3 Replies Latest reply on Feb 4, 2016 3:02 PM by Ann Bens
    Why are effects not working on still images.
    ErwinITH
      Why are some effects not working on still images?
      Like active camera or earthquake?
        • 1. Re: Why are effects not working on still images.
          whsprague Level 4
          It seems to me that to have an earthquake or busy camera, a series of frames would have to be moved  around by the software.  In other words, you need a video clip with distinct frames.  A still is one frame.
          You might be able work around this.  Put your still image in a dedicated project, share/export to a video.  It will have the many frames you need.  Bring it back into a project as the video rather than as a still.  You should then be able to apply your chosen effects.
          I didn't take the time to try this, but I think it should work.
          Bill
          • 2. Re: Why are effects not working on still images.
            ErwinITH Level 1
            That is probably so and I will test it...
            However I would like believe that a still frame is not 1 frame when its is extended for x time, because then you made x copies of the frame.
            Sounds more like a bug to me.
            But thx, Ill report back if it works.
            • 3. Re: Why are effects not working on still images.
              Actually it does work on a stills but you cannot see it, as a still consist of copies of the first frame (as you have already determined)
              So the effect is applied to a sequence of  'first' frames.
              You can check this by adding the effect to a still and move the slider back and forth in the Applied Effects window.
              Bill's suggestion actually works.
