creative cloud packager in not creating a package that I can install. It goes through the motions, downloads all the updates, creates the installer file but it doesnt work despite there being no errors in the log files
After banging my head against the desk at repeatedly creating packages, trying on different computers I've finally found a fix.
These packages were copied to an external drive, if I try and install them from the external drive, which is standard practice it fails.
If I then copy that pkg file from the External, to the computer I'm installing it on, then run it, it go's and installs fine.
Which is mind boggling stupid, because it's rare that you should have to copy the file to any computer, it's at
...Copy link to clipboard
I've got the same problem here.
I created new packages on a new machine and it's still not letting me install.
Can you indicate the platform (mac/win) you are on and the method you are using to install? Are there any errors, does it roll back? What is in your package?
On OS X for me.
What is the method you are using to install? Are there any errors, does it roll back? What is in your package?
Can you try with a new admin account?
Double click the pkg installer.
It's happened before, it will create all the packages fine, but some just refuse to install, can clear cache in the CCP Manager, re-create all the packages and still have problems.
It's doesn't install on a existing computer, so I went and tried on a fresh iMac with no Adobe products on it, exact same thing.
Below is my PDApp.log from the install.
It failed on a full installer where I selected all the Adobe products, so I re-created individual packages.
There's parts of the PDApp.log where it complains about the machine having a newer version, which is nonsense because it's a fresh, brand new install I did on an iMac. And the package was created on an iMac that was also fresh, no previous Adobe products, and using the latest Adobe CCP.
02/04/16 11:13:03:929 | [INFO] | | ASU | OPM | OPM | | | 6666 | Build Version - 9.0.0.78
02/04/16 11:13:03:929 | [INFO] | | ASU | OPM | OPM | | | 6666 | Logging Level verbosity Set to 4
02/04/16 11:13:03:996 | [INFO] | | ASU | OPM | OPM | | | 6666 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
02/04/16 11:13:03:996 | [INFO] | | ASU | OPM | OPM | | | 6666 | No Record found for the input fields in opm_getValueForKey
02/04/16 11:13:03:996 | [INFO] | | ASU | OPM | OPM | | | 6666 | Released OPM refrence successfully in opm_freeLibRef
02/05/16 10:57:10:628 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Build Version - 1.9.3.56
02/05/16 10:57:10:639 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Logging Level verbosity Set to 4
02/05/16 10:57:10:639 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | The following parameters are passed to Adobe Deployment Manager.
02/05/16 10:57:10:639 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/AdobeDeploymentManager --optXMLPath=/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/optionXML.xml --setupBasePath=/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ --installDirPath=/ --installLanguage= --mode=install
02/05/16 10:57:10:639 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Obtained root as installDirPath, so resetting it to blank.
02/05/16 10:57:10:640 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Build Version - 1.9.3.56
02/05/16 10:57:10:640 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Logging Level verbosity Set to 4
02/05/16 10:57:10:640 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | CustomAction Parameters obtained...
02/05/16 10:57:10:640 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | optXMLPath :: /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/optionXML.xml
02/05/16 10:57:10:640 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | setupBasePath :: /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/
02/05/16 10:57:10:640 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | installDirPath ::
02/05/16 10:57:10:640 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | installLang ::
02/05/16 10:57:10:640 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Initializing Custom Action Data from parameters
02/05/16 10:57:10:640 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Provisioning Tool path is (/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources///ProvisioningTool/adobe_prtk).
02/05/16 10:57:10:640 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Starting to run the custom action for install mode
02/05/16 10:57:10:643 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | STEP 1: Starting to parse Option XML.
02/05/16 10:57:11:101 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Install language fallback contains following languages :
02/05/16 10:57:11:101 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | (en_GB)
02/05/16 10:57:11:103 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | RemoteUpdateManager deploy Path doesn't exist.
02/05/16 10:57:11:103 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | No of updates found (2).
02/05/16 10:57:11:120 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Number of Medias found = 1
02/05/16 10:57:11:120 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Deployment Manager is running in Install Mode.
02/05/16 10:57:11:143 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Deployment XML created at path :: /tmp/A6FD7F7B-F6CF-4BDF-8457-0B1542DB98DA//EF9DE6F1-7F90-45CF-B39D-C342232441D8
02/05/16 10:57:11:182 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Override XML created at path :: /tmp/A6FD7F7B-F6CF-4BDF-8457-0B1542DB98DA//B4530E28-730A-4A83-8311-B32402F27C51
02/05/16 10:57:11:349 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Failed to find the pdb database.
02/05/16 10:57:11:350 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Failed to get the local payload database handle.
02/05/16 10:57:11:350 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | STEP 2: Starting to launch ASU AAM.
02/05/16 10:57:11:350 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Bootstrapper launch location is :: /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources//ASU/Install.dylib/Contents/MacOS/Install
02/05/16 10:57:21:637 | [INFO] | | ASU | AAMCustomHook | AAMCustomHook | | | 130185 | Build Version - 9.0.0.244
02/05/16 10:57:21:637 | [INFO] | | ASU | AAMCustomHook | AAMCustomHook | | | 130185 | Logging Level verbosity Set to 4
02/05/16 10:57:21:637 | [INFO] | | ASU | AAMCustomHook | | | CommandLineParser | 130185 | Parsing the command line provided. Number of command line arguments is 3
02/05/16 10:57:21:643 | [INFO] | | ASU | AAMCustomHook | Native-Utils | | | 130185 | utilBackupFolderIfExits pathToBkp /Library/Application Support/Adobe/OOBE/PDApp
02/05/16 10:57:21:643 | [INFO] | | ASU | AAMCustomHook | Native-Utils | | | 130185 | NOTE trying to backup ... Source path does not exits. So Success.
02/05/16 10:57:21:643 | [INFO] | | ASU | AAMCustomHook | Native-Utils | | | 130185 | Creating symbolic link of /Applications/Utilities/Adobe Application Manager/ to folder /Library/Application Support/Adobe/OOBE/PDApp
02/05/16 10:57:21:709 | [INFO] | | ASU | AAMCustomHook | AAMCustomHook | | | 130185 | Updater Inventory location: '/Applications/Utilities/Adobe Application Manager//UWA/UpdaterInventory.framework/Versions/A/UpdaterInventory'
02/05/16 10:57:21:732 | [INFO] | | ASU | AAMCustomHook | AAMCustomHook | | | 130185 | Going to create or update inventory
02/05/16 10:57:21:883 | [INFO] | | ASU | AAMCustomHook | AAMCustomHook | | | 130185 | Successfully created or updated updater inventory
02/05/16 10:57:42:291 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Build Version - 1.9.3.56
02/05/16 10:57:42:304 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Logging Level verbosity Set to 4
02/05/16 10:57:42:304 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | The return code from the Bootstrapper Process is (0).
02/05/16 10:57:42:304 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Starting apply CCP ASU.
02/05/16 10:57:42:304 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Bootstrapper launch location is :: /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources//ASU2/Install.dylib/Contents/MacOS/Install
02/05/16 10:57:42:669 | [INFO] | | ASU | Setup | Setup | | | 130477 | Build Version - 9.0.0.184
02/05/16 10:57:42:669 | [INFO] | | ASU | Setup | Setup | | | 130477 | Logging Level verbosity Set to 4
02/05/16 10:57:42:673 | [INFO] | | ASU | Setup | Setup | | | 130477 | TimeLog: Bootstrapper Start
02/05/16 10:57:42:673 | [INFO] | | ASU | Setup | Setup | | | 130477 | Action specified - "install"
02/05/16 10:57:42:673 | [INFO] | | ASU | Setup | | | | 130477 | Event Guid generated is: 'ad365678-9059-4f8b-9228-0e4450447951'
02/05/16 10:57:42:710 | [INFO] | | ASU | Setup | | | | 130485 | Event with guid 'ad365678-9059-4f8b-9228-0e4450447951' is being sent
02/05/16 10:57:42:720 | [INFO] | | ASU | Setup | Setup | | | 130477 | Launch Path set to /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2
02/05/16 10:57:42:809 | [INFO] | | ASU | PIM | PIM | | | 130477 | Build Version - 9.0.0.184
02/05/16 10:57:42:809 | [INFO] | | ASU | PIM | PIM | | | 130477 | Logging Level verbosity Set to 4
02/05/16 10:57:42:811 | [INFO] | | ASU | PIM | PIM | | | 130477 | Build Version - 9.0.0.184
02/05/16 10:57:42:811 | [INFO] | | ASU | PIM | PIM | | | 130477 | Logging Level verbosity Set to 4
02/05/16 10:57:42:811 | [INFO] | | ASU | PIM | PIM | | | 130477 | CREATE PIM Instance ...
02/05/16 10:57:42:846 | [INFO] | | ASU | PIM | PIM | | | 130477 | trying to createOrUpdatePIMDbSchema.
02/05/16 10:57:42:850 | [INFO] | | ASU | PIM | PIM | | | 130477 | Current db schema version on machine 4.
02/05/16 10:57:42:850 | [INFO] | | ASU | PIM | PIM | | | 130477 | Current db schema version to install 1.
02/05/16 10:57:42:850 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS Created Tables.
02/05/16 10:57:42:850 | [INFO] | | ASU | PIM | PIM | | | 130477 | PIM Database is Up To Date.
02/05/16 10:57:42:850 | [INFO] | | ASU | PIM | PIM | | | 130477 | Updater Inventory location:/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/Install.dylib/Contents/Frameworks/UpdaterInventory.framework/Versions/A/UpdaterInventory
02/05/16 10:57:42:901 | [INFO] | | ASU | PIM | PIM | | | 130477 | Acquired System level ACF lock ...
02/05/16 10:57:42:902 | [INFO] | | ASU | Setup | Setup | | | 130477 | TimeLog: Begin Installing
02/05/16 10:57:42:904 | [INFO] | | ASU | PIM | PIM | | | 130477 | Current OS version is: Major:10, Minor:10, ServicePack:4
02/05/16 10:57:43:013 | [INFO] | | ASU | PIM | PIM | | | 130477 | Package id 5F8B53A5-E6B4-4BA8-9139-3BCE8DE0F7CF is a Old Package, a newer package is installed in the system.
02/05/16 10:57:43:073 | [INFO] | | ASU | PIM | PIM | | | 130477 | Package id D2BEE4E6-7F8D-4D56-95FB-EF2E323D7521 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:43:146 | [INFO] | | ASU | PIM | PIM | | | 130477 | Package id 7F9A6906-6DBE-4B91-9BCC-840C9D0DD4B0 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:43:190 | [INFO] | | ASU | PIM | PIM | | | 130477 | Package id C8669E45-094E-43C7-AB3A-9AA778A76A17 is already installed
02/05/16 10:57:43:256 | [INFO] | | ASU | PIM | PIM | | | 130477 | Package id A078B261-F7EE-413F-9A03-D2F11B1C9D09 is already installed
02/05/16 10:57:43:329 | [INFO] | | ASU | PIM | PIM | | | 130477 | Package id 18B0AB1D-6DD9-4A02-82B9-8F73314B8C7A is already installed
02/05/16 10:57:43:453 | [INFO] | | ASU | PIM | PIM | | | 130477 | Package id 8C84A523-9AA0-4666-AB68-E07F0D24E801 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:43:509 | [INFO] | | ASU | PIM | PIM | | | 130477 | Package id 620D01DC-8077-4EBD-B378-2F18D2C73C27 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:43:569 | [INFO] | | ASU | PIM | PIM | | | 130477 | Package id 8455F192-5177-4596-A3D6-22513B70446B is a Old Package, a newer package is installed in the system.
02/05/16 10:57:43:604 | [INFO] | | ASU | PIM | PIM | | | 130477 | Package id 34D302AC-6A5F-4474-8404-60895A6BD0B7 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:43:609 | [INFO] | | ASU | PIM | PIM | | | 130477 | Package id 7BB10B61-3967-4CCD-A75C-6FD0F67F30C8 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:43:609 | [INFO] | | ASU | PIM | PIM | | | 130477 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 19626643
02/05/16 10:57:43:609 | [INFO] | | ASU | PIM | PIM | | | 130477 | freeDiskSpace ... 480372916224
02/05/16 10:57:43:609 | [INFO] | | ASU | PIM | PIM | | | 130477 | Executing Adobe Genuine Validation for all the AAM packages
02/05/16 10:57:43:609 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/core/PDApp.pimx'
02/05/16 10:57:43:622 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/core/PDApp.pima'
02/05/16 10:57:43:637 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/D6/D6.pimx'
02/05/16 10:57:43:643 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/D6/D6.pima'
02/05/16 10:57:43:657 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/DECore/DECore.pimx'
02/05/16 10:57:43:664 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/DECore/DECore.pima'
02/05/16 10:57:43:699 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/DWA/DWA.pimx'
02/05/16 10:57:43:703 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/DWA/DWA.pima'
02/05/16 10:57:43:720 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/P6/P6.pimx'
02/05/16 10:57:43:725 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/P6/P6.pima'
02/05/16 10:57:43:766 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/LWA/LWA.pimx'
02/05/16 10:57:43:771 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/LWA/LWA.pima'
02/05/16 10:57:43:805 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/UWA/UWA.pimx'
02/05/16 10:57:43:814 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/UWA/UWA.pima'
02/05/16 10:57:43:853 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/CCM/CCM.pimx'
02/05/16 10:57:43:859 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/CCM/CCM.pima'
02/05/16 10:57:43:892 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/P7/P7.pimx'
02/05/16 10:57:43:898 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/P7/P7.pima'
02/05/16 10:57:43:952 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/IPC/IPC.pimx'
02/05/16 10:57:43:956 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/IPC/IPC.pima'
02/05/16 10:57:43:965 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/AdobeGCClient/AdobeGCClient.pimx'
02/05/16 10:57:43:968 | [INFO] | | ASU | PIM | PIM | | | 130477 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/AdobeGCClient/AdobeGCClient.pima'
02/05/16 10:57:43:991 | [INFO] | | ASU | PIM | PIM | | | 130477 | Adobe Genuine Validation PASSED for all the AAM packages
02/05/16 10:57:43:991 | [INFO] | | ASU | PIM | PIM | | | 130477 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/core/PDApp.pimx
02/05/16 10:57:44:079 | [INFO] | | ASU | PIM | PIM | | | 130477 | NOTE package id 5F8B53A5-E6B4-4BA8-9139-3BCE8DE0F7CF is a Old Package, a newer package is installed in the system.
02/05/16 10:57:44:084 | [INFO] | | ASU | PIM | PIM | | | 130477 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/D6/D6.pimx
02/05/16 10:57:44:136 | [INFO] | | ASU | PIM | PIM | | | 130477 | NOTE package id D2BEE4E6-7F8D-4D56-95FB-EF2E323D7521 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:44:139 | [INFO] | | ASU | PIM | PIM | | | 130477 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/DECore/DECore.pimx
02/05/16 10:57:44:192 | [INFO] | | ASU | PIM | PIM | | | 130477 | NOTE package id 7F9A6906-6DBE-4B91-9BCC-840C9D0DD4B0 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:44:195 | [INFO] | | ASU | PIM | PIM | | | 130477 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/DWA/DWA.pimx
02/05/16 10:57:44:218 | [INFO] | | ASU | PIM | PIM | | | 130477 | Package id C8669E45-094E-43C7-AB3A-9AA778A76A17 is already installed
02/05/16 10:57:44:228 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS deleteAppletRegInfoRecords.
02/05/16 10:57:44:324 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS deletePackageUpgradeInfoRecords.
02/05/16 10:57:44:324 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS deletePackageInstallationInfoRecords.
02/05/16 10:57:44:380 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS insertPackageUpdateList.
02/05/16 10:57:44:384 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS insertAppletRegInfoList.
02/05/16 10:57:44:388 | [INFO] | | ASU | PIM | Native-Utils | | | 130477 | utilBackupFolderIfExits pathToBkp /Applications/Utilities/Adobe Application Manager/DWA
02/05/16 10:57:44:541 | [INFO] | | ASU | PIM | Native-Utils | | | 130477 | Backup folder path '/Applications/Utilities/Adobe Application Manager//DWA_bkp1'
02/05/16 10:57:44:717 | [INFO] | | ASU | PIM | PIM | | | 130477 | Trying to delete back up folder '/Applications/Utilities/Adobe Application Manager//DWA_bkp1'
02/05/16 10:57:45:304 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/DWA/DWA.pimx.
02/05/16 10:57:45:308 | [INFO] | | ASU | PIM | PIM | | | 130477 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/P6/P6.pimx
02/05/16 10:57:45:347 | [INFO] | | ASU | PIM | PIM | | | 130477 | Package id A078B261-F7EE-413F-9A03-D2F11B1C9D09 is already installed
02/05/16 10:57:45:396 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS deleteAppletRegInfoRecords.
02/05/16 10:57:45:510 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS deletePackageUpgradeInfoRecords.
02/05/16 10:57:45:510 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS deletePackageInstallationInfoRecords.
02/05/16 10:57:45:593 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS insertPackageUpdateList.
02/05/16 10:57:45:599 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS insertAppletRegInfoList.
02/05/16 10:57:45:605 | [INFO] | | ASU | PIM | Native-Utils | | | 130477 | utilBackupFolderIfExits pathToBkp /Applications/Utilities/Adobe Application Manager/P6
02/05/16 10:57:45:753 | [INFO] | | ASU | PIM | Native-Utils | | | 130477 | Backup folder path '/Applications/Utilities/Adobe Application Manager//P6_bkp1'
02/05/16 10:57:46:298 | [INFO] | | ASU | PIM | PIM | | | 130477 | Trying to delete back up folder '/Applications/Utilities/Adobe Application Manager//P6_bkp1'
02/05/16 10:57:46:560 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/P6/P6.pimx.
02/05/16 10:57:46:564 | [INFO] | | ASU | PIM | PIM | | | 130477 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/LWA/LWA.pimx
02/05/16 10:57:46:587 | [INFO] | | ASU | PIM | PIM | | | 130477 | Package id 18B0AB1D-6DD9-4A02-82B9-8F73314B8C7A is already installed
02/05/16 10:57:46:597 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS deleteAppletRegInfoRecords.
02/05/16 10:57:46:673 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS deletePackageUpgradeInfoRecords.
02/05/16 10:57:46:673 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS deletePackageInstallationInfoRecords.
02/05/16 10:57:46:727 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS insertPackageUpdateList.
02/05/16 10:57:46:731 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS insertAppletRegInfoList.
02/05/16 10:57:46:734 | [INFO] | | ASU | PIM | Native-Utils | | | 130477 | utilBackupFolderIfExits pathToBkp /Applications/Utilities/Adobe Application Manager/LWA
02/05/16 10:57:46:887 | [INFO] | | ASU | PIM | Native-Utils | | | 130477 | Backup folder path '/Applications/Utilities/Adobe Application Manager//LWA_bkp1'
02/05/16 10:57:47:500 | [INFO] | | ASU | PIM | PIM | | | 130477 | Trying to delete back up folder '/Applications/Utilities/Adobe Application Manager//LWA_bkp1'
02/05/16 10:57:47:803 | [INFO] | | ASU | PIM | PIM | | | 130477 | SUCCESS installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/LWA/LWA.pimx.
02/05/16 10:57:47:808 | [INFO] | | ASU | PIM | PIM | | | 130477 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/UWA/UWA.pimx
02/05/16 10:57:47:875 | [INFO] | | ASU | PIM | PIM | | | 130477 | NOTE package id 8C84A523-9AA0-4666-AB68-E07F0D24E801 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:47:879 | [INFO] | | ASU | PIM | PIM | | | 130477 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/CCM/CCM.pimx
02/05/16 10:57:47:912 | [INFO] | | ASU | PIM | PIM | | | 130477 | NOTE package id 620D01DC-8077-4EBD-B378-2F18D2C73C27 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:47:914 | [INFO] | | ASU | PIM | PIM | | | 130477 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/P7/P7.pimx
02/05/16 10:57:47:951 | [INFO] | | ASU | PIM | PIM | | | 130477 | NOTE package id 8455F192-5177-4596-A3D6-22513B70446B is a Old Package, a newer package is installed in the system.
02/05/16 10:57:47:953 | [INFO] | | ASU | PIM | PIM | | | 130477 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/IPC/IPC.pimx
02/05/16 10:57:47:968 | [INFO] | | ASU | PIM | PIM | | | 130477 | NOTE package id 34D302AC-6A5F-4474-8404-60895A6BD0B7 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:47:969 | [INFO] | | ASU | PIM | PIM | | | 130477 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/ASU2/packages/AdobeGCClient/AdobeGCClient.pimx
02/05/16 10:57:47:971 | [INFO] | | ASU | PIM | PIM | | | 130477 | NOTE package id 7BB10B61-3967-4CCD-A75C-6FD0F67F30C8 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:47:971 | [INFO] | | ASU | PIM | Native-Utils | | | 130477 | utilBackupFolderIfExits pathToBkp /Library/Application Support/Adobe/OOBE/PDApp
02/05/16 10:57:47:971 | [INFO] | | ASU | PIM | Native-Utils | | | 130477 | Backup folder path '/Library/Application Support/Adobe/OOBE//PDApp_bkp1'
02/05/16 10:57:47:972 | [INFO] | | ASU | PIM | Native-Utils | | | 130477 | Creating symbolic link of /Applications/Utilities/Adobe Application Manager/ to folder /Library/Application Support/Adobe/OOBE/PDApp
02/05/16 10:57:47:990 | [INFO] | | ASU | PIM | PIM | | | 130477 | Processing ... _pimCreateOrUpdateAAMInventory
02/05/16 10:57:48:037 | [INFO] | | ASU | PIM | PIM | | | 130477 | Inventory Already present on the machine...
02/05/16 10:57:48:038 | [INFO] | | ASU | Setup | Setup | | | 130477 | Adobe Application Manager Installation Successful.
02/05/16 10:57:48:038 | [INFO] | | ASU | Setup | Setup | | | 130477 | Deployment File Path not specified, not launching DE.
02/05/16 10:57:48:038 | [INFO] | | ASU | Setup | Setup | | | 130477 | ================= Exiting Installer with Code: 0 =================
02/05/16 10:57:48:038 | [INFO] | | ASU | Setup | | | | 130477 | Event Guid generated is: '6341c8ba-2f31-4e75-a7b5-4091ba61f787'
02/05/16 10:57:48:082 | [INFO] | | ASU | Setup | | | | 130485 | Event with guid '6341c8ba-2f31-4e75-a7b5-4091ba61f787' is being sent
02/05/16 10:57:48:292 | [INFO] | | ASU | PIM | PIM | | | 130477 | PIMSqlite closeDB status 0
02/05/16 10:57:48:292 | [INFO] | | ASU | PIM | PIM | | | 130477 | FREE PIM Instance ...
02/05/16 10:57:48:292 | [INFO] | | ASU | Setup | | | | 130477 | Waiting for the async thread to get the task completed
02/05/16 10:57:48:982 | [INFO] | | ASU | Setup | | | | 130485 | Async thread is completed. Now exiting from function.
02/05/16 10:57:49:143 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Build Version - 1.9.3.56
02/05/16 10:57:49:143 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Logging Level verbosity Set to 4
02/05/16 10:57:49:143 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | The return code from the Bootstrapper Process is (0).
02/05/16 10:57:49:144 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Starting apply ASU Self-Update.
02/05/16 10:57:49:144 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | SelfUpdate Path - /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14//
02/05/16 10:57:49:144 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Bootstrapper launch location is :: /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14///Install.dylib/Contents/MacOS/Install
02/05/16 10:57:49:424 | [INFO] | | ASU | Setup | Setup | | | 130522 | Build Version - 9.0.0.141
02/05/16 10:57:49:424 | [INFO] | | ASU | Setup | Setup | | | 130522 | Logging Level verbosity Set to 4
02/05/16 10:57:49:427 | [INFO] | | ASU | Setup | Setup | | | 130522 | TimeLog: Bootstrapper Start
02/05/16 10:57:49:427 | [INFO] | | ASU | Setup | Setup | | | 130522 | Action specified - "install"
02/05/16 10:57:49:427 | [INFO] | | ASU | Setup | Setup | | | 130522 | Patch Signature file exists
02/05/16 10:57:49:427 | [INFO] | | ASU | Setup | | | | 130522 | Event Guid generated is: '6d9c6451-176e-41be-b55f-aea8ef9b97e2'
02/05/16 10:57:49:428 | [INFO] | | ASU | Setup | Setup | | | 130522 | Launch Path set to /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14
02/05/16 10:57:49:460 | [INFO] | | ASU | Setup | | | | 130538 | Event with guid '6d9c6451-176e-41be-b55f-aea8ef9b97e2' is being sent
02/05/16 10:57:49:516 | [INFO] | | ASU | PIM | PIM | | | 130522 | Build Version - 9.0.0.141
02/05/16 10:57:49:516 | [INFO] | | ASU | PIM | PIM | | | 130522 | Logging Level verbosity Set to 4
02/05/16 10:57:49:518 | [INFO] | | ASU | PIM | PIM | | | 130522 | Build Version - 9.0.0.141
02/05/16 10:57:49:518 | [INFO] | | ASU | PIM | PIM | | | 130522 | Logging Level verbosity Set to 4
02/05/16 10:57:49:518 | [INFO] | | ASU | PIM | PIM | | | 130522 | CREATE PIM Instance ...
02/05/16 10:57:49:533 | [INFO] | | ASU | PIM | PIM | | | 130522 | trying to createOrUpdatePIMDbSchema.
02/05/16 10:57:49:537 | [INFO] | | ASU | PIM | PIM | | | 130522 | Current db schema version on machine 4.
02/05/16 10:57:49:537 | [INFO] | | ASU | PIM | PIM | | | 130522 | Current db schema version to install 1.
02/05/16 10:57:49:537 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS Created Tables.
02/05/16 10:57:49:537 | [INFO] | | ASU | PIM | PIM | | | 130522 | PIM Database is Up To Date.
02/05/16 10:57:49:537 | [INFO] | | ASU | PIM | PIM | | | 130522 | Updater Inventory location:/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/Install.dylib/Contents/Frameworks/UpdaterInventory.framework/Versions/A/UpdaterInventory
02/05/16 10:57:49:587 | [INFO] | | ASU | PIM | PIM | | | 130522 | Acquired System level ACF lock ...
02/05/16 10:57:49:589 | [INFO] | | ASU | Setup | Setup | | | 130522 | TimeLog: Begin Installing
02/05/16 10:57:49:590 | [INFO] | | ASU | PIM | PIM | | | 130522 | Current OS version is: Major:10, Minor:10, ServicePack:4
02/05/16 10:57:49:699 | [INFO] | | ASU | PIM | PIM | | | 130522 | Package id DEAF719E-32E1-43AB-927F-FD66F0059CA7 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:49:758 | [INFO] | | ASU | PIM | PIM | | | 130522 | Package id C6D0F02D-D70B-422C-A70A-862AE77E1EA4 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:49:829 | [INFO] | | ASU | PIM | PIM | | | 130522 | Package id 297EE025-DA8C-49E7-ACCC-4F55DFC9B8D8 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:49:871 | [INFO] | | ASU | PIM | PIM | | | 130522 | Package id C8669E45-094E-43C7-AB3A-9AA778A76A17 is already installed
02/05/16 10:57:49:937 | [INFO] | | ASU | PIM | PIM | | | 130522 | Package id A078B261-F7EE-413F-9A03-D2F11B1C9D09 is already installed
02/05/16 10:57:50:008 | [INFO] | | ASU | PIM | PIM | | | 130522 | Package id 18B0AB1D-6DD9-4A02-82B9-8F73314B8C7A is already installed
02/05/16 10:57:50:132 | [INFO] | | ASU | PIM | PIM | | | 130522 | Package id DCE198F9-C31B-48B4-930C-394A6CA63CD6 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:50:188 | [INFO] | | ASU | PIM | PIM | | | 130522 | Package id 4ACAE438-4BF0-4E48-BC86-5063DA0F0FBD is a Old Package, a newer package is installed in the system.
02/05/16 10:57:50:244 | [INFO] | | ASU | PIM | PIM | | | 130522 | Package id 8D3DE599-9E91-4E0A-BFCE-8663C2368AC4 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:50:295 | [INFO] | | ASU | PIM | PIM | | | 130522 | Package id ACD33979-719D-4632-838C-90DE716DE02D is a Old Package, a newer package is installed in the system.
02/05/16 10:57:50:299 | [INFO] | | ASU | PIM | PIM | | | 130522 | Package id DE058D19-91A6-4CA9-BF12-A248502A549F is a Old Package, a newer package is installed in the system.
02/05/16 10:57:50:299 | [INFO] | | ASU | PIM | PIM | | | 130522 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 19626643
02/05/16 10:57:50:300 | [INFO] | | ASU | PIM | PIM | | | 130522 | freeDiskSpace ... 480372707328
02/05/16 10:57:50:300 | [INFO] | | ASU | PIM | PIM | | | 130522 | Executing Adobe Genuine Validation for all the AAM packages
02/05/16 10:57:50:300 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/core/PDApp.pimx'
02/05/16 10:57:50:314 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/core/PDApp.pima'
02/05/16 10:57:50:327 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/D6/D6.pimx'
02/05/16 10:57:50:333 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/D6/D6.pima'
02/05/16 10:57:50:348 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/DECore/DECore.pimx'
02/05/16 10:57:50:357 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/DECore/DECore.pima'
02/05/16 10:57:50:390 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/DWA/DWA.pimx'
02/05/16 10:57:50:395 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/DWA/DWA.pima'
02/05/16 10:57:50:412 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/P6/P6.pimx'
02/05/16 10:57:50:418 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/P6/P6.pima'
02/05/16 10:57:50:457 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/LWA/LWA.pimx'
02/05/16 10:57:50:462 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/LWA/LWA.pima'
02/05/16 10:57:50:497 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/UWA/UWA.pimx'
02/05/16 10:57:50:505 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/UWA/UWA.pima'
02/05/16 10:57:50:543 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/CCM/CCM.pimx'
02/05/16 10:57:50:549 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/CCM/CCM.pima'
02/05/16 10:57:50:582 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/P7/P7.pimx'
02/05/16 10:57:50:588 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/P7/P7.pima'
02/05/16 10:57:50:642 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/IPC/IPC.pimx'
02/05/16 10:57:50:646 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/IPC/IPC.pima'
02/05/16 10:57:50:654 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/AdobeGCClient/AdobeGCClient.pimx'
02/05/16 10:57:50:658 | [INFO] | | ASU | PIM | PIM | | | 130522 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/AdobeGCClient/AdobeGCClient.pima'
02/05/16 10:57:50:681 | [INFO] | | ASU | PIM | PIM | | | 130522 | Adobe Genuine Validation PASSED for all the AAM packages
02/05/16 10:57:50:681 | [INFO] | | ASU | PIM | PIM | | | 130522 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/core/PDApp.pimx
02/05/16 10:57:50:766 | [INFO] | | ASU | PIM | PIM | | | 130522 | NOTE package id DEAF719E-32E1-43AB-927F-FD66F0059CA7 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:50:770 | [INFO] | | ASU | PIM | PIM | | | 130522 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/D6/D6.pimx
02/05/16 10:57:50:819 | [INFO] | | ASU | PIM | PIM | | | 130522 | NOTE package id C6D0F02D-D70B-422C-A70A-862AE77E1EA4 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:50:822 | [INFO] | | ASU | PIM | PIM | | | 130522 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/DECore/DECore.pimx
02/05/16 10:57:50:870 | [INFO] | | ASU | PIM | PIM | | | 130522 | NOTE package id 297EE025-DA8C-49E7-ACCC-4F55DFC9B8D8 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:50:873 | [INFO] | | ASU | PIM | PIM | | | 130522 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/DWA/DWA.pimx
02/05/16 10:57:50:896 | [INFO] | | ASU | PIM | PIM | | | 130522 | Package id C8669E45-094E-43C7-AB3A-9AA778A76A17 is already installed
02/05/16 10:57:50:906 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS deleteAppletRegInfoRecords.
02/05/16 10:57:50:943 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS deletePackageUpgradeInfoRecords.
02/05/16 10:57:50:944 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS deletePackageInstallationInfoRecords.
02/05/16 10:57:50:997 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS insertPackageUpdateList.
02/05/16 10:57:51:001 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS insertAppletRegInfoList.
02/05/16 10:57:51:005 | [INFO] | | ASU | PIM | Native-Utils | | | 130522 | utilBackupFolderIfExits pathToBkp /Applications/Utilities/Adobe Application Manager/DWA
02/05/16 10:57:51:157 | [INFO] | | ASU | PIM | Native-Utils | | | 130522 | Backup folder path '/Applications/Utilities/Adobe Application Manager//DWA_bkp1'
02/05/16 10:57:51:437 | [INFO] | | ASU | PIM | PIM | | | 130522 | Trying to delete back up folder '/Applications/Utilities/Adobe Application Manager//DWA_bkp1'
02/05/16 10:57:51:776 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/DWA/DWA.pimx.
02/05/16 10:57:51:779 | [INFO] | | ASU | PIM | PIM | | | 130522 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/P6/P6.pimx
02/05/16 10:57:51:813 | [INFO] | | ASU | PIM | PIM | | | 130522 | Package id A078B261-F7EE-413F-9A03-D2F11B1C9D09 is already installed
02/05/16 10:57:51:826 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS deleteAppletRegInfoRecords.
02/05/16 10:57:51:899 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS deletePackageUpgradeInfoRecords.
02/05/16 10:57:51:899 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS deletePackageInstallationInfoRecords.
02/05/16 10:57:51:994 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS insertPackageUpdateList.
02/05/16 10:57:52:000 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS insertAppletRegInfoList.
02/05/16 10:57:52:005 | [INFO] | | ASU | PIM | Native-Utils | | | 130522 | utilBackupFolderIfExits pathToBkp /Applications/Utilities/Adobe Application Manager/P6
02/05/16 10:57:52:150 | [INFO] | | ASU | PIM | Native-Utils | | | 130522 | Backup folder path '/Applications/Utilities/Adobe Application Manager//P6_bkp1'
02/05/16 10:57:52:786 | [INFO] | | ASU | PIM | PIM | | | 130522 | Trying to delete back up folder '/Applications/Utilities/Adobe Application Manager//P6_bkp1'
02/05/16 10:57:53:033 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/P6/P6.pimx.
02/05/16 10:57:53:037 | [INFO] | | ASU | PIM | PIM | | | 130522 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/LWA/LWA.pimx
02/05/16 10:57:53:061 | [INFO] | | ASU | PIM | PIM | | | 130522 | Package id 18B0AB1D-6DD9-4A02-82B9-8F73314B8C7A is already installed
02/05/16 10:57:53:070 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS deleteAppletRegInfoRecords.
02/05/16 10:57:53:124 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS deletePackageUpgradeInfoRecords.
02/05/16 10:57:53:124 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS deletePackageInstallationInfoRecords.
02/05/16 10:57:53:177 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS insertPackageUpdateList.
02/05/16 10:57:53:181 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS insertAppletRegInfoList.
02/05/16 10:57:53:184 | [INFO] | | ASU | PIM | Native-Utils | | | 130522 | utilBackupFolderIfExits pathToBkp /Applications/Utilities/Adobe Application Manager/LWA
02/05/16 10:57:53:342 | [INFO] | | ASU | PIM | Native-Utils | | | 130522 | Backup folder path '/Applications/Utilities/Adobe Application Manager//LWA_bkp1'
02/05/16 10:57:53:875 | [INFO] | | ASU | PIM | PIM | | | 130522 | Trying to delete back up folder '/Applications/Utilities/Adobe Application Manager//LWA_bkp1'
02/05/16 10:57:54:189 | [INFO] | | ASU | PIM | PIM | | | 130522 | SUCCESS installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/LWA/LWA.pimx.
02/05/16 10:57:54:192 | [INFO] | | ASU | PIM | PIM | | | 130522 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/UWA/UWA.pimx
02/05/16 10:57:54:259 | [INFO] | | ASU | PIM | PIM | | | 130522 | NOTE package id DCE198F9-C31B-48B4-930C-394A6CA63CD6 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:54:263 | [INFO] | | ASU | PIM | PIM | | | 130522 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/CCM/CCM.pimx
02/05/16 10:57:54:296 | [INFO] | | ASU | PIM | PIM | | | 130522 | NOTE package id 4ACAE438-4BF0-4E48-BC86-5063DA0F0FBD is a Old Package, a newer package is installed in the system.
02/05/16 10:57:54:298 | [INFO] | | ASU | PIM | PIM | | | 130522 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/P7/P7.pimx
02/05/16 10:57:54:334 | [INFO] | | ASU | PIM | PIM | | | 130522 | NOTE package id 8D3DE599-9E91-4E0A-BFCE-8663C2368AC4 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:54:336 | [INFO] | | ASU | PIM | PIM | | | 130522 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/IPC/IPC.pimx
02/05/16 10:57:54:352 | [INFO] | | ASU | PIM | PIM | | | 130522 | NOTE package id ACD33979-719D-4632-838C-90DE716DE02D is a Old Package, a newer package is installed in the system.
02/05/16 10:57:54:353 | [INFO] | | ASU | PIM | PIM | | | 130522 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Patches/AdobeApplicationManager-1.0_update14/packages/AdobeGCClient/AdobeGCClient.pimx
02/05/16 10:57:54:354 | [INFO] | | ASU | PIM | PIM | | | 130522 | NOTE package id DE058D19-91A6-4CA9-BF12-A248502A549F is a Old Package, a newer package is installed in the system.
02/05/16 10:57:54:354 | [INFO] | | ASU | PIM | Native-Utils | | | 130522 | utilBackupFolderIfExits pathToBkp /Library/Application Support/Adobe/OOBE/PDApp
02/05/16 10:57:54:363 | [INFO] | | ASU | PIM | Native-Utils | | | 130522 | Backup folder path '/Library/Application Support/Adobe/OOBE//PDApp_bkp1'
02/05/16 10:57:54:364 | [INFO] | | ASU | PIM | Native-Utils | | | 130522 | Creating symbolic link of /Applications/Utilities/Adobe Application Manager/ to folder /Library/Application Support/Adobe/OOBE/PDApp
02/05/16 10:57:54:417 | [INFO] | | ASU | PIM | PIM | | | 130522 | Processing ... _pimCreateOrUpdateAAMInventory
02/05/16 10:57:54:424 | [INFO] | | ASU | PIM | PIM | | | 130522 | Higher version of AAM Updater inventory is already present in the machine. So skipping the creation of AAM Updater Inventory
02/05/16 10:57:54:424 | [INFO] | | ASU | PIM | PIM | | | 130522 | Return ... SUCCESS _pimCreateOrUpdateAAMInventory
02/05/16 10:57:54:425 | [INFO] | | ASU | Setup | Setup | | | 130522 | Adobe Application Manager Installation Successful.
02/05/16 10:57:54:425 | [INFO] | | ASU | Setup | Setup | | | 130522 | ================= Exiting Installer with Code: 0 =================
02/05/16 10:57:54:425 | [INFO] | | ASU | Setup | | | | 130522 | Event Guid generated is: '579e272d-f6cb-452b-9193-2f8514abd6d7'
02/05/16 10:57:54:449 | [INFO] | | ASU | Setup | | | | 130538 | Event with guid '579e272d-f6cb-452b-9193-2f8514abd6d7' is being sent
02/05/16 10:57:54:632 | [INFO] | | ASU | PIM | PIM | | | 130522 | PIMSqlite closeDB status 0
02/05/16 10:57:54:632 | [INFO] | | ASU | PIM | PIM | | | 130522 | FREE PIM Instance ...
02/05/16 10:57:54:633 | [INFO] | | ASU | Setup | | | | 130522 | Waiting for the async thread to get the task completed
02/05/16 10:57:55:230 | [INFO] | | ASU | Setup | | | | 130538 | Async thread is completed. Now exiting from function.
02/05/16 10:57:55:285 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Build Version - 1.9.3.56
02/05/16 10:57:55:286 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Logging Level verbosity Set to 4
02/05/16 10:57:55:286 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | The return code from the Bootstrapper Process is (0).
02/05/16 10:57:55:286 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | STEP 3: Starting to launch Bootstrapper of Media (IDSN11.0).
02/05/16 10:57:55:286 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Bootstrapper launch location is :: /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources//Setup/IDSN11.0/Install.dylib/Contents/MacOS/Install
02/05/16 10:57:55:592 | [INFO] | | ASU | Setup | Setup | | | 130553 | Build Version - 9.0.0.72
02/05/16 10:57:55:592 | [INFO] | | ASU | Setup | Setup | | | 130553 | Logging Level verbosity Set to 4
02/05/16 10:57:55:595 | [INFO] | | ASU | Setup | Setup | | | 130553 | TimeLog: Bootstrapper Start
02/05/16 10:57:55:595 | [INFO] | | ASU | Setup | Setup | | | 130553 | Action specified - "install"
02/05/16 10:57:55:596 | [INFO] | | ASU | Setup | | | | 130553 | Event Guid generated is: 'ea3352bc-185b-46f1-bd3a-b95352eb47ea'
02/05/16 10:57:55:597 | [INFO] | | ASU | Setup | Setup | | | 130553 | Launch Path set to /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0
02/05/16 10:57:55:628 | [INFO] | | ASU | Setup | | | | 130559 | Event with guid 'ea3352bc-185b-46f1-bd3a-b95352eb47ea' is being sent
02/05/16 10:57:55:683 | [INFO] | | ASU | PIM | PIM | | | 130553 | Build Version - 9.0.0.72
02/05/16 10:57:55:684 | [INFO] | | ASU | PIM | PIM | | | 130553 | Logging Level verbosity Set to 4
02/05/16 10:57:55:686 | [INFO] | | ASU | PIM | PIM | | | 130553 | Build Version - 9.0.0.72
02/05/16 10:57:55:686 | [INFO] | | ASU | PIM | PIM | | | 130553 | Logging Level verbosity Set to 4
02/05/16 10:57:55:686 | [INFO] | | ASU | PIM | PIM | | | 130553 | CREATE PIM Instance ...
02/05/16 10:57:55:700 | [INFO] | | ASU | PIM | PIM | | | 130553 | trying to createOrUpdatePIMDbSchema.
02/05/16 10:57:55:704 | [INFO] | | ASU | PIM | PIM | | | 130553 | Current db schema version on machine 4.
02/05/16 10:57:55:704 | [INFO] | | ASU | PIM | PIM | | | 130553 | Current db schema version to install 1.
02/05/16 10:57:55:704 | [INFO] | | ASU | PIM | PIM | | | 130553 | SUCCESS Created Tables.
02/05/16 10:57:55:704 | [INFO] | | ASU | PIM | PIM | | | 130553 | PIM Database is Up To Date.
02/05/16 10:57:55:705 | [INFO] | | ASU | PIM | PIM | | | 130553 | Updater Inventory location:/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/Install.dylib/Contents/Frameworks/UpdaterInventory.framework/Versions/A/UpdaterInventory
02/05/16 10:57:55:755 | [INFO] | | ASU | PIM | PIM | | | 130553 | Acquired System level ACF lock ...
02/05/16 10:57:55:756 | [INFO] | | ASU | Setup | Setup | | | 130553 | TimeLog: Begin Installing
02/05/16 10:57:55:757 | [INFO] | | ASU | PIM | PIM | | | 130553 | Current OS version is: Major:10, Minor:10, ServicePack:4
02/05/16 10:57:55:865 | [INFO] | | ASU | PIM | PIM | | | 130553 | Package id B333EBA0-10BD-4D2C-86C0-9BA44508F9B0 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:55:922 | [INFO] | | ASU | PIM | PIM | | | 130553 | Package id AFC1916D-BE86-4894-B10C-62B1FF0D351D is a Old Package, a newer package is installed in the system.
02/05/16 10:57:55:991 | [INFO] | | ASU | PIM | PIM | | | 130553 | Package id 7BB5B711-9C44-4B4B-9F68-4084054F7B34 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:031 | [INFO] | | ASU | PIM | PIM | | | 130553 | Package id A949A75F-E388-4139-9C06-65F4F8C3B5BB is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:065 | [INFO] | | ASU | PIM | PIM | | | 130553 | Package id 4B15DB13-ABAE-4346-83D7-EBBBDD1E265A is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:105 | [INFO] | | ASU | PIM | PIM | | | 130553 | Package id DF368E2B-7D64-4A4A-9B22-AB7AE0159229 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:181 | [INFO] | | ASU | PIM | PIM | | | 130553 | Package id 6CE2635D-2E5A-4759-BE3C-3610B4CAEA65 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:223 | [INFO] | | ASU | PIM | PIM | | | 130553 | Package id 91D74A46-C4F6-463A-8D3C-28838A51BF66 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:263 | [INFO] | | ASU | PIM | PIM | | | 130553 | Package id 01263FE0-A102-476C-B4A6-72563A22452D is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:283 | [INFO] | | ASU | PIM | PIM | | | 130553 | Package id 87E5ACB1-F098-4CE8-8075-37BE2B523B4A is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:284 | [INFO] | | ASU | PIM | PIM | | | 130553 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 0
02/05/16 10:57:56:284 | [INFO] | | ASU | PIM | PIM | | | 130553 | freeDiskSpace ... 480372109312
02/05/16 10:57:56:284 | [INFO] | | ASU | PIM | PIM | | | 130553 | Executing Adobe Genuine Validation for all the AAM packages
02/05/16 10:57:56:284 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/core/PDApp.pimx'
02/05/16 10:57:56:297 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/core/PDApp.pima'
02/05/16 10:57:56:310 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/D6/D6.pimx'
02/05/16 10:57:56:316 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/D6/D6.pima'
02/05/16 10:57:56:332 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/DECore/DECore.pimx'
02/05/16 10:57:56:338 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/DECore/DECore.pima'
02/05/16 10:57:56:373 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/DWA/DWA.pimx'
02/05/16 10:57:56:377 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/DWA/DWA.pima'
02/05/16 10:57:56:395 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/P6/P6.pimx'
02/05/16 10:57:56:400 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/P6/P6.pima'
02/05/16 10:57:56:439 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/LWA/LWA.pimx'
02/05/16 10:57:56:444 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/LWA/LWA.pima'
02/05/16 10:57:56:481 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/UWA/UWA.pimx'
02/05/16 10:57:56:489 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/UWA/UWA.pima'
02/05/16 10:57:56:526 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/CCM/CCM.pimx'
02/05/16 10:57:56:531 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/CCM/CCM.pima'
02/05/16 10:57:56:565 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/P7/P7.pimx'
02/05/16 10:57:56:570 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/P7/P7.pima'
02/05/16 10:57:56:623 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/IPC/IPC.pimx'
02/05/16 10:57:56:628 | [INFO] | | ASU | PIM | PIM | | | 130553 | Validating package file: '/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/IPC/IPC.pima'
02/05/16 10:57:56:636 | [INFO] | | ASU | PIM | PIM | | | 130553 | Adobe Genuine Validation PASSED for all the AAM packages
02/05/16 10:57:56:636 | [INFO] | | ASU | PIM | PIM | | | 130553 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/core/PDApp.pimx
02/05/16 10:57:56:720 | [INFO] | | ASU | PIM | PIM | | | 130553 | NOTE package id B333EBA0-10BD-4D2C-86C0-9BA44508F9B0 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:726 | [INFO] | | ASU | PIM | PIM | | | 130553 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/D6/D6.pimx
02/05/16 10:57:56:774 | [INFO] | | ASU | PIM | PIM | | | 130553 | NOTE package id AFC1916D-BE86-4894-B10C-62B1FF0D351D is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:777 | [INFO] | | ASU | PIM | PIM | | | 130553 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/DECore/DECore.pimx
02/05/16 10:57:56:824 | [INFO] | | ASU | PIM | PIM | | | 130553 | NOTE package id 7BB5B711-9C44-4B4B-9F68-4084054F7B34 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:827 | [INFO] | | ASU | PIM | PIM | | | 130553 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/DWA/DWA.pimx
02/05/16 10:57:56:846 | [INFO] | | ASU | PIM | PIM | | | 130553 | NOTE package id A949A75F-E388-4139-9C06-65F4F8C3B5BB is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:847 | [INFO] | | ASU | PIM | PIM | | | 130553 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/P6/P6.pimx
02/05/16 10:57:56:876 | [INFO] | | ASU | PIM | PIM | | | 130553 | NOTE package id 4B15DB13-ABAE-4346-83D7-EBBBDD1E265A is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:878 | [INFO] | | ASU | PIM | PIM | | | 130553 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/LWA/LWA.pimx
02/05/16 10:57:56:897 | [INFO] | | ASU | PIM | PIM | | | 130553 | NOTE package id DF368E2B-7D64-4A4A-9B22-AB7AE0159229 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:898 | [INFO] | | ASU | PIM | PIM | | | 130553 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/UWA/UWA.pimx
02/05/16 10:57:56:962 | [INFO] | | ASU | PIM | PIM | | | 130553 | NOTE package id 6CE2635D-2E5A-4759-BE3C-3610B4CAEA65 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:56:966 | [INFO] | | ASU | PIM | PIM | | | 130553 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/CCM/CCM.pimx
02/05/16 10:57:56:998 | [INFO] | | ASU | PIM | PIM | | | 130553 | NOTE package id 91D74A46-C4F6-463A-8D3C-28838A51BF66 is a Old Package, a newer package is installed in the system.
02/05/16 10:57:57:000 | [INFO] | | ASU | PIM | PIM | | | 130553 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/P7/P7.pimx
02/05/16 10:57:57:034 | [INFO] | | ASU | PIM | PIM | | | 130553 | NOTE package id 01263FE0-A102-476C-B4A6-72563A22452D is a Old Package, a newer package is installed in the system.
02/05/16 10:57:57:036 | [INFO] | | ASU | PIM | PIM | | | 130553 | START installPackage at file /Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources/Setup/IDSN11.0/packages/IPC/IPC.pimx
02/05/16 10:57:57:051 | [INFO] | | ASU | PIM | PIM | | | 130553 | NOTE package id 87E5ACB1-F098-4CE8-8075-37BE2B523B4A is a Old Package, a newer package is installed in the system.
02/05/16 10:57:57:053 | [INFO] | | ASU | PIM | Native-Utils | | | 130553 | Creating symbolic link of /Applications/Utilities/Adobe Application Manager/ to folder /Library/Application Support/Adobe/OOBE/PDApp
02/05/16 10:57:57:077 | [INFO] | | ASU | PIM | PIM | | | 130553 | Processing ... _pimCreateOrUpdateAAMInventory
02/05/16 10:57:57:088 | [INFO] | | ASU | PIM | PIM | | | 130553 | Higher version of AAM Updater inventory is already present in the machine. So skipping the creation of AAM Updater Inventory
02/05/16 10:57:57:088 | [INFO] | | ASU | PIM | PIM | | | 130553 | Return ... SUCCESS _pimCreateOrUpdateAAMInventory
02/05/16 10:57:57:088 | [INFO] | | ASU | Setup | Setup | | | 130553 | Adobe Application Manager Installation Successful.
02/05/16 10:57:57:088 | [INFO] | | ASU | Setup | Setup | | | 130553 | Deployment File Path not specified, not launching DE.
02/05/16 10:57:57:088 | [INFO] | | ASU | Setup | Setup | | | 130553 | ================= Exiting Installer with Code: 0 =================
02/05/16 10:57:57:088 | [INFO] | | ASU | Setup | | | | 130553 | Event Guid generated is: 'efc2064f-5727-428c-8a82-a2dcb2b0f2de'
02/05/16 10:57:57:122 | [INFO] | | ASU | Setup | | | | 130559 | Event with guid 'efc2064f-5727-428c-8a82-a2dcb2b0f2de' is being sent
02/05/16 10:57:57:265 | [INFO] | | ASU | PIM | PIM | | | 130553 | PIMSqlite closeDB status 0
02/05/16 10:57:57:265 | [INFO] | | ASU | PIM | PIM | | | 130553 | FREE PIM Instance ...
02/05/16 10:57:57:265 | [INFO] | | ASU | Setup | | | | 130553 | Waiting for the async thread to get the task completed
02/05/16 10:57:57:939 | [INFO] | | ASU | Setup | | | | 130559 | Async thread is completed. Now exiting from function.
02/05/16 10:57:58:023 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Build Version - 1.9.3.56
02/05/16 10:57:58:023 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Logging Level verbosity Set to 4
02/05/16 10:57:58:024 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | The return code from the Bootstrapper Process is (0).
02/05/16 10:57:58:024 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Correcting Dependencies in local db.
02/05/16 10:57:58:024 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | STEP 4: Starting to launch Adobe Installer.
02/05/16 10:57:58:035 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Updated the deployment install language (en_GB) from the fallback map ...
02/05/16 10:57:58:035 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Obtained Adobe Common Folder Path.
02/05/16 10:57:58:035 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Adobe Installer launch location is :: /Library/Application Support/Adobe/OOBE/PDApp/DECore/Setup.app/Contents/MacOS/Setup
02/05/16 10:57:58:036 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | deploymentFile = (/tmp/A6FD7F7B-F6CF-4BDF-8457-0B1542DB98DA//EF9DE6F1-7F90-45CF-B39D-C342232441D8), installSourcePath = (/Volumes/Zoidberg/Adobe Installers/Mac/InDesign/Build/InDesign_Install.pkg/Contents/Resources//Setup/IDSN11.0)
02/05/16 10:57:58:036 | [INFO] | | ASU | DeploymentManager | AAMEEUtilities | | | 130009 | Launch Process With Task
02/05/16 10:58:11:353 | [FATAL] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | The return code from the Adobe Installer Process is (37).Stopping the installation process.
02/05/16 10:58:11:385 | [ERROR] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Media Failed (IDSN11.0)
02/05/16 10:58:11:385 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Starting to clean the partially installed payloads.
02/05/16 10:58:11:455 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Undeployment XML created at path :: /tmp/A6FD7F7B-F6CF-4BDF-8457-0B1542DB98DA//F69873AD-B614-46A9-9464-834D6B6E6B30
02/05/16 10:58:11:455 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Starting to launch the Adobe Installer for uninstall mode.
02/05/16 10:58:11:456 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | Obtained Adobe Common Folder Path.
02/05/16 10:58:11:456 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | /Library/Application Support/Adobe/OOBE/PDApp/DECore/Setup.app/Contents/MacOS/Setup
02/05/16 10:58:11:456 | [INFO] | | ASU | DeploymentManager | AAMEEUtilities | | | 130009 | Launch Process With Task
02/05/16 10:58:13:133 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130690 | Build Version - 9.0.0.242
02/05/16 10:58:13:133 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130690 | Logging Level verbosity Set to 4
02/05/16 10:58:13:134 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130690 | Start: Adobe Application Manager Uninstall...
02/05/16 10:58:13:134 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130690 | Get RIBS Product count
02/05/16 10:58:13:200 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130690 | RIBS Products install status
02/05/16 10:58:13:200 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130690 | Get NON RIBS Product count
02/05/16 10:58:13:201 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130690 | AAMRefs folder does not exists. Non-Ribs products does not exist on the system
02/05/16 10:58:13:201 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130690 | NON RIBS Products install status
02/05/16 10:58:13:201 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130690 | Launching removeAAM executable from: /Applications/Utilities/Adobe Application Manager//core/RemoveAAM
02/05/16 10:58:13:362 | [INFO] | | ASU | | UninstallAAM | | | 130710 | Executable launched to Remove AAM
02/05/16 10:58:13:363 | [INFO] | | ASU | | UninstallAAM | | | 130710 | Loading AdobePIM.dylib from: /Applications/Utilities/Adobe Application Manager/core/AdobePIM.dylib
02/05/16 10:58:13:548 | [INFO] | | ASU | | UninstallAAM | | | 130710 | calling pim_uninstallAAMFromAAMCleanerTool
02/05/16 10:58:13:551 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130710 | Build Version - 9.0.0.244
02/05/16 10:58:13:551 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130710 | Logging Level verbosity Set to 4
02/05/16 10:58:13:551 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130710 | Killing all Non-Deployment workflows
02/05/16 10:58:13:551 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130710 | Check and wait on Adobe installer (Bootstrapper) if running...
02/05/16 10:58:13:551 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130710 | Check and wait on Adobe installer (RIBS) if running...
02/05/16 10:58:13:552 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130710 | Check and wait if ACF is locked...
02/05/16 10:58:13:552 | [INFO] | | ASU | PIM-Uninstall | PIM-Uninstall | | | 130710 | Check and close Adobe Application Manager notifiers...
02/05/16 10:58:13:554 | [INFO] | | ASU | PIM-Uninstall | PIM | | | 130710 | Executing install modifiers
02/05/16 10:58:13:563 | [INFO] | | ASU | PIM | PIM | | | 130710 | Build Version - 9.0.0.244
02/05/16 10:58:13:563 | [INFO] | | ASU | PIM | PIM | | | 130710 | Logging Level verbosity Set to 4
02/05/16 10:58:13:563 | [INFO] | | ASU | PIM | PIM | | | 130710 | CREATE PIM Instance ...
02/05/16 10:58:13:570 | [INFO] | | ASU | PIM | PIM | | | 130710 | trying to createOrUpdatePIMDbSchema.
02/05/16 10:58:13:573 | [INFO] | | ASU | PIM | PIM | | | 130710 | Current db schema version on machine 4.
02/05/16 10:58:13:573 | [INFO] | | ASU | PIM | PIM | | | 130710 | Current db schema version to install 1.
02/05/16 10:58:13:573 | [INFO] | | ASU | PIM | PIM | | | 130710 | SUCCESS Created Tables.
02/05/16 10:58:13:573 | [INFO] | | ASU | PIM | PIM | | | 130710 | PIM Database is Up To Date.
02/05/16 10:58:13:651 | [WARN] | | ASU | PIM | | | XMLParser | 130710 | ERROR invalid xml file path. Could not read data from path /Applications/Utilities/Adobe Application Manager/AdobeGCClient/AdobeGCClient.pimx
02/05/16 10:58:13:814 | [WARN] | | ASU | PIM | | | XMLParser | 130710 | Error Description Error Domain=NSCocoaErrorDomain Code=260 "The file “AdobeGCClient.pimx” couldn’t be opened because there is no such file." UserInfo=0x209e70 {NSFilePath=/Applications/Utilities/Adobe Application Manager/AdobeGCClient/AdobeGCClient.pimx, NSUnderlyingError=0x209890 "The operation couldn’t be completed. No such file or directory"}
02/05/16 10:58:13:844 | [INFO] | | ASU | PIM | PIM | | | 130710 | Failed to load XML at path : '/Applications/Utilities/Adobe Application Manager/AdobeGCClient/AdobeGCClient.pimx'
02/05/16 10:58:13:955 | [ERROR] | | ASU | PIM | Native-Utils | | | 130710 | File doesnot exists at: '/Applications/Utilities/Adobe Application Manager/CCM/Utilities/AdobeApplicationManager(URIHandler).app/Contents/MacOS/AdobeApplicationManager(URIHandler)'
02/05/16 10:58:13:955 | [INFO] | | ASU | PIM | PIM | | | 130710 | Error occurred executing uninstall modifier at path: '/Applications/Utilities/Adobe Application Manager/CCM/Utilities/AdobeApplicationManager(URIHandler).app/Contents/MacOS/AdobeApplicationManager(URIHandler)'
02/05/16 10:58:14:199 | [INFO] | | ASU | PIM | Native-Utils | | | 130710 | Launch Process With Task
02/05/16 10:58:14:511 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | The return code from the Adobe Installer Process is (33).Uninstallation successful or nothing to uninstall.
02/05/16 10:58:14:536 | [INFO] | | ASU | DeploymentManager | AAMEEUtilities | | | 130009 | Preffered languages returned from the OS api call (en)
02/05/16 10:58:15:392 | [INFO] | | ASU | PIM | PIM | | | 130710 | Successfully executed uninstall modifier at path: '/Applications/Utilities/Adobe Application Manager/IPC/customhook/AdobeIPCBrokerCustomHook'
02/05/16 10:58:15:615 | [INFO] | | ASU | OPM | OPM | | | 130009 | Build Version - 9.0.0.222
02/05/16 10:58:15:615 | [INFO] | | ASU | OPM | OPM | | | 130009 | Logging Level verbosity Set to 4
02/05/16 10:58:15:739 | [INFO] | | ASU | PIM | Native-Utils | | | 130710 | Launch Process With Task
02/05/16 10:58:15:761 | [INFO] | | ASU | OPM | OPM | | | 130009 | Schema version and schema compatibility version are same or greater than current
02/05/16 10:58:15:761 | [INFO] | | ASU | OPM | OPM | | | 130009 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
02/05/16 10:58:15:761 | [INFO] | | ASU | OPM | OPM | | | 130009 | No Record found for the input fields in opm_getValueForKey
02/05/16 10:58:15:762 | [INFO] | | ASU | OPM | OPM | | | 130009 | Released OPM refrence successfully in opm_freeLibRef
02/05/16 10:58:15:793 | [INFO] | | ASU | AAMCustomHook | AAMCustomHook | | | 130725 | Build Version - 9.0.0.244
02/05/16 10:58:15:793 | [INFO] | | ASU | AAMCustomHook | AAMCustomHook | | | 130725 | Logging Level verbosity Set to 4
02/05/16 10:58:15:793 | [INFO] | | ASU | AAMCustomHook | | | CommandLineParser | 130725 | Parsing the command line provided. Number of command line arguments is 2
02/05/16 10:58:15:794 | [INFO] | | ASU | AAMCustomHook | AAMCustomHook | | | 130725 | Updater Inventory location: '/Applications/Utilities/Adobe Application Manager//UWA/UpdaterInventory.framework/Versions/A/UpdaterInventory'
02/05/16 10:58:16:074 | [INFO] | | ASU | DeploymentManager | | | | 130009 | Event Guid generated is: '88889155-4ff1-45be-9610-99490a6104b4'
02/05/16 10:58:16:138 | [INFO] | | ASU | AAMCustomHook | AAMCustomHook | | | 130725 | Updater Inventory remove status retVal 0, outStatusMajor 0, outStatusMinor 0
02/05/16 10:58:16:139 | [INFO] | | ASU | PIM | PIM | | | 130710 | Successfully executed uninstall modifier at path: '/Applications/Utilities/Adobe Application Manager/core/AAMCustomHook'
02/05/16 10:58:16:234 | [INFO] | | ASU | PIM | PIM | | | 130710 | PIMSqlite closeDB status 0
02/05/16 10:58:16:234 | [INFO] | | ASU | PIM | PIM | | | 130710 | FREE PIM Instance ...
02/05/16 10:58:16:234 | [ERROR] | | ASU | PIM | PIM | | | 130710 | Unable to free PIM object
02/05/16 10:58:16:235 | [INFO] | | ASU | PIM | PIM | | | 130710 | The temp path for AAM Backup is :/tmp/9FB63C54-FB19-472A-857C-8228058546BD
02/05/16 10:58:16:246 | [INFO] | | ASU | PIM | Native-Utils | | | 130710 | src File:/Library/Application Support/Adobe/AdobeApplicationManager does not exists in utilMovePathToPath
02/05/16 10:58:16:246 | [INFO] | | ASU | PIM | PIM | | | 130710 | Updater Inventory location:/tmp/9FB63C54-FB19-472A-857C-8228058546BD/Adobe Application Manager/UWA/UpdaterInventory.framework/UpdaterInventory
02/05/16 10:58:16:247 | [INFO] | | ASU | PIM | PIM-Uninstall | | | 130710 | Updater Inventory remove status retVal 1, outStatusMajor 0, outStatusMinor 0
02/05/16 10:58:16:247 | [INFO] | | ASU | PIM | PIM-Uninstall | | | 130710 | Successfully removed AAM Inventory... Using UpdaterInventory
02/05/16 10:58:17:389 | [INFO] | | ASU | PIM | PIM-Uninstall | | | 130710 | AAM PKG Forget status 0. Fail, but ignored..
02/05/16 10:58:17:660 | [INFO] | | ASU | PIM | PIM-Uninstall | | | 130710 | Successfully uninstalled Adobe Application Manager ..
02/05/16 10:58:18:044 | [INFO] | | ASU | DeploymentManager | | | | 130009 | Waiting for the async thread to get the task completed
02/05/16 10:58:18:053 | [INFO] | | ASU | DeploymentManager | | | | 130727 | Async thread is completed. Now exiting from function.
02/05/16 10:58:18:063 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 130009 | The install workflow is terminating.
Return Code 37 indicates a corrupt package.
https://helpx.adobe.com/creative-cloud/packager/troubleshoot-install-uninstall-errors-ccp.html
Validation failed. (Binary in the package may have got corrupt.) | 37 | Create the package again. |
Welk I have made package after package through the CCP. And each one of them says package was successfully built complete.
How on earth am I meant to know if there's a problem if your packager manager doesn't indicate an issue?
II've built these packages 3 times, I've tried on multiple computers to build them and they fail. I can't keep wasting time building package after package and then testing just to try and get one that works.
After banging my head against the desk at repeatedly creating packages, trying on different computers I've finally found a fix.
These packages were copied to an external drive, if I try and install them from the external drive, which is standard practice it fails.
If I then copy that pkg file from the External, to the computer I'm installing it on, then run it, it go's and installs fine.
Which is mind boggling stupid, because it's rare that you should have to copy the file to any computer, it's at the very least always installed off an external, and a lot of people in Enterprise are pushing it out over the network and management suites so there's some serious issue in the Adobe Packager if that's the case where it can't handle the medium it's being installed off.
Hopefully if someone else is having problems then this fixes it.
We were able to work around this problem by creating a .DMG disk image from the folder containing the installer, then putting that DMG onto our external media. We can then mount the DMG directly from the external and run it successfully without having to copy the installer to the machine first.
Don't ask me why this works. I've done this in the past to work around problems installing .pkg files from an SMB share, and figured it was worth a shot here.
My mistake, I was using the msi file not the setup.exe, all is fine when using the setup.exe
