1 Reply Latest reply on Feb 3, 2016 4:32 AM by Peter Spier
    Remove a recurring textbox
    samuelf80274044
      I need to remove a recurring textbook that appears on every page in the same position throughout a document. It contains the text "Module 6. Materials and Hardware" and has no object style or paragraph style. It is an overridden master page item.
      I assume that there is a script or something similar in Find and replace that might help but I can't for the life of me figure it out.
      If you to ask questions for more information I'm here.
      Thank you in advance.
      Samuel
        • 1. Re: Remove a recurring textbox
          Are you sure it's overridden? If it is I don't think there's an easy way to deal with it, but if not you could just delete it from the master.
          A really ugly solution would be to add a layer high enough to be in front of the layer holding this frame, then add a [Paper]-filled frame to cover the area on the master page.
