2 Replies Latest reply on Feb 12, 2016 1:22 AM by Kamna Yadav
    Elements v11 to Premiere Elements v14
    jeffb58242288
      How do I configure Photoshop V11 so it will "output" & edit in Premiere Elements V14 instead of Premiere Elements V11?
        • 1. Re: Elements v11 to Premiere Elements v14
          Kamna Yadav Adobe Employee
          Hi Jeff,
          As per my understanding, you've both PRE 11 as well as 14 installed on your machine. By default, if Organizer 11 is used then it would open PRE 11. If you want to use PRE 14, then you can provide the path of the "Adobe Premiere Elements.exe" in the Edit>Preferences>Editing>Use supplementary editing application. This will lead to PRE 14 being used for editing instead of PRE 11.
          Please tell us if that works for you.
          -Kamna
          • 2. Re: Elements v11 to Premiere Elements v14
            Hi Jeff,
            Did you get time to check if the tip helped? If you are satisfied with the answer and your problem has been solved, then can you please mark the question as answered and select the respective answer as Correct Answer as it might help other users in the future if they land on this page for this issue?
            Kamna
