2 Replies Latest reply on Feb 6, 2016 10:31 AM by s. bartc62478624
    Will not save.  Save/export PDF hangs forever although will print.
    s. bartc62478624
      Trying to bring a little one made by combining 5 one page PDFs.  Try to save or export as pdf and it hangs.
      It will print.  MAC 10.11.3
        • 1. Re: Will not save.  Save/export PDF hangs forever although will print.
          YatharthS Adobe Employee
          Hi ,
          Please provide the exact dot version for acrobat,check whether any update available for the software after going through 'Help > check for updates'. If its up to date try this step :-
          ** Restore Preferences :-
          1.From finder,please navigate to Go >Go to folder > Library,from here under the preferences folder remove all the ".plist" files for acrobat .
          2. Then from Go to folder > ~Library, from here under the preferences folder remove all the ".plist" files for acrobat .
          Would like to know whether is this happening with this document or will others as well.
          Regards,
          Yatharth
          • 2. Re: Will not save.  Save/export PDF hangs forever although will print.
            s. bartc62478624 Level 1
            All software was up to date.  I was filling out and signing a form.
            I believe the problem was caused by some interaction with CloudS which in this case is
            absolutely unnecessary and a wasted overhead.  I am sure there are many applications
            where this overhead is worthwhile.
            Much easier to do it with OS X Preview.
            Thanks for your concern and efforts.
            Bart Childs
