4 Replies Latest reply on Feb 4, 2016 2:36 AM by ciceroc69199093
    Javascript code for Adobe Acrobat
    ciceroc69199093
      I have to use some Javascript code for a PDF file.
      I am just starting learning Javascript but I don't have all the knowledge for now.
      Here's my wish I would like : in the file we can see in Viewer Type: Adobe Acrobat.
      If I want to rewrite a text in this place I have to delete "Adobe Acrobat" and then I can write an another.
      But my wish is to click in this text "Adobe Acrobat" and when I click on it the text should disappear, and then I can rewrite on it.
      If nothing is written in this part "Adobe Acrobat" should come back.
      I don't know if my explication is good.
      Thanks for your help.
      Here's the link:
      http://www.planetpdf.com/planetpdf/pdfs/ppjslc_commonex_1.pdf
        • 2. Re: Javascript code for Adobe Acrobat
          ciceroc69199093 Level 1
          Thank you for the link.
          Could you tell me how to put this code
          // Custom Format script for text field
          if (!event.value) {
          event.value = "Instructional text goes here";
          event.target.display = display.noPrint;
          } else {
          event.target.display = display.visible;
          into this
          var bAlreadyOpened;
          function docOpened()
          if(bAlreadyOpened != "true")
               // document has just been opened, reset form
                            this.resetForm();
                            // check version/type
                            var variation = app.viewerVariation;
                            var version = app.viewerVersion;
                            var variationName = "";
                            if(variation == "Reader")
                                  variationName = "Adobe Reader";
                            else if(variation == "Full")
                                  variationName = "Adobe Acrobat";
                            // now set the form fields to show what type/version is running
                            this.getField("txtType").value = variationName;
                            this.getField("txtVersion").value = app.viewerVersion;
            else
            // document has already been opened
          // call the docOpened() function
          docOpened();
          Thank you very much
          • 3. Re: Javascript code for Adobe Acrobat
            The two things are unrelated. The code I provided in that thread is meant to be used as the field's On Focus and On Blur events. Your code is a doc-level script.
            • 4. Re: Javascript code for Adobe Acrobat
              OK I understand.
              Thanks you very much for your help.
