2 Replies Latest reply on Jan 29, 2016 1:37 AM by graceplight
    merging black and white scanned images
    graceplight
      I am trying to merge (and align) three scanned black and white TIFF images of old photos (dimension of each image is 2480 x 3508).
      The images are overall of good quality (low noise), have small overlaps and are pretty well aligned (minimal cropping should be needed on merged image).
      I tried using the Photo Merge options but I get unknown error or "not enough info to estimate the camera motion".
      Not sure what to do next....
        • 1. Re: merging black and white scanned images
          Hayhill Level 2
          What version or LR? Although there are a few problems being reported with the latest  (6.4), it sound like your problem is the "small overlap". The automatic merge to pano algorithms generally require a very generous overlap to work correctly. 30-40% overlap for each picture is typical. Sounds to me that you may have to do this manually in PS.
          • 2. Re: merging black and white scanned images
            graceplight Level 1
            Thank you for the useful reply.
            I updated to the latest LR version, and at least now I can see the images inside of the Panorama window with different projections.
            However, once I select Merge, the application crashes with this error:
            Problem Event Name:    APPCRASH
              Application Name:    lightroom.exe
              Application Version:    6.4.0.10
              Application Timestamp:    56a2e8ef
              Fault Module Name:    StackHash_8cab
              Fault Module Version:    6.1.7601.19110
              Fault Module Timestamp:    568429e5
              Exception Code:    c0000374
              Exception Offset:    00000000000bffc2
              OS Version:    6.1.7601.2.1.0.256.48
              Locale ID:    1033
              Additional Information 1:    8cab
              Additional Information 2:    8cab7204dbb82444e280aa23a464d37b
              Additional Information 3:    2000
              Additional Information 4:    200059a6835754cfd7efe43e1a4354e4
