9 Replies Latest reply on Jan 31, 2016 12:01 PM by tracyy42935226
    Please help Creating a Detach Button that detaches a document I have attached with an Attach Button
    tracyy42935226 Level 1
      Let me apologize up front for this being a bit of complicated question. I found a thread on this forum that helped me attach a file with a click of a button- now I want to detach this same file.  Below is how far I've gotten.
      I created a form in Adobe Acrobat DC that allows a user to attach a document to the form with a click of a button.  The way this is programmed is that on the button itself with a Mouse Up action, the following Javascript is run:
      if (app.viewerVersion < 11) {
          import_pre_11();
      } else {
          import_11();
      Then there is a document level javascript for attaching the file that is programmed like this:
      // Initialize attachment number
      attachment_num = 1;
      // Initial location of file attachment icon
      // The x value is incremented below
      var oFAP = {x_init: -72, x: -72, y: -72};  // Below lower-left corner of the page
      function import_pre_11() {
          if (app.viewerType === "Reader") {
              app.alert({
                  cMsg: "You must user Reader version 11 or later to attach files to this form.",
                  cTitle: "Attach File Error",
                  nIcon: 3,
                  nType: 0
              return;
          // Prompt user to import a file
          app.alert({
              cMsg: "Click the OK button to select a file from your system.",
              cTitle: "Attach File",
              nIcon: 3,
              nType: 0
          try {
              var rc = this.importDataObject("Attachment" + attachment_num);
              if (rc) {
                  attachment_num += 1;
                  app.alert({
                      cMsg: "Attachment successful.\r\rOpen the Attachments panel to access the attached file(s).",
                      cTitle: "Attachment Successful",
                      nIcon: 3,
                      nType: 0
              } else {
                  app.alert({
                      cMsg: "Attachment cancelled.",
                      cTitle: "Attachment Cancelled",
                      nIcon: 3,
                      nType: 0
          } catch (e) {
              app.alert({
                  cMsg: "Could not attach file.",
                  cTitle: "Could not attach file",
                  nIcon: 3,
                  nType: 0
      function import_11() {
          try {
              var annot = addAnnot({
                  page: event.target.page,
                  type: "FileAttachment",
                  author: "Form user",
                  name: "File Attachment",
                  point: [oFAP.x, oFAP.y],
                  contents: "File attachment on: " + util.printd("yyyy/mm/dd HH:MM:ss", new Date()),
                  attachIcon: "Paperclip"
              annot.cAttachmentPath; // Prompt user to select a file to attach
              oFAP.x += 18;  // Increment the x location for the icon
          } catch (e) {
              app.alert({
                  cMsg: "Could not attach file.\r\rPlease report this error.",
                  cTitle: "File attachment error",
                  nIcon: 3,
                  nType: 0
      That process works flawlessly.  What I want to do now is detach that same document with the click of another button.  I understand very basic javascript but had help from the forum creating the above script.  Can anyone provide me a solution (if there is one), to help me detach the file that the user attached with the script above? Thank you so much in advance!!!
