3 Replies Latest reply on Jan 28, 2016 5:32 AM by rob day
    Applescript and Indesign files
    ciceroc69199093
      Hi I am using this script :
      set demodoc to (choose file with prompt "Where is “Scripting Examples:chevalet Indesign?" of type {"indd"})
      tell application "Finder"
        set demofolder to (container of myDocument) as text
      end tell
      tell application "Adobe InDesign CS5"
      activate
      import data from file (demofolder & "Fusion.txt") ¬
        using prototype story "chevalet" into story "page"
      end tell
      But the problem is when I am testing it, the prompt is not able to see Indesign files.
      I tested several times with indt, .indd, InDd, idml, ...  but nothing is working.
      I don't really understand.
      I have actually Adobe InDesign CS6 and Mac OSX Yosemite.
      Can someone help me please?
        • 1. Re: Applescript and Indesign files
          Try
          set demodoc to (choose file with prompt "Where is “Scripting Examples:chevalet Indesign?" of type {"InDd", "IDd4", "IDd5", "IDd6", "IDd7", "IDd8", "IDd9", "IDdX", "IDdXI", "IDXt"})
          • 2. Re: Applescript and Indesign files
            ciceroc69199093 Level 1
            It's working, and it's better than I expected all files and also folder can be seen by the prompt.
            Really thanks Sir Rob.
            Regards,
            • 3. Re: Applescript and Indesign files
              Would it be easier to simply ask for the text file and wrap the import command in a try, which you should probably do anyway in case the import fails? Something like:
                   --note for the prompt to display this line has to be in the Finder tell
                  set demodoc to (choose file with prompt "Where is the Fusion Text File?")
                      try
                          --import commands
                      on error
                          display dialog
                          "Please choose a Text File"
                             return
                      end try
                  end tell
              end tell
