2 Replies Latest reply on Feb 3, 2016 1:55 PM by jjmirro
    No Histogram in Camera RAW 9.3.1
    jjmirro
      I am using Adobe Camera RAW 9.3.1.  The histogram is missing from the top right of the panel.  How do I get it there?  Thanks
        • 1. Re: No Histogram in Camera RAW 9.3.1
          ssprengel Adobe Community Professional & MVP
          Is there a gray box where the histogram should be or is the row of tabs that is normally below the histogram right along the top right?  I don't know of any way to hide the histogram so if that section is just gone maybe something is corrupted in the plug-in resource files and a reinstall could fix it.  If the there is a gray box instead of an active histogram maybe something is wrong with the GPU/video-drivers and you should try disabling it at the bottom of the Ctrl-K ACR preferences.
          ACR 9.4 is the current version so try installing that to see if things start working.
          • 2. Re: No Histogram in Camera RAW 9.3.1
            jjmirro Level 1
            I installed the new version, 9.4, and that didn't work.  Then I turned off the GPU/video-drivers and that worked.  Thanks.
