Have downloaded Adobe Digital Editions to use with my Kobo. I could authorize my computer but when I click on the gear icon and the choices come up to authourize my kobo it does not work. How do I authorize my Kob so I can borrow books form my public library?
Which error message you get exactly?
I have the exact same problem. But I also can't authorize my computer. The message I receive says:
Activation server error. Code: E_AUTH_NOT_READY
Digital Editions encountered an error on the activation server.
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
