3 Replies Latest reply on Feb 2, 2016 2:30 PM by Carl Von Stetten
    Application Fault with jrun_iis6_wildcard.dll IIS worker process stopped
    AlphaPepper
      Hello everyone,
      I recently inherited an application running ColdFusion MX7 Version: 7,0,0,91690
      This application was moved to a Windows 2008 R2 Server last year.  Ever since then we've been getting an intermittent error in the Windows Application Event Log.   The error is generated when a user is navigating through the application, clicks on something and gets a "This page can't be displayed" in IE.
      The error details are below.  It's IIS 7.5 on Windows 2008 R2.  The Application Pool is the DefaultAppPool.  The Identity is set to "ApplicationPoolIdentity".
      This problem is intermittent.   But when it happens it's a huge inconvenience for users.  Now that I've inherited this I'm expected to figure it out (the previous owner never bothered to look into it).
      Any help/guidance is appreciated.   Many thanks!
      Faulting application name: w3wp.exe, version: 7.5.7601.17514, time stamp: 0x4ce7a5f8
      Faulting module name: jrun_iis6_wildcard.dll, version: 4.0.5.25479, time stamp: 0x41dd9e81
      Exception code: 0xc0000005
      Fault offset: 0x0000b0a7
      Faulting process id: 0x1498
      Faulting application start time: 0x01d159e5ed3b47d1
      Faulting application path: C:\WINDOWS\SysWOW64\inetsrv\w3wp.exe
      Faulting module path: \\?\C:\CFusionMX7\runtime\lib\wsconfig\1\jrun_iis6_wildcard.dll
      Report Id: a7a6074f-c5df-11e5-8b57-005056a82e22
      Details from Windows Error Reporting:
      Version=1
      EventType=APPCRASH
      EventTime=130984736096658977
      ReportType=2
      Consent=1
      ReportIdentifier=a7a60750-c5df-11e5-8b57-005056a82e22
      IntegratorReportIdentifier=a7a6074f-c5df-11e5-8b57-005056a82e22
      WOW64=1
      1. Response.type=4
      Sig[0].Name=Application Name
      Sig[0].Value=w3wp.exe
      Sig[1].Name=Application Version
      Sig[1].Value=7.5.7601.17514
      Sig[2].Name=Application Timestamp
      Sig[2].Value=4ce7a5f8
      Sig[3].Name=Fault Module Name
      Sig[3].Value=jrun_iis6_wildcard.dll
      Sig[4].Name=Fault Module Version
      Sig[4].Value=4.0.5.25479
      Sig[5].Name=Fault Module Timestamp
      Sig[5].Value=41dd9e81
      Sig[6].Name=Exception Code
      Sig[6].Value=c0000005
      Sig[7].Name=Exception Offset
      Sig[7].Value=0000b0a7
      DynamicSig[1].Name=OS Version
      DynamicSig[1].Value=6.1.7601.2.1.0.274.10
      DynamicSig[2].Name=Locale ID
      DynamicSig[2].Value=1033
      DynamicSig[22].Name=Additional Information 1
      DynamicSig[22].Value=12d4
      DynamicSig[23].Name=Additional Information 2
      DynamicSig[23].Value=12d477f32913d53e5db39e24097950de
      DynamicSig[24].Name=Additional Information 3
      DynamicSig[24].Value=265a
      DynamicSig[25].Name=Additional Information 4
      DynamicSig[25].Value=265a3b834dddc27b6c478f267fcc46aa
      UI[2]=C:\WINDOWS\SysWOW64\inetsrv\w3wp.exe
      UI[5]=Check online for a solution (recommended)
      UI[6]=Check for a solution later (recommended)
      UI[7]=Close
      UI[8]=IIS Worker Process stopped working and was closed
      UI[9]=A problem caused the application to stop working correctly. Windows will notify you if a solution is available.
      UI[10]=&Close
      LoadedModule[0]=C:\WINDOWS\SysWOW64\inetsrv\w3wp.exe
      LoadedModule[1]=C:\WINDOWS\SysWOW64\ntdll.dll
      LoadedModule[2]=C:\WINDOWS\syswow64\kernel32.dll
      LoadedModule[3]=C:\WINDOWS\syswow64\KERNELBASE.dll
      LoadedModule[4]=C:\WINDOWS\syswow64\ADVAPI32.dll
      LoadedModule[5]=C:\WINDOWS\syswow64\msvcrt.dll
      LoadedModule[6]=C:\WINDOWS\SysWOW64\sechost.dll
      LoadedModule[7]=C:\WINDOWS\syswow64\RPCRT4.dll
      LoadedModule[8]=C:\WINDOWS\syswow64\SspiCli.dll
      LoadedModule[9]=C:\WINDOWS\syswow64\CRYPTBASE.dll
      LoadedModule[10]=C:\WINDOWS\system32\pcwum.DLL
      LoadedModule[11]=C:\WINDOWS\syswow64\USER32.dll
      LoadedModule[12]=C:\WINDOWS\syswow64\GDI32.dll
      LoadedModule[13]=C:\WINDOWS\syswow64\LPK.dll
      LoadedModule[14]=C:\WINDOWS\syswow64\USP10.dll
      LoadedModule[15]=C:\WINDOWS\syswow64\ole32.dll
      LoadedModule[16]=C:\WINDOWS\SysWOW64\inetsrv\IISUTIL.dll
      LoadedModule[17]=C:\WINDOWS\system32\IMM32.DLL
      LoadedModule[18]=C:\WINDOWS\syswow64\MSCTF.dll
      LoadedModule[19]=C:\PROGRA~2\Sophos\SOPHOS~1\SOPHOS~1.DLL
      LoadedModule[20]=C:\WINDOWS\syswow64\PSAPI.DLL
      LoadedModule[21]=C:\WINDOWS\system32\ntmarta.dll
      LoadedModule[22]=C:\WINDOWS\syswow64\WLDAP32.dll
      LoadedModule[23]=C:\WINDOWS\SysWOW64\inetsrv\w3wphost.dll
      LoadedModule[24]=C:\WINDOWS\syswow64\OLEAUT32.dll
      LoadedModule[25]=C:\WINDOWS\SysWOW64\inetsrv\nativerd.dll
      LoadedModule[26]=C:\WINDOWS\syswow64\CRYPT32.dll
      LoadedModule[27]=C:\WINDOWS\syswow64\MSASN1.dll
      LoadedModule[28]=C:\WINDOWS\syswow64\XmlLite.dll
      LoadedModule[29]=C:\WINDOWS\system32\ktmw32.dll
      LoadedModule[30]=C:\WINDOWS\SysWOW64\inetsrv\IISRES.DLL
      LoadedModule[31]=C:\WINDOWS\system32\CRYPTSP.dll
      LoadedModule[32]=C:\WINDOWS\system32\rsaenh.dll
      LoadedModule[33]=C:\WINDOWS\system32\mscoree.dll
      LoadedModule[34]=C:\WINDOWS\system32\apphelp.dll
      LoadedModule[35]=C:\WINDOWS\syswow64\CLBCatQ.DLL
      LoadedModule[36]=C:\WINDOWS\system32\mlang.dll
      LoadedModule[37]=C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
      LoadedModule[38]=C:\WINDOWS\syswow64\SHLWAPI.dll
      LoadedModule[39]=C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
      LoadedModule[40]=C:\WINDOWS\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4940_ none_d08cc06a442b34fc\MSVCR80.dll
      LoadedModule[41]=C:\WINDOWS\system32\inetsrv\iiscore.dll
      LoadedModule[42]=C:\WINDOWS\SysWOW64\inetsrv\W3TP.dll
      LoadedModule[43]=C:\WINDOWS\SysWOW64\inetsrv\w3dt.dll
      LoadedModule[44]=C:\WINDOWS\system32\HTTPAPI.dll
      LoadedModule[45]=C:\WINDOWS\system32\slc.dll
      LoadedModule[46]=C:\WINDOWS\syswow64\WS2_32.dll
      LoadedModule[47]=C:\WINDOWS\syswow64\NSI.dll
      LoadedModule[48]=C:\WINDOWS\syswow64\Normaliz.dll
      LoadedModule[49]=C:\WINDOWS\system32\faultrep.dll
      LoadedModule[50]=C:\WINDOWS\system32\Secur32.dll
      LoadedModule[51]=C:\WINDOWS\system32\NLAapi.dll
      LoadedModule[52]=C:\WINDOWS\system32\napinsp.dll
      LoadedModule[53]=C:\WINDOWS\System32\mswsock.dll
      LoadedModule[54]=C:\WINDOWS\system32\DNSAPI.dll
      LoadedModule[55]=C:\WINDOWS\System32\winrnr.dll
      LoadedModule[56]=C:\ProgramData\Sophos\Web Intelligence\swi_ifslsp.dll
      LoadedModule[57]=C:\WINDOWS\system32\VERSION.dll
      LoadedModule[58]=C:\WINDOWS\System32\wshtcpip.dll
      LoadedModule[59]=C:\WINDOWS\System32\wship6.dll
      LoadedModule[60]=C:\WINDOWS\system32\IPHLPAPI.DLL
      LoadedModule[61]=C:\WINDOWS\system32\WINNSI.DLL
      LoadedModule[62]=C:\WINDOWS\system32\rasadhlp.dll
      LoadedModule[63]=C:\WINDOWS\System32\fwpuclnt.dll
      LoadedModule[64]=C:\WINDOWS\System32\inetsrv\cachuri.dll
      LoadedModule[65]=C:\WINDOWS\System32\inetsrv\cachfile.dll
      LoadedModule[66]=C:\WINDOWS\System32\inetsrv\cachtokn.dll
      LoadedModule[67]=C:\WINDOWS\System32\inetsrv\cachhttp.dll
      LoadedModule[68]=C:\WINDOWS\System32\inetsrv\defdoc.dll
      LoadedModule[69]=C:\WINDOWS\System32\inetsrv\dirlist.dll
      LoadedModule[70]=C:\WINDOWS\System32\inetsrv\protsup.dll
      LoadedModule[71]=C:\WINDOWS\System32\inetsrv\static.dll
      LoadedModule[72]=C:\WINDOWS\System32\inetsrv\authanon.dll
      LoadedModule[73]=C:\WINDOWS\System32\inetsrv\modrqflt.dll
      LoadedModule[74]=C:\WINDOWS\System32\inetsrv\custerr.dll
      LoadedModule[75]=C:\WINDOWS\System32\inetsrv\loghttp.dll
      LoadedModule[76]=C:\WINDOWS\System32\inetsrv\iisreqs.dll
      LoadedModule[77]=C:\WINDOWS\system32\WSOCK32.dll
      LoadedModule[78]=C:\WINDOWS\System32\inetsrv\isapi.dll
      LoadedModule[79]=C:\WINDOWS\System32\inetsrv\filter.dll
      LoadedModule[80]=C:\WINDOWS\System32\inetsrv\validcfg.dll
      LoadedModule[81]=C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\webengine.dll
      LoadedModule[82]=C:\WINDOWS\system32\USERENV.dll
      LoadedModule[83]=C:\WINDOWS\system32\profapi.dll
      LoadedModule[84]=C:\Windows\Microsoft.NET\Framework\v4.0.30319\aspnet_filter.dll
      LoadedModule[85]=C:\WINDOWS\system32\MSVCR110_CLR0400.dll
      LoadedModule[86]=C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_filter.dll
      LoadedModule[87]=\\?\C:\CFusionMX7\runtime\lib\wsconfig\1\jrun_iis6_wildcard.dll
      FriendlyEventName=Stopped working
      ConsentKey=APPCRASH
      AppName=IIS Worker Process
      AppPath=C:\WINDOWS\SysWOW64\inetsrv\w3wp.exe
