3 Replies Latest reply on Feb 4, 2016 6:23 AM by Szalam
    After Effects -- 13.7 -- extremely slow updated in Composition view when scrubbing
    nicknameforme Level 1
      I am getting extremely poor performance on my Windows 10 (Skylake - 32GB Ram) computer with After Effects.
      I have a composition which primarily consists of about 1000 sequential HD resolution frames and it will often not update the composition view for 10, 20 or even 30+ seconds when I scrub the timeline.  I have worked with similar compositions before and have never seen such sluggish or strange behavior. Sometimes the composition window is just blank for a while before I even see a frame when I first load the project.  This is not a complex composition.  It's just a few layers with minimal effects (nothing 3d).  The RAM is not filled up on my computer either.  It says I have 18 GB free.
      This slow behavior was true on the previous version of After Effects too -- not just 13.7.
      What is going on?
      I thought After Effects had recently been given a re-engineered core designed for speed.  This is the worst responsiveness I have ever seen, no exaggeration, with any version of After Effects dating back to CS 6 or even earlier.
        • 1. Re: After Effects -- 13.7 -- extremely slow updated in Composition view when scrubbing
          It's actually in the middle of being worked on. CC 2015 is just a partly done version of it. Some people are having great success with it. While other people...not so much.
          Do you have CC 2014 on your machine? If not, get it and see how it behaves. How to Find and Install Previous Version of Adobe Apps in CC 2015
          What format are these frames? Where do they reside (local hard drive, NAS, RAID, etc.)?
          What effects are in use?
          Is this a project you've built yourself?
          When you're scrubbing, you say the RAM isn't filled up, but how do your CPU's look? If anything, I would expect to see one core spiking if it's a CPU issue. But if none of them are, the issue resides somewhere else.
          Wait, quick question: is your comp accidently set to use the ray-traced renderer?
          • 2. Re: After Effects -- 13.7 -- extremely slow updated in Composition view when scrubbing
            Thank you for your response.   You are asking astute questions.
            Effects in use are a photo filter, a few Set Mattes and a timer (all stuff I normally use without issue).  I don't think it's effects-related because even if I just load the raw frames in the viewer (by double-clicking the PNG footage entry in the Project panel) it's still slow.
            The files are PNGs (what I always use) and stored on an NAS (as always).  As I said, this job is not unlike hundreds of others I've done in the past in terms of it's specifics.  The project was built myself.  CPU utilization does not seem to respond much at all during scrubbing as seen in the Task manager.  Incidentally, video card is nvidia Geforce 980 Ti.
            Raytrace is not on.
            I will try CC 2014.  That's a good idea. Hopefully it will be more responsive because right now 2015 is basically unusable.
            • 3. Re: After Effects -- 13.7 -- extremely slow updated in Composition view when scrubbing
              Out of curiosity, could you try bringing files onto your local drive instead of the NAS and see if CC 2015 behaves as expected that way?
              Also, let us know if CC 2014 behaves itself with both the local files and the NAS files.
