1 2 Previous Next 41 Replies Latest reply on Feb 6, 2016 9:58 AM by Jim_Simon
    Why is my render not making more use of my GPU?
    site fail Level 1
      We recently upgraded from Windows 7 to Windows 10 (clean install), added two SSD drives (one as a system drive, one for Adobe cache, etc.), and the system has a 10TB RAID for media.  The system is a dual proc Xeon machine.  We also upgraded from the Quatro 4000 to the M5000 (properly connected and supplied with the additional power required, latest drivers installed).  The problem is that I notice no difference in the slugish performance I see in Premiere and in rendering.  I've attached a screen capture that shows almost no GPU usage and the render of a 24 second clip taking nearly an hour with long gaps between frames in which the computer seems to do nothing.  And why is CPU utilization so hight?  There are a few effects applied to the footage, mainly MagicBullet Denoiser II as well as some Grad filters. Raw footage is BMCC DNG image sequence.  I understand that Denoiser II is slow, but I'm not understanding why it is so slow on such an expensive system and why the graphics card spends most of its time doing nothing. I've even closed all other applications and told the nvidia control panel to set power use to prefer maximum performance.  Any advice would be appreciated.
        • 2. Re: Why is my render not making more use of my GPU?
          site fail Level 1
          Thanks but that raises more questions than it answers as all of the effects I'm using, including Denoiser II, are supposed to be GPU accelerated.
          • 3. Re: Why is my render not making more use of my GPU?
            Premiere does not support MPE hardware on Denoiser.
            Might want to contact Red Giant on this one.
            Red Giant - User Guides
            • 4. Re: Why is my render not making more use of my GPU?
              site fail Level 1
              "Our latest update features a GPU speed enhancement that is supported on systems with OpenCL 1.1 and higher. The "Use GPU" checkbox is turned on if Denoiser II v1.4 detects a suitable GPU."
              Red Giant | Compatibility
              • 5. Re: Why is my render not making more use of my GPU?
                Jim_Simon Level 9
                If you turn that effect off, how the performance?
                • 6. Re: Why is my render not making more use of my GPU?
                  site fail Level 1
                  Not nearly as bad, but playback is still only 1 or less frames per second at 1/2 res.  With denoiser on it is unusable (which I can accept and I usually just apply it just prior to render...what I can't accept is a 24 second clip taking an hour to render and the GPU hardly being used).  With effects turned off playback nearly reaches realtime at 1/2 res.
                  • 7. Re: Why is my render not making more use of my GPU?
                    Jim_Simon Level 9
                    OK.
                    What kind of performance are you seeing with just the clips, no effects at all?  Do you get realtime at Full quality?
                    • 8. Re: Why is my render not making more use of my GPU?
                      site fail Level 1
                      About 5 or 6 frames per second with nothing rendering.
                      • 9. Re: Why is my render not making more use of my GPU?
                        Jim_Simon Level 9
                        OK.
                        What kind of CPU usage are you getting for just the media at Full, no effects?
                        • 10. Re: Why is my render not making more use of my GPU?
                          site fail Level 1
                          It spikes to 100% on playback, no effects.
                          • 11. Re: Why is my render not making more use of my GPU?
                            Jim_Simon Level 9
                            OK.
                            So my first thought here is that even with the dual Xeon's, your system just isn't powerful enough to properly handle this media.
                            Those CPU's are pretty old.  You might do well to consider upgrading again to a more modern 5930K.
                            • 12. Re: Why is my render not making more use of my GPU?
                              site fail Level 1
                              Thanks for all yer responses.  It is an HP Z800 workstation with upgrades, including RAID card, additional memory, and a graphics card (nvidia M5000) done by CDW under a corporate account.  I find it difficult to believe that a workstation that costs in excess of 10 grand can't play this video (it actually did better with the old card).  When it comes to playing DNG image sequences, the bottleneck should be the drives, not the processor since there is no long GOP codec to decode.  And there is hardly any load on the drive that the media is on.  Additionally, I see a graphics card that cost thousands of dollars sitting around doing nothing when, according to everything I've read, it should be doing the majority of the work. I'm thinking there may be some sort of conflict somewhere?
                              • 13. Re: Why is my render not making more use of my GPU?
                                Jim_Simon Level 9
                                Well, that you're pegging the CPU during simple playback is a pretty good indicator that you just don't have enough CPU there.
                                Like I said, they're pretty old.
                                If you care to upload a clip somewhere, I can test it here, see how it runs.
                                • 14. Re: Why is my render not making more use of my GPU?
                                  RoninEdits Most Valuable Participant
                                  what resolution is the bmcc cinemadng footage? 2.5k or 4.6k or different? i would think your computer could handle 2.5k or lower fine. im not sure about 4.6k, but would still expect it to do better than 6fps. your dual xeon, as jim points out, is old tech from around 2010. its comparable to a fast new intel 4 core cpu. the quadro m5000 is an underclocked gtx 980. it has alot of power, so if it is having to wait on the cpu's for frames to work on, it will show alot of idle time and low usage.
                                  premiere doesn't use the gpu for the majority of the workload, it has always been the cpu. the gpu is still important and in some projects with enough gpu effects can start to equal the cpu workload, but not replace it. Adobe Premiere Pro CC and GPU support | Premiere Pro work area   however premiere is suppose to use the gpu for debayering with the cinemadng footage. Ingest and edit native camera formats in Premiere Pro CC | Adobe Premiere Pro CC tutorials.  if you disable mercury playback engine gpu acceleration cuda, does playback perform any worse or the same? if its close to the same, then perhaps there is an issue with premiere not using the gpu for debayering.
                                  when you tested just the media and got 5-6 fps on playback, was that in the source monitor or a new timeline without the grad filters or any other media?
                                  if you play other media, like dnxhd/r, prores, or cineform, does the computer work ok? or does all media struggle for simple playback?
                                  • 15. Re: Why is my render not making more use of my GPU?
                                    site fail Level 1
                                    Thanks Jim and Ronin.  The footage is original BMCC, so 2.5k and the slow playback happens in both the program monitor with all effects turned off as well as in the source monitor and it pings the CPU in both.  I'm not sure why this is an issue for me and no one else seems to notice, but Resolve can play BMCC footage on my system just fine at full res with less than a 50% CPU usage so I'm pretty sure this is an Adobe engineering issue.  I can't see how it would be possible that the camera itself can playback footage with the hardware it has and this system won't.  I know there is dedicated hardware in the camera, but I don't buy the argument that this footage can't be played on this system...indeed I've proven that it can be with Resolve.  Resolve can even play graded footage just fine and I can scrub through it pretty well.  I wish I had another editing platform I could install to do some further testing but it seems to me that there are some issues with Premiere. In regards to turning off Mercury for playback, it is far worse with it off, about one frame per second at 1/2 res in the source monitor.  So what gives?
                                    • 16. Re: Why is my render not making more use of my GPU?
                                      Jim_Simon Level 9
                                      That's not the argument we're making, though.  We're saying it can't be easily played back on that system by Premiere Pro.  How it plays in other programs isn't relevant unless you plan to stop using PP and exclusively use the other program.  (Which might actually be an option with Resolve 12.)
                                      • 17. Re: Why is my render not making more use of my GPU?
                                        if we were to pretend for a moment that the cinemadng was that demanding in premiere and you needed a new computer, it would have to be 4x faster to get from 6fps to 24fps. no current dual xeon system is that powerful, and premiere doesn't support quad xeon systems, so basically it would be impossible. i do believe premiere should be able to handle the cinemadng 2.5k media with your computer. premiere for all its problems, is pretty efficient with system resources in my experience. with disabling cuda and playback performance dropping so bad, it suggests to me that cuda is being used and the gpu may not be the issue.
                                        i think the problem is with premiere working properly, but i haven't heard of any recent cinemadng problems or fixes to your situation.
                                        do you have other media types like prores/dnxhd/cineform that work properly or does all media have major performance issues?
                                        does media encoder and prelude have similar poor performance with cinemadng media (not projects from premiere)?
                                        if you can install some older versions of premiere, you could test if its just a new issue with cc2015 or not.
                                        • 18. Re: Why is my render not making more use of my GPU?
                                          Kevin-Monahan Adobe Employee
                                          Moving to Hardware forum.
                                          Kevin
                                          • 19. Re: Why is my render not making more use of my GPU?
                                            Jim_Simon Level 9
                                            I'm not sure the math on this one is quite that simplistic.  But I'm still willing to test the media on my two systems to see what's up, if one cares to upload a clip.
                                            • 20. Re: Why is my render not making more use of my GPU?
                                              site fail Level 1
                                              Hello.  Thanks for the feedback.  I've done some tests but I decided to start a new thread as this no longer seems related to just the render performance as related to the GPU.
                                              • 21. Re: Why is my render not making more use of my GPU?
                                                ECBowen Most Valuable Participant
                                                There are several problems involved with this config. Number 1 those CPU's are 4 generations back at this point and the clock speed is to low for good realtime playback and GPU acceleration. You want the CPU clock speed to be atleast 2.6 GHz or higher. GPU acceleration performance is impacted greatly by clock speed. The lower the clock speed the less data gets to the GPU at any point in time. More threads helps but does not offset the low clock speed. Couple this the ram bandwidth of that platform compared to the current X99 platform ie i7 Gen 4. is significantly lower ie a fraction of the performance with far lower clock speed. This has a huge impact on GPU acceleration with frames above 1080 resolution. The 10TB raid you list does not state the amount of drives. CinemaDNG media takes a huge amount of disk bandwidth even at 1080 res. At 2.5K res the disks need to be able to handle around 500 to 600MB/s or more. At 4K you are talking upward of 1GB/s a sec. That likely is a huge impact to what you are running now. You can try and move some of that media to the SSD cache drive and see how it plays in a Premiere timeline by itself. However I would plan on getting 1TB SSD's for media if you work with Cinema DNG often. Adobe has far greater caching at the moment with CC 2015 than previous version and other applications. Davinci also caches far more to ram when playing back. Premiere has GPU accelerated debayering which should help with the Cinema DNG media but you have to have the clock speed on the CPU's to really be beneficial. All the way around the CPU's and ram are a major bottleneck for that platform compared to the current X99 platform. That system with a 5960 8 Core and 64GB of DDR4 would vastly outperform the current system you have with 2.5K or 4K media especially CinemaDNG. Also keep in mind the camera playback is far different than media playback in an editor just like playback in QuickTime player or VLC is far less load on the system and less disk requirement than an editor.
                                                Eric
                                                ADK
                                                • 22. Re: Why is my render not making more use of my GPU?
                                                  jim, it was just to make a point against how bad the performance was at 6fps. even if it required a computer 2x more powerful, the current i7 x99 cpu's wouldn't cut it.
                                                  there is this old footage to download if you or anyone else wants to test it.
                                                  http://video.blackmagicdesign.com/Shot_1.zip
                                                  http://video.blackmagicdesign.com/Shot_2.zip
                                                  http://video.blackmagicdesign.com/Shot_3.zip
                                                  http://video.blackmagicdesign.com/Shot_4.zip
                                                  http://video.blackmagicdesign.com/Shot_5.zip
                                                  • 23. Re: Why is my render not making more use of my GPU?
                                                    site fail Level 1
                                                    My point is not that the system is not old, my point is that it used to work just fine in CC, and CC2014 for editing this footage. I could playback BMCC 2.5k CinemaDNG just fine, in fact I could even scrub through it and play it with basic grading on it.  As I said, I've edited feature length pieces (Portrait of St Louis at 250 Years) and countless smaller projects this way. Additionally, see my other post detailing the tests I've run for simple playback.  This system, for example, can play GH4 4k footage with nearly no load on the processor or graphics card.  Inside of Premiere, the load is significant.  The same goes for all other formats I've tested.  IMHO, there is no reason that it should be 2,3, or 6 times more taxing on the processor to run playback from the source monitor in premiere as it is to run playback via VLC or Windows Media Player.  I'll gladly hear arguments to the contrary, but if "Premiere should be significantly slower to play video than freeware" is a realistic argument to Adobe then I need to know so I can make decisions moving forward.  I work for a NFP institution and we can't afford to replace expensive editing workstations every other year because software actually got slower.
                                                    • 24. Re: Why is my render not making more use of my GPU?
                                                      i saw your other thread, here it is for anyone reading this thread. Premiere Performance - Some questions and tests.
                                                      i would like to point out one real possibility between playback in media players such as vlc and premiere... your quadro m5000 should support h.254 and h.265 media decoding, and the media player programs may be using that to offload the cpu workload. even though this tech has been around for a long time (for h264), premiere does not support gpu accelerated decoding and encoding of h264 and h265 media. these formats are very compressed and cpu's are not designed to handle them, so premiere will see heavy cpu usage with these codecs.
                                                      looking at your testing with dnxhd it shows premiere not too far off from vlc cpu usage, and that is what i would expect as there is no gpu acceleration for dnxhd. if its dnxhd 444 10bit maybe the cpu usage is about right for your machine, but if its simple 422 8bit dnxhd i would expect it to be closer to 10% cpu on your machine. if that media was 422 8bit dnxhd, you might wanna run cinebench benchmark and see how well your cpu's are performing.
                                                      i still don't have any solutions for the cinemadng problem. there are several settings in resolve that affect the cpu usage with cinemadng playback, i think 4 or more various settings, which might explain the lower cpu usage in resolve. i don't recall any performance/quality settings in premiere for cinemadng. you said it worked before on an oler version of premiere, and before the hardware upgrades, have you tried installing an older version of premiere to test?
                                                      • 25. Re: Why is my render not making more use of my GPU?
                                                        Bill Gehrke Adobe Community Professional & MVP
                                                        I downloaded one of the clips referenced above.  I can easily play it back (without any added effects) on this laptop with full resolution without any frame loss on this laptop (i7-4700HQ, 24GB of RAM, GTX 765M, 2 SATA III SSD's, with Premiere 9.1, then I noticed that it was still 9.1 and upgraded to Premiere 9.2 and it dropped 2-6 frames per playback.
                                                        • 26. Re: Why is my render not making more use of my GPU?
                                                          there is another variable, those files are from when the bmcc camera's first came out. since then, there is a new, slightly more compressed, cinemadng format that the camera's can produce from an update. im not sure if there is a performance or compatibility difference with premiere and the new format or not... if the OP, site fail, wants to share a clip or two, it might be worth testing. at the same time, site fail could download and test one of those old clips to see if there is a performance difference.
                                                          • 27. Re: Why is my render not making more use of my GPU?
                                                            Jim_Simon Level 9
                                                            I downloaded one of the older test clips.  It played back without any dropped frames on my i5 2500K system for about 2 seconds, but then started dropping frames.  However, this was due to my single disk drive which just couldn't keep up.  The CPU only hit about 10% load during playback.
                                                            • 28. Re: Why is my render not making more use of my GPU?
                                                              your cpu and bills laptop cpu are somewhat close in performance, and about as powerful as one of the xeon's in site fails dual xeon machine. for your machine to only be using 10% cpu before the drive bottlenecked the playback, suggests site fail's machine is plenty more than powerful enough. we still have the possibility of the new cinemadng format being an issue, as those were the old/original format in that link.
                                                              • 29. Re: Why is my render not making more use of my GPU?
        Jim_Simon Level 9
        I'm still happy to test those, should they be uploaded.
        • 30. Re: Why is my render not making more use of my GPU?
        site fail Level 1
        Thanks guys, I'm running the benchmark now and after that I'll download one of the orig files and report back.  I do have the latest firmware on the camera but, as I mentioned before, this performance drop is pretty univeral against all formats.  Later, when I report back, I'll include the results of some other tests.
        • 31. Re: Why is my render not making more use of my GPU?
        Hey, I just noticed from your Task Manager images that you are only running your CPU's at half power.  You do not have hyperthreading enabled--why?
        • 32. Re: Why is my render not making more use of my GPU?
        CC2015 greatly increased the caching Adobe uses ie ram for GPU acceleration. This can improve performance with much greater ram bandwidth. GH4 media is no where near as disk intensive or GPU acceleration intensive as CinemaDNG. Its like comparing apples to tomatoes. Of Course the GH4 media will play much easier. It does not have any debayering components like Cinema DNG and it's a fraction of the disk bandwidth ie data streaming from the drives. Memory management itself is also handled by the CPU so the CPU load will increase as the memory management changes. I have tested Raw, CinemaDNG, and R3D extensively and know exactly what it takes to run it well. Your system will not handle it well with the current config. CC2014 was when GPU accelerated debayering was added but not to the extent 2015 uses it. It takes a I7 Gen 3 system with 32GB of ram ie an X79 to handle it decently and X99 to handle it easily. If you want better performance without replacing hardware then go back to CC 2014 or CC when the GPU accelerated debayering was not available and the memory management was far less on the system. 1 last thing I forgot to mention. CC2015 now uses the GPU acceleration player for the source monitor as well as the Timeline monitor. In the past the source monitor just functioned like a standard player without GPU acceleration.
        Eric
        ADK
        • 33. Re: Why is my render not making more use of my GPU?
        i saw the core count but figured it was so old it may not have hyper threading hah. i looked it up, turns out they do have HT. HT doesn't actually increase the raw power of cpu, it just doubles the thread pipelines. some programs work better with extra threads, and get a nice boost, while some don't multi-thread well and do better with HT off. it would still be worth turning on to test.
        i also looked up the memory specs on the cpu's while on intel's site
        i5-2500K has dual channel, 21 GB/s max bandwidth
        i7-4700HQ has dual channel, 25.6 GB/s max bandwidth
        E5649 has triple channel, 32 GB/s max bandwidth
        • 34. Re: Why is my render not making more use of my GPU?
        I also had to look it up before I started typing away!
        Premiere Pro is one of those programs that is well hyperthreaded in most places, so it will really payoff here.
        Bill
        • 35. Re: Why is my render not making more use of my GPU?
        site fail Level 1
        Too old...ha.  I think HT has been around since Pentium 4.  So Hyperthreading was off in the BIOS, I turned it on.  It hasn't helped with playback in my limited testing.  In regards to the benchmark, I did the test (before turning on HT) and the second two encoding took less than a couple minutes each.  I'll also say the the GPU was all over the place, sometimes above 50% with the CPU pretty low.
        However, when I went to run the script it came up with errors.  The files are in the same directory as the script, but it was telling me no such file name on a certian line.  When I looked at the file it was looking for in the script, it was looking for two different mp2 files, one was called MPEG2-DVD test.m2v and the other MPEG2-DVD test_1.m2v, which was never created.  I removed the _1 and the script ran...is this acceptable to do?  Is this a mistake in the script? I will probably run the test again.  Also, the instructions for the last video say to turn on Mercury in the project settings but it was already on...should it be off or on for the first two encodes?
        Playback with the above linked DNG files play back at 20%CPU and 20%GPU (with HT).  I went back and tried a newer DNG file with HT on, and the CPU maxes out at 80% but it doesn't play smoothly at all.  GPU at 20%.  I'll also say that the GPU jumps up past 50% when playing back GH4 footage, for whatever its worth.
        • 36. Re: Why is my render not making more use of my GPU?
        the gh4 4k cpu usage does seem high. but as i pointed out earlier, its heavily compressed h264 which cpu's are not designed to encode/decode. adobe needs to adopt gpu encoding/decoding, otherwise with intel's slowing speed growth, 8k h265 editing will be nearly impossible.
        the new cinemadng format is slightly more compressed than the original format, but your 4x cpu usage increase seems way out of line. so i think its back to a problem with premiere and the media. there are some threads with problems regarding the blackmagic 4k camera's, but i couldn't find any for the 2.5k media. i didn't find any solution either, just conclusions that premiere doesn't support the new format.
        • 37. Re: Why is my render not making more use of my GPU?
        We export the MPEG2-DVD timeline twice  The first time is with GPU acceleration and should produce the MPEG2-DVD.m2v file (during this test you should see almost 100% GPU usage), the second time you export that timeline is with the CPU only (you turn off GPU acceleration) and produces the the MPEG2-DVD_1.m2v file which will be many times longer than the first.  For the the fourth test you will have to turn the GPU acceleration back on.for the H.264 timeline.  If you copy and paste or rename any files it changes the time stamps.  You can cut and paste without changing the time stamps.  If you removed the "_1" from the script that is defeating the purpose.  There is no mistake in the script, it was been run hundreds of times.  The most common problem is the four required files are not located in the proper location.
        • 38. Re: Why is my render not making more use of my GPU?
        Jim_Simon Level 9
        I rather hope they don't.  Or at least offer the option to turn it off.  So far, GPU encoders seem to be inferior to software encoders.
        • 39. Re: Why is my render not making more use of my GPU?
        some are worse, some are just as good. for people working with captured h264 or exporting to h264, there is already a quality hit to begin with. it should be easy enough for them to have an option in export to choose between software or hardware encoding.
        1 2 Previous Next
