3 Replies Latest reply on Feb 1, 2016 12:18 PM by frameexpert
    XML declaration
    KuddRoww Level 1
      When writing an XML object to file is it possible to include the XML declaration?
      I've tried the toXMLString() function and that doesn't seem to work, I get the XML file contents just fine but no declaration.
      I've tried adding it as a string literal like so (the book object is simple an XML object containing all of the book contents):
      var xmlFile = File(chapterFolder+app.activeDocument.name.replace(".indd","")+".xml");
      xmlFile.open('w');
      xmlFile.encoding = 'UTF-8';
      xmlFile.write("""<?xml version="1.0" encoding="UTF-8"?>"""+"\r"+book.toXMLString());
      xmlFile.close();
      Is there a property I'm missing that would allow me to have the declaration included automatically?
      Cheers,
      Kurtis
        • 1. Re: XML declaration
          frameexpert Level 4
          Hi Kurtis,
          Is it an ExtendScript XML object? I am able to do this in one of my scripts and get the declaration:
          var settingsXML = <settings><test-element>Element text</test-element></settings>;
          saveSettingsFile (settingsXML);
          function saveSettingsFile (settingsXML) {
              var settingsFile = File ($.fileName.replace (/\.jsx(?:bin)?$/i , ".xml"));
              settingsFile.open ("w");
              settingsFile.write ("<?xml version='1.0'?>\r" + settingsXML);
              settingsFile.close ();
          This script give me this result:
          <settings>
          </settings>
          -Rick
          • 2. Re: XML declaration
            KuddRoww Level 1
            Thanks for testing! That works. I didn't realize that I'm outputting two XML files, one with a file name including date and one without. I was testing the code against the one and checking the other. Thanks for taking the time to test and respond to this.
            • 3. Re: XML declaration
              frameexpert Level 4
              My pleasure. Thanks for marking it Correct!
