3 Replies Latest reply on Jul 28, 2017 10:18 AM by philipw15367395
    Unable to publish
    Patty K Breeze Level 1
      I am using Windows 10 and PPT 2016, and just installed Presenter 11 on my own personal computer. I am getting a message that Adobe Presenter is unable to publish this presentation, that I should check if there is enough disk space (there is plenty) and check if I have appropriate permissions to the folder. I own this computer - there is not other owner or admin. This program is so frustrating.
      What else should can I check to get this to work?
      Patty
        • 1. Re: Unable to publish
          So, after many hours of trying to get Presenter 11 to publish, and 2 hours online with Adobe support in India, I was finally informed that Adobe is aware of compatibility issues between PPT 2016 and Presenter 11. I have canceled that subscription since I am not able to use it, and Adobe could not tell me when that issue might be resolved.
          My question to Adobe is: how will I know when it is resolved, especially since I haven't seen anything published about the incompatibility problem?
          • 2. Re: Unable to publish
            Mr. JP
            This is the second post I have read which I am having the same issue but, I am using Windows 7 and Office 2010.
            Adobe has not answered the previous post either.
            Presenter 8.1 worked fine. Now upgraded to version 11 having nothing but problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
            • 3. Re: Unable to publish
              philipw15367395 Level 1
              I have been having the same issues with Presenter 11 error "unable to publish..." It happened in Windows 7 and continued when I upgraded to Windows 10 with a clean install. I've tried all the clearing the Windows temp folders and creating a new user which did not work for me - only recreating the file from scratch worked. The below solution has worked for me on one PowerPoint.
              Solution: Change PowerPoint saving format (not file type)
              Go to PowerPoint Options --> Save --> Save presentations --> Save files in this format -->
              Select  "Open Document Presentation" from the drop-down. Files still appear to save with a PPTX extension (instead of .odp)
