2 Replies Latest reply on Mar 9, 2009 5:35 PM by Ned Murphy
    importing swf file within a mc button
      I have a mc button within a mc button, on the second button I trying to open a external swf file. how can I do that?
      I am somewhat new to flash, so have a detailed description of what to do would be great thanks.
        • 1. Re: importing swf file within a mc button
          clbeech Level 3
          when using AS2 you cannot 'read' events that occur on a child clip of a parent that has an event handler (ie. onPress, onRelease, etc.)
          in this case you need to use a method such as hitTesting within a loop the child clip once the exterior event handler has been invoked, such as with a drop down menu.
          there are several posts here with code solutions to this problem, i know that i and others have posted. search the forums for this issue and you will find the solution codes needed.
          • 2. Re: importing swf file within a mc button
            Generally, if you have a button within a button, the outer button will not allow the inner button to work.
            Also what do you mean regarding "open a external swf"?
