2 Replies Latest reply on Jan 28, 2016 5:48 AM by A.T. Romano
    Mémoire système allouée insuffisante. Erreur Transcodage lors export vers DVD
    ajc3
      Bonjour,
      Procédant au montage d'une petite vidéo de 2 minutes, je rencontre deux problèmes:
      • Mémoire système allouée à Première Eléments 14 presque saturée.
      • Lors de la création du DVD : Erreur Transcodage
      Ma config :
      SSD 1 To pour le système avec 40 Go alloué à la mémoire virtuelle sur le SSD
      Merci de votre aide.
        • 1. Re: Mémoire système allouée insuffisante. Erreur Transcodage lors export vers DVD
          Your operating system is 32 bits which means you will not be able to use more then 4 gig (3.48 to be precise)
          I dont think you will be able to solve this problem without upgrading to Windows 10 64 bits and put some more RAM in your machine. (12-16 gig).
          Then you still will be left with Elements being 32 bits.
          Maybe you can swap that for a 64 bits version at Adobe (not sure about that, might want to Contact Customer Care on that).
          • 2. Re: Mémoire système allouée insuffisante. Erreur Transcodage lors export vers DVD
            A.T. Romano Level 7
            ajc3
            At this time, just how much available RAM does your computer have?
            From your screenshot, it looks like you are only exporting Expert & Share/Devices/Computer
            1920 x 1080
            1 minutes 45.45 seconds Duration
            412 MB Files Size (Please verify that is your 412,20 Mo and you are using a comma as decimal point.)
            Even a Windows 10 32 bit computer and Premiere Elements 14 might be expected to handle that. Also, consider the use of Expert & Share/Devices/Custom advanced settings to create your own export preset (including a lower bitrate). Nonetheless....
            What are the properties (formats) of the Timeline content?
            Premiere Elements 14/14.1 as a 32 bit application limits you in the larger projects. Premiere Elements 14/14.1 Windows is 64 bit application when it is specifically installed on Windows 7, 8, 8.1, or 10 64 bit.
            But, from the data in your screenshot, I suspect that there is more going on beyond the lower memory message. Please explore the Timeline content and structure and other possible computer memory problems beyond the limitations of a 32 bit system.
            Thank you.
            ATR
