6 Replies Latest reply on Feb 1, 2016 10:08 AM by rob day
    Progressive Leading in InDesign
    billypostle
      Hi I hope someone can help, I have an idea I am finding hard to execute in InDesign, I have around 12000 words that I want to have progressively smaller leading all the way down the page to the point that lines are actually overlapping (legibility is not a factor here). On an A1 page I currently have around 200 lines of text. Is there anyway of telling InDesign to reduce the leading on every new line of text or am I going to have to do this myself? I have attached a screenshot that may help explain what I am trying to do. Hope someone can help!!
      Thanks!
        • 1. Re: Progressive Leading in InDesign
          John Mensinger Adobe Community Professional & MVP
          I don't think you'll find a way to get InDesign to do this for your with any existing features, but I do suspect it might be possible to script. Reposting this in the Scripting forum is probably your best bet. InDesign Scripting
          • 2. Re: Progressive Leading in InDesign
            If you are using OSX try this AppleScript:
            tell application "Adobe InDesign CC 2014"
                set use paragraph leading of text preferences to false
                set x to object reference of every line of selection
                set c to count of x
                set l to leading of item 1 of x
                set p to (1 / c) * l
                repeat with i from c to 1 by -1
                    set leading of item i of x to (c - i) * p
                end repeat
            end tell
            • 3. Re: Progressive Leading in InDesign
              billypostle Level 1
              You sir are a gentle and a scholar, worked an absolute dream!!
              THANK YOU!
              • 4. Re: Progressive Leading in InDesign
                Glad to hear it worked. This version might be better:
                    set use paragraph leading of text preferences of active document to false
                    set c to count of x
                    set lding to leading of item 1 of x
                    set p to (1 / c) * lding
                    repeat with i from 2 to c
                        set leading of item i of x to lding - (p * i)
                    end repeat
                end tell
                • 5. Re: Progressive Leading in InDesign
                  billypostle Level 1
                  Thats a tad less dramatic which actually maybe a good thing. Could you tell me what variable I can adjust to lessen/increase the effect please.
                  At the moment I have something looking like this and I would prefer the text to be slightly more spaced towards the bottom.
                  • 6. Re: Progressive Leading in InDesign
                    See if this helps. The e variable can be adjusted—should be between .5 and .9—the lower the number the more space:
                        --an ease adjustment. Number must be less than 1
                        set e to 0.9
                        set c to count of x
                        repeat with i from 1 to c
                            try
                                set leading of item i of x to lding - ((p * i) * e)
                            end try
                        end repeat
                    end tell
                    .6 on the left, .9 on the right
