9 Replies Latest reply on Apr 4, 2016 12:37 PM by Michael Witherell
    Why is stroke on wrong side of inner contour, compound path, InD CC?
    foldingdummy Level 1
      Curious stroke glitch: occurs in both compound path made from shapes and when using "create outlines" from text.
      Details: When I create outlines from type in InDesign CC, then apply a stroke with "align to outside of path" chosen in stroke specs, the stroke goes to the outside of __both__ the inner and outer contour. Same glitch happens with "align to inside" chosen. With compound paths (PostScript objects), the inner contour should be stroked on the "mirror image" of the path from the outer contour. For comparison, it is _not_ wrong in Illustrator, only InDesign. If I copy the path from InDesign document and paste it into Illustrator document, Illustrator strokes it correctly.
