13 Replies Latest reply on Mar 11, 2009 6:35 AM by apocalipsis19
    Cfheader and cfcontent question
    apocalipsis19 Level 1
      Hi Community!
      I wrote a program that generates a pipe delimited file
      The file downloads to my desktop but I want it to be downloaded to a location in one of my servers. How do I accomplish that?
      This is how my cfheader and cfcontent lines of code looks like:
      <cfcontent type="text/plain" reset="yes">
      <cfheader name="Content-Disposition" charset="utf-8" value="attachment;filename=companyname_#DateFormat(now(),'MMDDYYYYhhmmss')#.txt">
      Any thoughts fellows?
      Thanks!
        • 1. Re: Cfheader and cfcontent question
          Level 7
          Sounds like the wrong tool for the desire job.
          <cfcontent...> is for just what it is doing. Delivering content to the
          client that requested it. So the file is going to end up there, on the
          client system.
          If you want to write the file locally on the ColdFusion application
          server or to a networked server, the <cffile...> tag is the tag for
          this. If you are trying to use networked servers; be aware that, by
          default, ColdFusion is configured to only have permissions to its local
          server. You will need to configure it to have the desired permissions
          to other servers.
          If you are trying to get the file to a server that does not share file
          system access with the ColdFusion server, <cfftp...> would be the tag to
          move the file. This, of course, requires the receiving server to accept
          FTP protocol requests.
          If you can't write files to this server, ftp to this server or have some
          process on this server make a HTTP request to the ColdFusion server,
          then you are going to need to find somebody to walk a disk or memory
          stick from the ColdFusion server to the receiving server with the file
          on it.
          • 2. Re: Cfheader and cfcontent question
            Level 7
            If the CF server is on the same network as the server you mention, and it
            has permissions to do so, you can just write the file with <cffile>.
            If it doesn't have that sort of access, you'll need to use <cfftp> or
            something, which would necessitate the server in question to be running as
            an FTP server.
            What is happening to this file once it arrives at its location on the
            server? I presume some other sort of process / application is picking it
            up and doing something with it? Can that application request the file
            directly from the CF server when it needs it, via a web service call, or
            HTTP request?
            Adam
            • 3. Re: Cfheader and cfcontent question
              Level 7
              OK, so the similarity between your post and my post was a bit spooky, Ian.
              Adam
              • 4. Re: Cfheader and cfcontent question
                Level 7
                Great minds...alike and all that.
                But to get my quota of gloating in today.
                My post was 2 minutes sooner (according my my e-mail time stamps)
                And you did not include the sneaker net option! ;-)
                • 5. Re: Cfheader and cfcontent question
                  Adam and Ian:
                  Thank you for your posts. It looks to me that I will have to use the cffile tags. I was using cfcontent and cfheader because it was easier for me to add the contents to the txt file.
                  I extract my fields from a query then pipe delimit them into a txt file.
                  How would I add that content to the file using cffile?
                  • 6. Re: Cfheader and cfcontent question
                    This is my code to add the content of the generated txt file:
                    <cfoutput>
                    <cfloop index="idx" from="1" to="#getFields.recordcount#">
                    #Trim(getFields.email[idx])#|#Trim(getFields.firstname[idx])#|#Trim(getFields.lastname[idx ])#|#Trim(getFields.postalcode[idx])#|#Trim(getFields.campaign[idx])#|#DateFormat(getField s.firstordd[idx],'MM/DD/YYYY hh:mm:ss:l')#|#getFields.firstordamt[idx]#|#DateFormat(getFields.lastordd[idx],'MM/DD/YYY Y hh:mm:ss:l')#|#getFields.lastordamt[idx]#|#getFields.htdordcnt[idx]#|#getFields.htdordtot [idx]#|#getFields.annualordcnt[idx]#|#getFields.annualordtot[idx]##Chr(13)##Chr(10)#
                    <cfset flagList = "">
                    </cfloop>
                    </cfoutput>
                    • 7. Cfheader and cfcontent question
                      JR "Bob" Dobbs-qSBHQ2 Level 3
                      Your use of DateFormat does not appear to be correct. For the time portion you will need to add the TimeFormat function.
                      You might also consider using the date format "yyyymmdd" so that your files will be sorted by date when they are listed by file name order.
                      See sample.
                      • 8. Re: Cfheader and cfcontent question
                        Level 7
                        Instead of outputting the content to the response stream, you generate
                        it into a variable then use that variable in the appropriate property of
                        the <cffile...> tag.
                        <cfsaveContent...> makes this very easy and would not require much
                        modification to your code, but is by no means the only way to accomplish
                        this.
                        • 9. Re: Cfheader and cfcontent question
                          I was able to use cfsavecontent but my list of values doesn't read the char(13) character. At the end of each line I want to hit enter. I used cfsavecontent like this:
                          <cfsavecontent variable="fileContent">
                          <cfoutput> #Trim(getFields.email[idx])#|#Trim(getFields.firstname[idx])#|#Trim(getFields.lastname[id x])#|#Trim(getFields.postalcode[idx])#|#Trim(getFields.campaign[idx])#|#DateFormat(getFiel ds.firstordd[idx],'MM/DD/YYYY hh:mm:ss:l')#|#getFields.firstordamt[idx]#|#DateFormat(getFields.lastordd[idx],'MM/DD/YYY Y hh:mm:ss:l')#|#getFields.lastordamt[idx]#|#getFields.htdordcnt[idx]#|#getFields.htdordtot [idx]#|#getFields.annualordcnt[idx]#|#getFields.annualordtot[idx]##chr(13)#
                          </cfoutput>
                          </cfloop>
                          </cfsavecontent>
                          Any thoughts?
                          • 10. Re: Cfheader and cfcontent question
                            Level 7
                            apocalipsis19 wrote:
                            > Any thoughts?
                            Two, right of the top of my head.
                            One, in the windows world, it is usually a carriage return and a line
                            feed character (i.e. #chr(13)##chr(10)# at the end of the lines, Unix
                            traditionally just uses a carriage return.
                            Second, you are not outputting HTML anymore - which ignores most extra
                            whitespace in the content. So all the extra whitespace characters
                            [spaces, tabs, returns etc.] in your content block count and can easily
                            throw off file formats.
                            Try this and see if it gets you closer.
                            <cfoutput>
                            <!--- outside the content block so it does not get in the way. --->
                            <cfsavecontent variable="fileContent"><cfloop
                            ...>#var1#|#var2#|#varN##chr(13)##chr(10)#</cfloop></cfsaveContent>
                            <!--- notice how the <cfsavecontent...> block is on one line --->
                            </cfoutput>
                            OR you could also do string concatenation something like this.
                            <cfset fileContent = "">
                            <cfloop...>
                            <cfset fileContent = fileContent & var1 & '|' & var2 & '|' & varN &
                            chr(13) & chr(10>
                            </cfloop>
                            OR
                            you could use the append file function of the cffile tag.
                            <cffile action="write" ... output="#firstLineOfData#">
                            <cfloop...>
                            <cffile action="append" ... output="#otherLinesOfData#">
                            </cfloop>
                            • 11. Re: Cfheader and cfcontent question
                              For Windows OS newline is Chr(13) & Chr(10). For Unix Chr(10).
                              You may also want to remove the white space within your CFSAVECONTENT open and close tags. Any white space within the tags is treated as part of the content to be saved. An HTML file would ignore this white space but it could be important to a formatted text file.
                              Chr function:
                              http://livedocs.adobe.com/coldfusion/8/htmldocs/help.html?content=functions_c-d_04.html#47 49523
                              • 12. Re: Cfheader and cfcontent question
                                Level 7
                                Heh.
                                As I've always said (?), "it's the uniform high quality of answer that
                                really makes these forums great".
                                [snort]
                                Adam
                                • 13. Re: Cfheader and cfcontent question
                                  Adam and Ian:
                                  cffile combined with a cfsavecontent solved my problem!\
                                  Thanks!
