Hi, I'm very new to Adobe Flash and animating in general, so this is all a lot more complicated than just drawing. I have a project due very soon, and my teacher hasn't had the chance to answer any questions, so here I am. And I have no time to figure it out on my own, since I don't have the program to use at my leisure.
I'm doing a PacMan animation, so here are my questions:
1. I did a motion tween for PacMan, and I want to extend it on the timeline, but when I do, the actions get faster. Is there a way to extend it just so I can insert more keyframes or must I start over with his motions?
2. How can I make an object suddenly appear in a certain frame?
3. I was told to make PacMan run the course all with his mouth open, so now how do I get him to close his mouth? I have an image of him with his mouth closed, so I was going to use that, I just...don't know how.
4. How do I make him turn and face different directions? I've tried rotating him, but all that does is rotate him slowly throughout the whole animation.
I think that's it. Thank you for your help in advance.
actually, if you extend a tween the changes will get slower. there's nothing easy to do about that except change the framerate, but doing that will affect everything in your swf.
insert a keyframe on the timeline
insert a keyframe on the timeline of the layer where you want the object to appear (right click over the frame>click insert keyframe) and then draw/add your object to the stage while that key frame is selected. (add an empty keyframe further down that layer to remove the object.)
make sure pacman is a movieclip. assign pacman an instance name (in the actions panel). add two frames to your pacman timeline. one with mouth open and one with mouth closed. put a stop() in frame 1 of pacman's actions panel. at the keyframe where you want pacman to change from his open mouth frame 1 to his closed mouth frame 2, in the actions panel, add
pacman.gotoAndStop(2);
you can use the transform tool or actionscript to change his x scale to -1.
