With our R213 release, scheduled for March 2016, we're going to push some updates that aim to solve some of the consistency or redundancy issues currently present in our liquid beta implementation.
Today, the pagination across some of the BC modules is highly inconsistent and offers different level of support depending on the module it's implemented on. We want to change that so that all modules outputting paginated data expose a metadata object named "pagination" with the following fields:
previousPageUrl, nextPageUrl
- for the modules that expose paginated data but for which the concept of previous and next page might not make sense, these fields will be set to nullcurrentPage, numberOfPages
- numeric values, mandatory. currentPage represents the current page number, using 1 based indexingitemsPerPage
- numeric, mandatory [new]totalItemsCount
- numeric, mandatory [new] - also requested here: https://forums.adobe.com/ideas/4547While previousPageUrl, nextPageUrl, currentPage
and numberOfPages
are already exposed by some modules, itemsPerPage
and totalItemsCount
are new fields that aim to make it easier for partner to handle module output.
As such, the modules below will be updated for pagination metadata consistency:
itemsPerPage
and totalItemsCount
. previousPageUrl
and nextPageUrl
will be set to null instead of string empty when there is no previous / next page available. currentPage, numberOfPages
, itemsPerPage
and totalItemsCount
. previousPageUrl
and nextPageUrl
will be set to null instead of string empty when there is no previous / next page available.itemsPerPage
and totalItemsCount
, itemsPerPage
and totalItemsCount
. previousPageUrl
and nextPageUrl
, itemsPerPage
and totalItemsCount
. previousPageUrl
and nextPageUrl
will be set to null instead of string empty when there is no previous / next page available.Important note: while the change is backwards compatible for most modules, there are three modules (listed below) where the change is going to break the compatibility:
module_blog
, overall layout:previousPageUrl
will be null
instead of “#”nextPageUrl
will be null
instead of “#”module faqresults
previousPageUrl
will be null
instead of “”nextPageUrl
will be null
instead of “”module searchresults
previousPageUrl
will be null
will be null
instead of “” To prevent any navigation issues, please update your sites prior to the release to take this change into account.
Currently, in web apps detail layout, numeric, boolean and datetime values respect their type. In the web app list layout they are captured as string. With the R213 release, we're going to adopt a consistent behaviour for both cases.
Important notes:
{% if myVariable and myVariable != "" %}
).As previously mentioned on this forum thread (Removing unnecessary data from modules in Liquid), we're planning to remove some of the unnecessary data outputted by liquid modules. Please find below a list of what's scheduled for removal.
1. editableFieldTypes from module data
Many modules include an object named editableFieldTypes in the data they make available for Liquid. Below is an example of the editableFieldTypes object generated for events (bookings):
"events": {
"moduleName": "booking",
"editableFieldTypes": {
"body": "Html",
"id": "Id",
"name": "Text",
"date": "Date",
"capacity": "Number",
"percentFull": "Number",
"capacityEmpty": "Number"
These editable fields are a reminiscence from a feature we previously experimented with but never made it to production. They are of no use at the moment and just pollute the output of |json
2. Unused fields from moduleDescriptor
In Liquid, each module contains a metadata object called moduleDescriptor
. For example:
"events": {
"moduleDescriptor": {
"templatePath": "/Layouts/Booking/list.html",
"parameters": "filter=\"all\",collection=\"events\",template=\"\"",
"apiEndpoint": "/api/v3/booking",
"objectType": -1,
"objectId": -1,
"adminUrl": ""
With the release, we're going to remove the following fields from the moduleDescriptor
: apiEndpoint, adminUrl. adminUrl
are unusable for the vast majority of modules and the apiEndpoint
is probably not really useful as a field in the content rendered by a module. objectType
and objectId
will not be removed for the moment, but we do not plan to support them in the future.
3. _raw date fields generated by modules
For date time fields, most modules also output a _raw
version which is the same as the normal version except that it isn't converted to the site's time zone. Instead it always uses the Sydney timezone without daylight saving. _raw
date time fields were useful in the older days of Liquid in BC when we didn't have proper data type and handling and no format filters for dates, since _raw
fields were in a format that was easier to use in JavaScript. However, nowadays they are just redundant and in many situations inaccurate and thus we are removing them.
To avoid any problems with your sites, please make sure you update the pages using the changed functionality by March 10th.
Thank you BC team for finally getting around to locking down and working on tidying, finishing and sorting Liquid into a good state.
Hey guys,
module_booking seems to have zero pagination data output when rendered as a collection and there is no means to form the pagination etc and not mentioned in your update notes.
Hi Liam,
It's not mentioned because we haven't added pagination for this module. Further updates here will be considered for future releases but nothing planned yet.
Cristinel
