3 Replies Latest reply on Mar 7, 2009 2:54 AM by Newsgroup_User
    V12 DB xtra Version 3
    Level 7
      Ok, I'm officially at the pulling hair out point in my project.
      I have found that the fileXtra4 method "fx_volumeIsCDROM" doesn't recognize
      the CD drive when a CD is mounted. I'm running 10.3.9 in Director MX. So I
      compromised and used "fx_volumeIsRemovable" which returned the proper value
      and I thought my problem was solved. Now a tester who is running 10.5.x
      gets a handler not defined error for that call. The xtras folder has the
      carbon and non-carbon version of the xtra in it. Any ideas why this is
      happening?
      Craig S. Wollman
      Word of Mouth Productions
      159-00 Riverside Drive West
      New York, New York 10032
      (212) 928-9581
        • 1. Re: V12 DB xtra Version 3
          Level 7
          Oops. Subject should have read "fileXtra4"
          Craig S. Wollman
          (212) 928-9581
          "WOMP" <craig@wordofmo.com> wrote in message
          news:gosfqm$a7k$1@forums.macromedia.com...
          > recognize the CD drive when a CD is mounted. I'm running 10.3.9 in
          > Director MX. So I compromised and used "fx_volumeIsRemovable" which
          > returned the proper value and I thought my problem was solved. Now a
          > tester who is running 10.5.x gets a handler not defined error for that
          > call. The xtras folder has the carbon and non-carbon version of the xtra
          > in it. Any ideas why this is happening?
          > Craig S. Wollman
          > (212) 928-9581
          • 2. Re: FileXtra4
            Level 7
            Presumably it runs in Rosetta then.
            Do you mean a version for OS9 and another for OSX?
            Do you check the xtra instance after creation:
            fx4 = xtra("FileXtra4").new()
            if ( ilk(fx4, #instance) = 0 ) then
            alert "Xtra instantiation failed"
            exit
            end if
            • 3. Re: FileXtra4
              Level 7
              The extra is definitely there that's how I get the disk list and there's no
              error there.
              Craig S. Wollman
              (212) 928-9581
              "Sean Wilson" <webforumsuser@macromedia.com> wrote in message
              news:got4ot$3gn$1@forums.macromedia.com...
              >> Now a tester who is running 10.5.x gets a handler not defined error for
              >> that call.
              >> The xtras folder has the carbon and non-carbon version of the xtra in it.
              > exit
              > end if
