3 Replies Latest reply on Jan 29, 2016 9:28 PM by Steve Werner
    Copying & and flipping or flopping on object axis
    peterpica Level 1
      Is there an easy way to have a geometric shape, say a box that has 1/2-point line thickness, replicated (mirrored) left to right on it's right-hand axis... so that the vertical lines where it's rotating from overprint each other EXACTLY? I.e, you don't have a vertical rule in the center that's optically heavier than all other rules in either box. I've a number of forms to be done and manually adjusting the horizontal positioning of these elements is quite tedious. When I use the mirror panel buttons, the objects abut -- they do not overprint on their common edge. Normally I'd set up a table, but the boxes all have rounded corners.
      Thanks.
