5 Replies Latest reply on Feb 2, 2016 1:02 PM by Chetna Srivastava
    Lightroom 5.7.1 incompatible with Mac OS X Yosemite?
    adamw30615061
      Hi, I've just upgraded my Macbook to Mac OS X Yosemite and I can't open Lightroom 5.7.1. It says that I should check if my version of lightroom works with Yosemite. Any idea on how to solve the issue? If the two are incompatible, can I download an updated version of Lightroom? Many thanks!
        • 1. Re: Lightroom 5.7.1 incompatible with Mac OS X Yosemite?
          dj_paige Level 9
          OSX Yosemite (OSX 10.10) is listed as supported under Lightroom system Requirements for Lightroom 5
          System requirements for Photoshop Lightroom for Mac and Windows OS
          • 2. Re: Lightroom 5.7.1 incompatible with Mac OS X Yosemite?
            Chetna Srivastava Adobe Employee
            Hi adamw,
            Lightroom 5 is compatible with Mac Yosemite so, it should work fine.
            Could you please share the screenshot of the exact error message that you get?
            Regards,
            Chetna
            • 3. Re: Lightroom 5.7.1 incompatible with Mac OS X Yosemite?
              99jon Adobe Community Professional & MVP
              After updating OS X it is usually necessary to trash the prefs. Launch Finder and on the menu bar click “Go” whilst holding down the Optn(Alt) key and choose Library. Open the Preferences folder and trash the two plist files relating to LR5 (see image below)
              Then re-launch Lightroom.
              N.B. Apple hides the user Library until the Alt key is depressed.
              • 4. Re: Lightroom 5.7.1 incompatible with Mac OS X Yosemite?
                adamw30615061 Level 1
                I am getting the below when I try to launch
                Process:               Adobe Photoshop Lightroom 5 [1064]
                Path:                  /Applications/Adobe Photoshop Lightroom 5.app/Contents/MacOS/Adobe Photoshop Lightroom 5
                Identifier:            com.adobe.Lightroom5
                Version:               ???
                Code Type:             X86-64 (Native)
                Parent Process:        ??? [1]
                Responsible:           Adobe Photoshop Lightroom 5 [1064]
                User ID:               501
                Date/Time:             2016-02-02 19:21:09.608 +0100
                OS Version:            Mac OS X 10.10.3 (14D136)
                Report Version:        11
                Anonymous UUID:        71B6659F-0DAC-2758-B2F8-596D6FD5162E
                Sleep/Wake UUID:       1BA89692-A175-423D-99A9-BA6A4E34FE61
                Time Awake Since Boot: 6700 seconds
                Time Since Wake:       660 seconds
                Crashed Thread:        0
                Exception Type:        EXC_BREAKPOINT (SIGTRAP)
                Exception Codes:       0x0000000000000002, 0x0000000000000000
                Application Specific Information:
                dyld: launch, loading dependent libraries
                Dyld Error Message:
                  Library not loaded: @executable_path/../Frameworks/asneu.framework/versions/a/asneu
                  Referenced from: /Applications/Adobe Photoshop Lightroom 5.app/Contents/MacOS/Adobe Photoshop Lightroom 5
                  Reason: image not found
                Binary Images:
                    0x7fff6a71a000 -     0x7fff6a750837  dyld (353.2.1) <65DCCB06-339C-3E25-9702-600A28291D0E> /usr/lib/dyld
                    0x7fff8dfbb000 -     0x7fff8eb3cff7  com.apple.AppKit (6.9 - 1347.57) <B214D528-7D1C-39B2-BE36-821D417A0297> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                    0x7fff98875000 -     0x7fff98ba6fff  com.apple.Foundation (6.9 - 1153.20) <F0FF3A5D-C5B7-34A1-9319-DE1EF928E58E> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                Model: MacBookPro8,1, BootROM MBP81.0047.B04, 2 processors, Intel Core i5, 2.3 GHz, 4 GB, SMC 1.68f96
                Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In
                Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
                Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
                AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.98.100.24)
                Bluetooth: Version 4.3.4f4 15601, 3 services, 27 devices, 1 incoming serial ports
                Network Service: AirPort, AirPort, en1
                Serial ATA Device: Hitachi HTS545032B9A302, 320.07 GB
                Serial ATA Device: HL-DT-ST DVDRW  GS31N
                USB Device: Hub
                USB Device: IR Receiver
                USB Device: FaceTime HD Camera (Built-in)
                USB Device: Hub
                USB Device: Apple Internal Keyboard / Trackpad
                USB Device: BRCM2070 Hub
                USB Device: Bluetooth USB Host Controller
                Thunderbolt Bus: MacBook Pro, d.0
                • 5. Re: Lightroom 5.7.1 incompatible with Mac OS X Yosemite?
                  Thank you for sharing the logs.
                  That seems to be a damaged install.
                  Would suggest you to reinstall Lightroom 5 and then, check.
