Hi guys,
A couple of month ago when I last checked our website it looked alright. But all of a sudden it become quite the mess!
This page was in line and all was good. But now there's plenty of gaps created and spaces where they dont need to be! When I check the coding, it was all good. So what could be the cause?
Is it a bug?
Can someone help me with fixing the issue?
Please?
Thanks!
That is more information.
Then it is breaks that is a line break. You will have put those in editing the small product layout. Did you edit the layout in the admin with the normal editor? Not designed for coding so that will have caused it.
Go to the small product layout, go in code and you just need to delete those breaks.
Hard to tell without the code. Likely to involve float
and clear
css properties, though.
Hi Robert,
This is the code I have:
<table width="100%" cellpadding="5" border="0">
<tbody><tr>
<td colspan="3"><h2>X Gondola, Classic</h2></td>
</tr>
<tr>
<th><strong>Specs</strong></th>
<th><strong>Code</strong></th>
</tr>
<tr class="blueRow">
<td>670Lx670Wx1350H</td>
<td>GCXD66</td>
</tr>
<tr>
<td>900Lx900Wx1350H</td>
<td>GCXD99</td>
</tr>
</tbody></table>
What do you think?
Yep, that's definitely a table
. Can't say much else about what you've shown here.
Go into the code and delete your spacing and gaps... You will likely find that you press delete and nothing happens.. IF the CSS is fine you will have edited the code in something strange and got a hidden characters in there which WILL blow out content.
Hi Liam, thanks so much. I do think its the hidden character in the CSS. How do I go about fixing this? Where do I go to edit the CSS?
I think your misunderstand your assuming it is your CSS causing it, you not provided a link so it is always a lot harder to help without one to see the issue directly.
Hi Liam,
My assumption is based on checking out the CSS of the webpage from my google chrome. The <br> codes are the things that created the strange spaces. All I need to do it delete them from BC correct? How do i do that?
THANK YOU LIAM! YOU'RE A LEGEND
