7 Replies Latest reply on Feb 3, 2016 1:25 PM by Szalam
    Cinema4D errors
    gletiecq
      Cinema4D providing the following error message when opening an After Effects Project with a Cinema4D file.  Started happening immediately following the latest update.
      AEGP Plugnin CINEWARE scenelayer: CINERENDER-Connection Failure ( 5027:: 12 )
      Computer information:
      Windows 7 Professional (64 bit) SP1
      Intel i7-4930, 24GB, SSD w/WEI=7.8
      Windows Log Information:
      Faulting application name: CineRenderAE.exe, version: 17.0.4.7, time stamp: 0x5645e986
      Faulting module name: CineRenderAE.exe, version: 17.0.4.7, time stamp: 0x5645e986
      Exception code: 0xc0000005
      Fault offset: 0x0000000000656f63
      Faulting process id: 0x984
      Faulting application start time: 0x01d15d3582355083
      Faulting application path: C:\Program Files\Adobe\Adobe After Effects CC 2015\Support Files\Plug-ins\MAXON CINEWARE AE\(CINEWARE Support)\bin\CineRenderAE.exe
      Faulting module path: C:\Program Files\Adobe\Adobe After Effects CC 2015\Support Files\Plug-ins\MAXON CINEWARE AE\(CINEWARE Support)\bin\CineRenderAE.exe
      Report Id: bfe54678-c928-11e5-be11-74d02b29f520
      Windows WER Report information:
      Version=1
      EventType=APPCRASH
      EventTime=130988342426265614
      ReportType=2
      Consent=1
      UploadTime=130988342426425623
      ReportIdentifier=51aea4ae-c927-11e5-be11-74d02b29f520
      IntegratorReportIdentifier=51aea4ad-c927-11e5-be11-74d02b29f520
      Response.BucketId=143404645
      Response.BucketTable=28
      Response.type=4
      Sig[0].Name=Application Name
      Sig[0].Value=CineRenderAE.exe
      Sig[1].Name=Application Version
      Sig[1].Value=17.0.4.7
      Sig[2].Name=Application Timestamp
      Sig[2].Value=5645e986
      Sig[3].Name=Fault Module Name
      Sig[3].Value=CineRenderAE.exe
      Sig[4].Name=Fault Module Version
      Sig[4].Value=17.0.4.7
      Sig[5].Name=Fault Module Timestamp
      Sig[5].Value=5645e986
      Sig[6].Name=Exception Code
      Sig[6].Value=c0000005
      Sig[7].Name=Exception Offset
      Sig[7].Value=0000000000656f63
      DynamicSig[1].Name=OS Version
      DynamicSig[1].Value=6.1.7601.2.1.0.256.48
      DynamicSig[2].Name=Locale ID
      DynamicSig[2].Value=1033
      DynamicSig[22].Name=Additional Information 1
      DynamicSig[22].Value=ab37
      DynamicSig[23].Name=Additional Information 2
      DynamicSig[23].Value=ab370803e49e26e4241a6e2916394afd
      DynamicSig[24].Name=Additional Information 3
      DynamicSig[24].Value=f4df
      DynamicSig[25].Name=Additional Information 4
      DynamicSig[25].Value=f4df3ce8eede9b0c799df6dabf5512a7
      UI[2]=C:\Program Files\Adobe\Adobe After Effects CC 2015\Support Files\Plug-ins\MAXON CINEWARE AE\(CINEWARE Support)\bin\CineRenderAE.exe
      UI[3]=CineRenderAE has stopped working
      UI[4]=Windows can check online for a solution to the problem.
      UI[5]=Check online for a solution and close the program
      UI[6]=Check online for a solution later and close the program
      UI[7]=Close the program
      LoadedModule[0]=C:\Program Files\Adobe\Adobe After Effects CC 2015\Support Files\Plug-ins\MAXON CINEWARE AE\(CINEWARE Support)\bin\CineRenderAE.exe
      LoadedModule[1]=C:\windows\SYSTEM32\ntdll.dll
      LoadedModule[2]=C:\windows\system32\kernel32.dll
      LoadedModule[3]=C:\windows\system32\KERNELBASE.dll
      LoadedModule[4]=C:\windows\system32\imagehlp.dll
      LoadedModule[5]=C:\windows\system32\msvcrt.dll
      LoadedModule[6]=C:\windows\system32\ADVAPI32.dll
      LoadedModule[7]=C:\windows\SYSTEM32\sechost.dll
      LoadedModule[8]=C:\windows\system32\RPCRT4.dll
      LoadedModule[9]=C:\windows\system32\PSAPI.DLL
      LoadedModule[10]=C:\windows\system32\USER32.dll
      LoadedModule[11]=C:\windows\system32\GDI32.dll
      LoadedModule[12]=C:\windows\system32\LPK.dll
      LoadedModule[13]=C:\windows\system32\USP10.dll
      LoadedModule[14]=C:\windows\system32\SHELL32.dll
      LoadedModule[15]=C:\windows\system32\SHLWAPI.dll
      LoadedModule[16]=C:\windows\system32\ole32.dll
      LoadedModule[17]=C:\windows\system32\OLEAUT32.dll
      LoadedModule[18]=C:\windows\system32\MSVCP120.dll
      LoadedModule[19]=C:\windows\system32\MSVCR120.dll
      LoadedModule[20]=C:\Program Files\Adobe\Adobe After Effects CC 2015\Support Files\libmmd.dll
      LoadedModule[21]=C:\windows\system32\IMM32.DLL
      LoadedModule[22]=C:\windows\system32\MSCTF.dll
      State[0].Key=Transport.DoneStage1
      State[0].Value=1
      State[1].Key=DataRequest
      State[1].Value=Bucket=143404645/nBucketTable=28/nResponse=1/n
      FriendlyEventName=Stopped working
      ConsentKey=APPCRASH
      AppName=CineRenderAE
      AppPath=C:\Program Files\Adobe\Adobe After Effects CC 2015\Support Files\Plug-ins\MAXON CINEWARE AE\(CINEWARE Support)\bin\CineRenderAE.exe
      STEPS TAKEN TO RESOLVE THE PROBLEM THAT HAVE NOT WORKED:
      1     Run After Effects as Administrator
      2     Change TCP Port for Cineware to 5027, Purge Memory & Cache, delete cached files & wipe all temp files using CCleaner
      3     Add Firewall rule to unblock port activity TCP Ports 5027-5030
      4     Reinstall After Effects using Creative Cloud
      5     Remove After Effects with Creative Cloud Cleaner Tool and reinstall
      6     Remove After Effects with Creative Cloud Cleaner Tool, run CCleaner to remove all unused registry keys, and reinstall
      7     Remove all Create Cloud Applications, run CCleaner, manually remove all adobe files from the following locations:
                C:\Program Files\Common Files\Adobe
                C:\Users\<User>\AppData\Local\Adobe
                C:\Users\<User>\AppData\Roaming\Adobe\After Effects (and others)
           and reinstall
      8     Disable Microsoft Security Essentials and Windows Firewall
      9     Remove all creative cloud files using Creative Cloud Cleaner Tool and delete the following:
           C:\Program Files (x86)\Adobe
           C:\Program Files\ProgramData\Adobe
           and reinstall Creative Cloud and After Effects
