More testing has revealed that each time you close the
project and then reopen it, some of your changes to the .css file
are randomly messed with by RH, therefore rendering them useless.
I've just submitted a Bug report for this issue.
Until RH can provide relief for this, the much-ballyhooed
feature is completely useless for the following reasons:
* The default indent and alignment settings are the opposite
of the default settings achieved with the usual list toolbar
buttons. These styles are not useful to us, since they would
display differently from the thousands of lists already in our
projects.
* The output you get when selecting the "disc" List Style is
· - which is actually the tiny "mid-dot", not disc. (The
RH 8 filled-circle option, a non-W3C option, is larger and
therefore closer to the default disc.)
* The None option in the List Style control displays
upper-alpha list markers (A, B, C, etc.), as stated in the original
post.
* No options are enabled when clicking the Format button
(Paragraph for Space after, etc.).
Leon
