1 Reply Latest reply on Jan 31, 2016 11:47 PM by Nanaky
    Error:check activation.
    jbwilson13 Level 1
      I've used Digital Editions for years but this morning when I tried to open a book I downloaded from the library, a window stating Error: check activation popped up and won't open my book.  What do I have to do to get this to work like it used to?
        • 1. Re: Error:check activation.
          Nanaky Level 5
          Windows:
          1. Close all applications.
          2. Choose Start > Run.
          3. In the Open text box, type regedit and then press Enter. The Registry Editor opens.
          4. In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
          5. Select the Adept key.
          6. Choose File > Export.
          7. In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
          8. Right-click the Adept key and choose Delete.
          9. In the Confirm Key Delete dialog, click OK.
          10. Close the Registry Editor.
          11. Open Adobe Digital Editions and reauthorize.
          Macintosh:
          1. quit Adobe Digital Editions.
          2. Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
            If you are using 10.7, see Access hidden library files | Mac OS 10.7 and later.
          3. Open Adobe Digital Editions and reauthorize
