5 Replies Latest reply on Feb 5, 2016 6:43 AM by carmeni72280659
    problems with tone curve
      hi all
      where can i put manuell values like that
      RGB:0/27, 21/30, 81/80, 100/84
      Red:7/0, 52/51, 100/100
      Green: 0/1, 100/94
      Blue: 0/10, 28/33, 69/67, 100/93 (picture attached)
      in the tone curve?
      thanks a lot
        • 1. Re: problems with tone curve
          dj_paige Level 9
          The tone curve in Lightroom operates via mouse movements. You cannot input numbers to the tone curve.
          • 2. Re: problems with tone curve
            WobertC Adobe Community Professional
            When you have the "Point" curve optioned- (click on the point curve icon- bottom right)
            You can click on the curve to "Set" a point.
            When you hold the cursor clicked on a set point you will see the from/to percentage coordinates at the top of the tone curve box.
            For example to set 81/80  click a Set point and move it on the curve until you see 81.0/80.0 %  at the top- as in this screen clip- (it shows 82.4 / 80.0 % )
            I have set the four RGB points similar to your values in your screen-clip.-
            (Error in this screen-clip above!!! the Channel selection does not appear if your are developing a PSD file!)
            For a RAW, TIF or JPG the Channel selection is visible-
            To set the individual Color channel curves-
            First open the  drop-down menu beside [Channel :] to select the color channel, then repeat the procedure to set points to the wanted values. Repeat for each color channel- Red Blue Green.
            eg. this is BLUE point 69/67  (The curve shows 69.4 / 66.7 % )
            When you have set all the values in the example in your post- the first step should be to save a Tone Curve Preset and your settings will be easily re-producible.
            • 3. Re: problems with tone curve
              trshaner Adobe Community Professional & MVP
              Previous post deleted-I thought you were trying to enter 0-255 RGB values. Sorry for any confusion!
              In addition to
              • 4. Re: problems with tone curve
                holding the SHIFT key locks the curve point X axis value
                Thanks trshaner,
                I learn something new every day.
                And holding [ALT]- makes the mouse movement much finer for more accurate positioning of the set point.
                • 5. Re: problems with tone curve
                  carmeni72280659 Level 1
                  hey gusys thank you all so much
