3 Replies Latest reply on Feb 5, 2016 12:18 PM by joel_pau
    get current time lable
    ryan_pu Level 1
      So I can play to
      .play('label')
      And I can stop at
      .stop('label')
      but How do I read what label I am currently at? I would like to make some conditionals based off where it is in timeline based on labels.
        • 1. Re: get current time lable
          joel_pau Level 5
          You have 2 tools: sym.getPosition() and sym.getLabelPosition().
          I assume i have a label called "first" at 1000 (one second);
          if ( sym.getPosition() ==  sym.getLabelPosition("first") ) { console.log("the current label is first) };
          What's your goal?
          • 2. Re: get current time lable
            ryan_pu Level 1
            Would like to attach a list of switches to a tester and compare them to a results list. if its a match, activate another function.
            example:
            conditionsArray(['.btn1','.swtch1']);
            if (conditionsArray == on, on) {startEngine}
            code that I got so far:
            function twoPhaseSwitch(object,state)
              var obj = $(object);
              var state = $(state);
              obj.click(function(e)
              if(state == 'off')
              stage.getSymbol(obj).stop('on');
              state = 'on';
              }else{
              stage.getSymbol(obj).stop('off');
              state = 'off';
            function conditionsArray(obj)
              for (var i=obj.length;i--;)
               //alert(obj.getPosition());
               //alert(obj.state);
               //alert(obj[state]);
            • 3. Re: get current time lable
              joel_pau Level 5
              Well, i have Edge Animate 1.5
              Can you send me a sample using a private message?
