1 Reply Latest reply on Feb 1, 2016 2:58 PM by try67
    Will not let me highlight a pdf.
    chriss57182522
      Using Acrobat Adobe Pro.  Downloaded a pdf that I need to mark up and the highlighter will not work.  Had problem before and was able to correct but not now.
        • 1. Re: Will not let me highlight a pdf.
          You can only use the highlighter tool on real text, not text that's inside an image. If you can't use this tool then switch to something like the Square tool and you'll be able to use it anywhere. You can set its properties so it looks just like a highlight, using a yellow, semi-transparent fill color.
