0
      12
      Yes Major (15) - Multiple HP Applications
      Yes Minor (5) - One HP Application
      8.a
      Reason8
      Yes
      0
      100
      Yes (0) - Low
      No (100) - High
      9.a
      Reason 9
      No
      0
      100
      Yes (100) - High
      No (0) - Low
      Based on this questions the impact should be calculated. If the score of above questions are then the Risk field should be High if value is between 80-100 .
      Change Category
      Major
      Scoring Reference
      Impact
      Range
      High
      80-100++
      Medium
      50-79
      Low
      0-49
      IT Area
      Max Rating
      Total Rating
      Impact Rating
      Team 1
      379
      144
      High
      A New field to be created which captures the risk value.
        • 1. Re: Javascript to calculate the average
          Do you have a specific question, or do you expect us to write your entire script for you?
          • 2. Re: Javascript to calculate the average
            You need to create a custom calculation to sum the values and count the number of items to be used in the calculation, not all "averages" use the total number of entries, and divide the sum by the number items used or needed for computing the average as long as that number is not zero
            There a number of JavaScript sites that provide user written functions for calculating various statistics.
            • 3. Re: Javascript to calculate the average
              gayathriv26674322 Level 1
              Hi
              I need the logic of the script.
              • 4. Re: Javascript to calculate the average
                You place the value of the fields to be used in the average into an array. Next filter out unwanted data element if needed, like empty elements. Now sum the elements of the array. Divide the sum of the elements in the array by the number of items in the array and assign the result to the field for the result;
                A function like will compute the average of the values in an array of values.
                function average(data){
                   // computes the average of the values within an array;
                   var sum = data.reduce(function(sum, value){
                     return sum + value;
                   }, 0);
                   var avg = sum / data.length;
                   return avg;
                   } // end function average;
                The above is the JavaScript syntax for the computation. I assume you understand how to get field values and add the values to an arraty. If needed you can use the array filter method or prototype to remove unwanted data elements.
