4 Replies Latest reply on Feb 1, 2016 12:09 PM by f3arl37664746
    timer and progress bar
    f3arl37664746 Level 1
      hie everyone need a help related to timer, like we watch some music videos in which timer runs with the music, wait here is a link for a sample : https://www.youtube.com/watch?v=AjGFDngVSrE .and the other thing is i want to add progress bar, which will fill up till the music gets end from the start.
      well i am using after effects as well as premiere pro in these days thanks
        • 1. Re: timer and progress bar
          In Premiere Pro, there is the Timecode effect. You could use a garbage matte to knock off the parts of it you don't want.
          In After Effects, you have the Numbers effect which you could keyframe (or use the time expression).
          For a loading bar, just make a shape layer and scale it over time in the x direction.
          Since you're new to AE, you should start here: Getting started with After Effects It will help you avoid a lot of frustration.
          • 2. Re: timer and progress bar
            thanks, it helped me nm, if you have any video tutorials on these 2 subjects it would be great for me i am confuse about timer, actually i want to add timer in my song, with minutes and sec. only, should i use premiere or ae and how ?
            • 3. Re: timer and progress bar
              You can do that with After Effects and the numbers effect. Just play with it a bit.
              Before you do that though, please go through the resources I linked. If you try to use AE without getting a basic understanding of how it works, you're just going to get frustrated.
              • 4. Re: timer and progress bar
                Here Is A Code That I've Got From Youtube, I Dont know Which Language Is That, but it helped me. got to paste in in source text after creating text " 00:00 " and now its working.. thanks tho
                sek = Math.floor(time%60);
                min = Math.floor(time/60);
                if(min<10)
                "0" + min +":" + sek;
                else
                min +":" + sek;
                if(sek<10)
                "0" + min +":0" + sek;
