1 Reply Latest reply on Feb 5, 2016 10:19 AM by JoelGeraci_Datalogics
    slide to play frames
    fernandoe6239238
      This is the challenge!
      This is a 3d scene and I want to create a slider so I can move thru the frames.
      The goal is not to play sequences but to control manually the scene.
      How can be done? I would appreciate some help.
        • 1. Re: slide to play frames
          JoelGeraci_Datalogics Level 3
          The Animation object in the 3D JS API will allow you to get the length of the animation in seconds, the current time measured in seconds, as well as the number of frames per second. Do a little math and you can step through the animation frame by frame...
          ...or you can just use the animation slider in the 3D toolbar.
          J-
