2 Replies Latest reply on Apr 11, 2016 8:28 AM by davitig68807294
    changing the centerpoint for addlight
    davitig68807294
      Using this example code:
      app.project.item(index).layers.addLight(name, centerPoint)
      I created the following test code where I add a light to my second scene (composition) in my project to create a shadow:
      var s2light1 = scene2.layers.addLight("s2light1", [1143,121]);
      This works perfectly. But I now also want to set the 3rd (Z) value for the centerPoint in Extendscript (as is possible in After Effects).
      However according to the After Effects CS6 scripting guide it seems you can only set the X and Y values: "The center of the new camera, a floating-point array [x, y]. This is used to set the initial x and y values of the new camera’s Point of Interest property. The z value is set to 0." Is there another approach or work around to set the Z-value for the center point in Extendscript which I can try?
      Many thanks.
      Daviti Gokadze
      [ email signature removed - see http://forums.adobe.com/docs/DOC-3731 ]
