4 Replies Latest reply on Nov 23, 2017 5:47 AM by llpilch
    Can't turn off GPU acceleration
    Bongboots
      I have tried GPU acceleration in the past, but it wasn't enabled for my Radeon HD 6950. Ironically, today I found it was, and turned it on. LR was soon freezing in the Develop module, so I went to Preferences to turn it off again. I've tried several times, but it doesn't uncheck, just freezes! I tried rebooting, but freezes again while trying. Is the only way to delete the Preferences file, and if so, where is it?
      Bruce
      Lightroom version: CC 2015.4 [ 1060496 ]
      License: Creative Cloud
      Operating system: Windows 7
      Version: 6.1
      Application architecture: x64
      System architecture: x64
      Logical processor count: 4
      Processor speed: 3.3 GHz
      Built-in memory: 8172.1 MB
      Real memory available to Lightroom: 8172.1 MB
      Real memory used by Lightroom: 457.8 MB (5.6%)
      Virtual memory used by Lightroom: 436.5 MB
      Memory cache size: 373.9 MB
      Maximum thread count used by Camera Raw: 4
      Camera Raw SIMD optimization: SSE2,AVX
      System DPI setting: 96 DPI
      Desktop composition enabled: Yes
      Displays: 1) 1920x1200, 2) 1280x1024
      Input types: Multitouch: No, Integrated touch: No, Integrated pen: No, External touch: No, External pen: No, Keyboard: No
      Graphics Processor Info:
      AMD Radeon HD 6900 Series
      Check OpenGL support: Passed
      Vendor: ATI Technologies Inc.
      Version: 3.3.13399 Core Profile Context 15.200.1062.1004
      Renderer: AMD Radeon HD 6900 Series
      LanguageVersion: 4.40
      Application folder: C:\Program Files\Adobe\Adobe Lightroom
      Library Path: F:\Pictures\Lightroom\Lightroom Catalog.lrcat
      Settings Folder: C:\Users\Bruce\AppData\Roaming\Adobe\Lightroom
      Installed Plugins:
      1) Facebook
      2) Flickr
      Config.lua flags: None
      Adapter #1: Vendor : 1002
          Device : 6719
          Subsystem : 23071787
          Revision : 0
          Video Memory : 2032
      AudioDeviceIOBlockSize: 1024
      AudioDeviceName: Realtek Digital Output(Optical) (Realtek High Definition Audio)
      AudioDeviceNumberOfChannels: 2
      AudioDeviceSampleRate: 44100
      Build: LR5x102
      Direct2DEnabled: false
      GPUDevice: not available
      OGLEnabled: true
        • 1. Re: Can't turn off GPU acceleration
          Mohit Goyal Adobe Employee (Admin)
          Hi Bongboots,
          Please Follow the Solution below
          1. Go To Edit>>Preference>>Performance>>Uncheck "Use Graphics Processor"  If this does not solves the issue then,
          2. With Lightroom closed
          • Navigate to
              C:\Users\YourUserName\AppData\Roaming\Adobe\Lightroom\Preferences    (Where AppData is a hidden/system folder so you may need to enter the folder name directly into your Explorer address bar or enable hidden/system folders in Explorer folder view options.)
          • Open the file LightroomPreferences.agprefs
          • Search for the line Use autobahn=True(Press CTRL+F)
          • Change it to Use Autobahn=False
          Once Done save the File
          Restart Lightroom
             3. Also refer this link and update Graphics Processor if you use AMD card
          Adobe Photoshop Lightroom Help | Issues with Lightroom CC/Lightroom 6 and AMD graphics cards | Win
          Let us know if that helps
          Regards,
          Mohit
          • 2. Re: Can't turn off GPU acceleration
            Bongboots Level 1
            Many thanks for the quick reply Mohit. That did the trick. I may try the 15.8 Beta drivers sometime, but for now will use it with GPU acceleration off! AMD seem to have stopped writing new drivers for the HD 6950.
            Regards,
            Bruce
            • 3. Re: Can't turn off GPU acceleration
              Your Welcome.
              Mohit
              • 4. Re: Can't turn off GPU acceleration
                llpilch
                I'm having the same problem, but now with Lightroom Classic CC.
                I always managed to turn the GPU acceleration OFF changing "true" to "false" in "UseAutoBahn" line at preferences file in older versions of Lightroom CC (i think it was Lightroom CC 2015 that I was using before), but now in Lightroom Classic CC I can't! After starting LR, it shows again the tips like it was the first time I'm openning it and then turns the GPU acceleration on again.
                I edit the file always after restarting the computer so the preferences file is not already loaded in the computer memorylr.png
                When will adobe fix this problem? it is an known issue even in older versions, why this damn option is not turned off by default? Why the software chashes when we try to disable it? PLEASE adobe, fix it.
