10 Replies Latest reply on Feb 1, 2016 6:47 PM by taniab29936993
    Lightroom won't let me import presets
    taniab29936993
      I purchased a preset from BeArt presets, specifically the skin perfection preset. When I try to import the preset files, a box pops up saying that . Error importing. The preset file was the wrong type of preset.
      ddoes anyone know why this would happen? I imported another preset package I purchase last week with no problem.
      thanks
      T
        • 1. Re: Lightroom won't let me import presets
          WobertC Adobe Community Professional
          What kind of preset is it? A Develop preset? Those are the most common, but there are also Export, External Editor, FTP, Filter, Import, Local Adjustment, and Metadata presets. And maybe others.
          You can find the location of your Presets folders in the Presets tab of Preferences.
          Purchased presets can be manually copied to the correct folder if you know which they belong in!
          Can BeArt provide you with more details to install?
          • 2. Re: Lightroom won't let me import presets
            taniab29936993 Level 1
            hi!
            THanks for your reply!
            THe Preset is called Portrait Perfection Collection but BeArt.
            so this preset works in Lightroom. I can make skin adjustments within Lightroom. Brushes are provided along with presets. So I'm not sure what this falls under?
            BEart has given me several different ways to install. At first I thought it's was just an extract issue. But when BeArt sent me a drop box link with all the files extracted, Lightroom wouldn't let me import. BeArt said to install Lightroom again and go to Adobe support. They said this is the first time this has happened to them.
            I Have to wait till Monday to get someone at Adobe support.
            thanks
            tania
            • 3. Re: Lightroom won't let me import presets
              so you mentioned manually copying the presets into the folder. Do you mean directly into the folder in the light room folder I created?
              • 4. Re: Lightroom won't let me import presets
                ManiacJoe Adobe Community Professional
                Yes. Go to the folder where LR keeps the develop presets. On windows this is
                C:\Users\my_name\AppData\Roaming\Adobe\Lightroom\Develop Presets\
                Create a new folder here and copy your presets into that folder.
                • 5. Re: Lightroom won't let me import presets
                  im not sure where to start? In LR on the left hand side I made a new folder in the presets section. When I right click it has import, it doesn't have a paste action and it won't let me import via copy from the unzipped files.  I'm not sure of where I would do the above you mention. Sorry I'm new to LR. Can you break it down a bit more?
                  thanks so much!
                  • 6. Re: Lightroom won't let me import presets
                    The "Manual" method referred to, does not involve Lightroom.
                    You can use Lightroom to show you where your presets are stored by opening preferences and looking in the [Presets] tab- click on [Show Lightroom Presets Folder...].
                    Presets are in a folder "Lightroom Settings"
                    OR you could use the OS to search for the folder "Lightroom Settings"
                    (Note: it can exist in either of two places- 1. As Joe states in Post#4, or 2. In the same folder as the Catalog.
                    Using the Preferences method will always find the location!)
                    Now close Lightroom! and using File Explorer/Mac Finder- copy and paste the xxxx.lrtemplate  files  supplied by BeArt, into a folder where they belong. Two folders are important for editing presets:
                    Global Presets will go in "Develop Presets"
                    Brush Presets will go in "Local Adjustment Presets"
                    You will need to know the difference!
                    • 7. Re: Lightroom won't let me import presets
                      wow!
                      You are a genius!
                      tha is so much! It worked
                      • 8. Re: Lightroom won't let me import presets
                        ok, I just tried to edited a phot using the brushes. But now when I select the skin nightlight preset on the left in LR, and then go to the adjustments tool on the right in LR, I don't see the BeArt settings to highlight the skin. What's going on now? Sigh
                        • 9. Re: Lightroom won't let me import presets
                          Presets on the left of the Develop module screen are 'global' "Development" presets, affecting the whole image.
                          Brush presets only appear when you have the Adjustment Brush active and you choose a brush preset from the "Effect" drop-down menu.   (This reflects the need for the different folders for the presets as discussed above.)
                          So maybe the preset "skin nightlight" should belong in the folder- {Local Adjustment Presets}  and not in {Develop Presets}
                          Global Presets-
                          Local Adjustment "Brush" Presets- In the "Effect" Drop-down menu-
