OS is windows 8.1 or 7 I have tried both. Does it on both.
Flash 20.0.0.286
Chrome with auto update. FireFox did do a better job at first. Then it got worse then Chrome.
10 MPS on download speeds.
Checked and unchecked hardware acceleration. No effect.
Tired increasing the web site data. No effect.
Tried 4 different computers thinking they was to small to run Flash smoothly. No effect.
Been doing this over 2 years saving up money to get another computer to only find out it was not the problem hardware wise.
3 AMD and latest Intel I5 3.5 8gigs of ram.
Computer is dedicated to only doing videos. No other background programs installed. Just the OS and its updates. Drivers for MB
2 Different monitors. First was a plasma, second is a Vizio. Same problem
Screen resolution does not matter. Nor does play back resolution.
Hulu. Be nice to watch Hulu. The app in the TV plays Hulu fine. It is just a crappy app. Crashes alot. But the video is smooth!!!
Watching a show, when it pans it stutters, when it zooms is stutters. Watch the news. The bottom ticker stutters.
I can play a DVD, fine
Videos that are not Flash play fine.
So..... Any Thoughts would be really nice. Really really nice.
could you please share the video URL for which the issue occurs.
What is the flash player version are you using?
click on check now button on below page :
Thanks for replying.
Any website that uses flash. Hulu, HBO go. Foxnews.
Flash 20.0.0.286
I even tried Ubuntu to see if windows was the problem.
Still the same. Little better. Not much though.
How are the computers connected to the Internet? Are you using wireless, ethernet or something else?
Hulu in particular is problematic because they don't use hardware acceleration for video. All of the video is processed on the system CPU, which can be processor intensive. You should be able to fire up task manager and see if there's CPU contention in play. If the CPU is hitting 100%, then you're experiencing CPU contention. The machine can't keep up with the processing required to render the video stream. If not, then I'd look at the network. If you're on wireless, I'd plug the thing into the router by ethernet. If the performance is still bad, plug it directly into the cable/dsl/whatever modem. If it's still bad, try a second ethernet cable just in case.
Do you have the same problem with things like 4K videos on Youtube? Those are HTML5 and should leverage hardware acceleration. Searching for 4K test video should find something reasonable. Here's one of some first-person shooter in 4K: 4K UHD Test Video - YouTube if so, what does "Stats for nerds" look like in the right-click context menu? Youtube has nice metrics.
Thanks for the reply.
net connection is DSL 10mps tested. Wired or wireless to computer does not matter. I have done a stand alone connection also.
The computer cpu is less then 20% More then enough to do this. 8gigs of ram on mb.
Testing your 4k youtube videos play fine. No lagging. No stuttering. I played many on there.
The stats, dropped frames 30/9034. Dash yes 248/251, Res 1920x1080
Yeah, those stats look great.
I'd like to try and reproduce it on my end. It would be great if you could give me the output of the DirectX diagnostic tool (dxdiag). It includes a detailed inventory of hardware and drivers that should help me track down a comparable machine.
The output from chrome://gpu would also be really interesting.
If you haven't tried it, the 64-bit Firefox Beta for Windows is way better than the 32-bit version, at least when you're talking about Flash Player.
Mozilla Firefox Web Browser — Download Firefox Beta in your language — Mozilla
The system is Ubuntu right now. I was seeing if it did better then windows.
FireFox is 44. This is a 64 bit system.
Chrome seems to do better on this system.
Graphics Feature Status
Canvas: Software only, hardware acceleration unavailable
Flash: Hardware accelerated
Flash Stage3D: Hardware accelerated
Flash Stage3D Baseline profile: Hardware accelerated
Compositing: Hardware accelerated
Multiple Raster Threads: Enabled
Rasterization: Software only. Hardware acceleration disabled
Video Decode: Software only, hardware acceleration unavailable
Video Encode: Hardware accelerated
WebGL: Hardware accelerated
Driver Bug Workarounds
clear_uniforms_before_first_program_use
count_all_in_varyings_packing
disable_post_sub_buffers_for_onscreen_surfaces
disable_texture_storage
scalarize_vec_and_mat_constructor_args
Problems Detected
Accelerated 2d canvas is unstable in Linux at the moment
Disabled Features: accelerated_2d_canvas
Accelerated video decode is unavailable on Linux: 137247
Disabled Features: accelerated_video_decode
EXT_occlusion_query appears to be buggy with Intel GPUs on Linux
Clear uniforms before first program use on all platforms: 124764, 349137
Applied Workarounds: clear_uniforms_before_first_program_use
Mesa drivers in Linux handle varyings without static use incorrectly: 333885
Applied Workarounds: count_all_in_varyings_packing
Disable partial swaps on linux drivers: 339493
Applied Workarounds: disable_post_sub_buffers_for_onscreen_surfaces
Always rewrite vec/mat constructors to be consistent: 398694
Applied Workarounds: scalarize_vec_and_mat_constructor_args
Linux Mesa drivers crash on glTexSubImage2D() to texture storage bound to FBO: 521904
Applied Workarounds: disable_texture_storage
Accelerated rasterization has been disabled, either via about:flags or command line.
Disabled Features: rasterization
GpuMemoryBuffer Status
ATC Software only
ATCIA Software only
DXT1 Software only
DXT5 Software only
ETC1 Software only
R_8 Software only
RGBA_4444 Software only
RGBX_8888 Software only
RGBA_8888 Software only
BGRX_8888 Software only
BGRA_8888 Software only
YUV_420 Software only
YUV_420_BIPLANAR Software only
UYVY_422 Software only
Version Information
Data exported 2/14/2016, 5:01:06 PM
Chrome version Chrome/48.0.2564.103
Operating system Linux 3.19.0-49-generic
Software rendering list version 10.16
Driver bug list version 8.32
ANGLE commit id 5576734a46f8
2D graphics backend Skia
Command Line Args --flag-switches-begin --flag-switches-end
Driver Information
Initialization time 74
In-process GPU false
Sandboxed true
GPU0 VENDOR = 0x8086, DEVICE= 0x0412
Optimus false
AMD switchable false
Driver vendor Mesa
Driver version 10.5.9
Driver date
Pixel shader version 1.30
Vertex shader version 1.30
Max. MSAA samples 8
Machine model name
Machine model version
GL_VENDOR Intel Open Source Technology Center
GL_RENDERER Mesa DRI Intel(R) Haswell Desktop
GL_VERSION 3.0 Mesa 10.5.9
GL_EXTENSIONS GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_color_buffer_float GL_ARB_compressed_texture_pixel_storage GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_conservative_depth GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multisample GL_ARB_multitexture GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_packing GL_ARB_shading_language_420pack GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirrored_repeat GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rgb10_a2ui GL_ARB_texture_rg GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_view GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_texture GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_texture GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_EXT_vertex_array GL_OES_EGL_image GL_OES_read_format GL_KHR_debug GL_KHR_context_flush_control GL_3DFX_texture_compression_FXT1 GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_trinary_minmax GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ATI_blend_equation_separate GL_ATI_draw_buffers GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_MESA_pack_invert GL_MESA_texture_signed_rgba GL_MESA_window_pos GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_S3_s3tc GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
Disabled Extensions GL_ARB_occlusion_query GL_ARB_occlusion_query2
Window system binding vendor SGI
Window system binding version 1.4
Window system binding extensions GLX_ARB_create_context GLX_ARB_create_context_profile GLX_ARB_create_context_robustness GLX_ARB_fbconfig_float GLX_ARB_framebuffer_sRGB GLX_ARB_multisample GLX_EXT_create_context_es2_profile GLX_EXT_framebuffer_sRGB GLX_EXT_import_context GLX_EXT_texture_from_pixmap GLX_EXT_visual_info GLX_EXT_visual_rating GLX_MESA_copy_sub_buffer GLX_OML_swap_method GLX_SGI_swap_control GLX_SGIS_multisample GLX_SGIX_fbconfig GLX_SGIX_pbuffer GLX_SGIX_visual_select_group GLX_INTEL_swap_event
Window manager Compiz
XDG_CURRENT_DESKTOP Unity
GDMSESSION ubuntu
Compositing manager Yes
Direct rendering Yes
Reset notification strategy 0x8252
GPU process crash count 0
DirX
id:
tv
description: Desktop Computer
product: All Series (All)
vendor: ASUS
version: System Version
serial: System Serial Number
width: 64 bits
capabilities: smbios-2.8 dmi-2.7 vsyscall32
configuration:
administrator_password = disabled
boot = normal
chassis = desktop
family = ASUS MB
frontpanel_password = disabled
keyboard_password = disabled
power-on_password = disabled
sku = All
uuid = 60DA923C-DAD7-DD11-95B9-2C56DC3B244D
id:
core
description: Motherboard
product: Z97-PRO GAMER
vendor: ASUSTeK COMPUTER INC.
physical id:
0
version: Rev X.0x
serial: 151158190002313
slot: To be filled by O.E.M.
id:
firmware
description: BIOS
vendor: American Megatrends Inc.
physical id:
0
version: 2106
date: 05/21/2015
capacity: 8128KiB
capabilities: pci apm upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification uefi
id:
memory
description: System Memory
physical id:
45
slot: System board or motherboard
id:
bank:0
description: DIMM [empty]
product: [Empty]
vendor: [Empty]
physical id:
0
serial: [Empty]
slot: DIMM_A1
id:
bank:1
description: DIMM DDR3 Synchronous 1600 MHz (0.6 ns)
product: F3-12800CL9-4GBSR2
vendor: Fujitsu
physical id:
1
serial: 00000000
slot: DIMM_A2
width: 64 bits
clock: 1600MHz (0.6ns)
id:
bank:2
product: [Empty]
vendor: [Empty]
physical id:
2
serial: [Empty]
slot: DIMM_B1
id:
bank:3
vendor: Fujitsu
physical id:
3
serial: 00000000
slot: DIMM_B2
width: 64 bits
id:
cpu
description: CPU
product: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
vendor: Intel Corp.
physical id:
52
bus info:
cpu@0
version: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
slot: SOCKET 1150
capacity: 3900MHz
width: 64 bits
clock: 100MHz
capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm ida arat epb pln pts dtherm tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm xsaveopt cpufreq
configuration:
cores = 4
enabledcores = 4
threads = 4
id:
cache:0
description: L1 cache
physical id:
53
slot: CPU Internal L1
capacity: 256KiB
capabilities: synchronous internal write-back
id:
cache:1
description: L2 cache
physical id:
54
slot: CPU Internal L2
capacity: 1MiB
capabilities: synchronous internal write-back unified
id:
cache:2
description: L3 cache
physical id:
55
slot: CPU Internal L3
capacity: 6MiB
id:
pci
description: Host bridge
product: 4th Gen Core Processor DRAM Controller
vendor: Intel Corporation
physical id:
100
bus info:
pci@0000:00:00.0
version: 06
width: 32 bits
clock: 33MHz
configuration:
driver = hsw_uncore
resources:
irq : 0
id:
pci:0
description: PCI bridge
product: Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller
physical id:
1
bus info:
pci@0000:00:01.0
version: 06
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
configuration:
driver = pcieport
resources:
irq : 24
id:
display
description: VGA compatible controller
product: Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller
physical id:
2
bus info:
pci@0000:00:02.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration:
driver = i915
latency = 0
resources:
irq : 29
memory : f7800000-f7bfffff
memory : e0000000-efffffff
ioport : f000(size=64)
id:
multimedia:0
description: Audio device
product: Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller
physical id:
3
bus info:
pci@0000:00:03.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration:
driver = snd_hda_intel
latency = 0
resources:
irq : 31
memory : f7c34000-f7c37fff
id:
usb:0
description: USB controller
product: Intel Corporation
physical id:
14
bus info:
pci@0000:00:14.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
configuration:
driver = xhci_hcd
latency = 0
resources:
irq : 25
memory : f7c20000-f7c2ffff
id:
communication
description: Communication controller
physical id:
16
bus info:
pci@0000:00:16.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration:
driver = mei_me
latency = 0
resources:
irq : 28
memory : f7c3e000-f7c3e00f
id:
network
description: Ethernet interface
product: Ethernet Connection (2) I218-V
physical id:
19
bus info:
pci@0000:00:19.0
logical name:
eth0
version: 00
serial: 2c:56:dc:3b:24:4d
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration:
autonegotiation = on
broadcast = yes
driver = e1000e
driverversion = 2.3.2-k
firmware = 0.1-4
latency = 0
link = no
multicast = yes
port = twisted pair
resources:
irq : 27
memory : f7c00000-f7c1ffff
memory : f7c3c000-f7c3cfff
ioport : f080(size=32)
id:
usb:1
physical id:
1a
bus info:
pci@0000:00:1a.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm debug ehci bus_master cap_list
configuration:
driver = ehci-pci
latency = 0
resources:
irq : 16
memory : f7c3b000-f7c3b3ff
id:
multimedia:1
physical id:
1b
bus info:
pci@0000:00:1b.0
version: 00
width: 64 bits
clock: 33MHz
configuration:
latency = 0
resources:
irq : 30
memory : f7c30000-f7c33fff
id:
pci:1
physical id:
1c
bus info:
pci@0000:00:1c.0
version: d0
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
configuration:
driver = pcieport
resources:
irq : 16
id:
pci:2
product: 82801 PCI Bridge
physical id:
1c.3
bus info:
pci@0000:00:1c.3
version: d0
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm subtractive_decode bus_master cap_list
id:
pci
product: ASM1083/1085 PCIe to PCI Bridge
vendor: ASMedia Technology Inc.
physical id:
0
bus info:
pci@0000:03:00.0
version: 04
width: 32 bits
clock: 33MHz
capabilities: pci subtractive_decode bus_master cap_list
id:
usb:2
physical id:
1d
bus info:
pci@0000:00:1d.0
version: 00
width: 32 bits
clock: 33MHz
configuration:
driver = ehci-pci
latency = 0
resources:
irq : 23
memory : f7c3a000-f7c3a3ff
id:
isa
description: ISA bridge
physical id:
1f
bus info:
pci@0000:00:1f.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
configuration:
driver = lpc_ich
latency = 0
resources:
irq : 0
id:
storage
description: SATA controller
physical id:
1f.2
bus info:
pci@0000:00:1f.2
version: 00
width: 32 bits
clock: 66MHz
capabilities: storage msi pm ahci_1.0 bus_master cap_list
configuration:
driver = ahci
latency = 0
resources:
irq : 26
ioport : f0d0(size=8)
ioport : f0c0(size=4)
ioport : f0b0(size=8)
ioport : f0a0(size=4)
ioport : f060(size=32)
memory : f7c39000-f7c397ff
id:
serial
description: SMBus
physical id:
1f.3
bus info:
pci@0000:00:1f.3
version: 00
width: 64 bits
clock: 33MHz
configuration:
latency = 0
resources:
memory : f7c38000-f7c380ff
ioport : f040(size=32)
id:
scsi:0
physical id:
1
logical name:
scsi0
capabilities: emulated
id:
cdrom
description: DVD reader
product: DVD-ROM TS-H353B
vendor: TSSTcorp
physical id:
0.0.0
bus info:
scsi@0:0.0.0
logical name:
/dev/cdrom
logical name:
/dev/sr0
version: D200
capabilities: removable audio dvd
configuration:
ansiversion = 5
status = open
id:
scsi:1
physical id:
2
logical name:
scsi1
id:
disk
description: ATA Disk
product: FUJITSU MHW2080B
vendor: Fujitsu
physical id:
0.0.0
bus info:
scsi@1:0.0.0
logical name:
/dev/sda
version: 001C
serial: K10AT7627P5S
capabilities: partitioned partitioned:dos
configuration:
ansiversion = 5
sectorsize = 512
signature = 00079a2b
id:
volume:0
description: EXT4 volume
vendor: Linux
physical id:
1
bus info:
scsi@1:0.0.0,1
logical name:
/dev/sda1
logical name:
version: 1.0
serial: e7ec3067-fd2c-452b-adc1-42b2c160179f
capacity: 66GiB
capabilities: primary bootable journaled extended_attributes large_files huge_files dir_nlink extents ext4 ext2 initialized
configuration:
created = 2016-02-05 16:33:09
filesystem = ext4
lastmountpoint = /
modified = 2016-02-05 17:30:45
mount.fstype = ext4
mount.options = rw,relatime,errors=remount-ro,data=ordered
mounted = 2016-02-05 17:30:45
state = mounted
id:
volume:1
description: Extended partition
physical id:
2
bus info:
scsi@1:0.0.0,2
logical name:
/dev/sda2
capacity: 8067MiB
capabilities: primary extended partitioned partitioned:extended
id:
logicalvolume
description: Linux swap / Solaris partition
physical id:
5
logical name:
/dev/sda5
capacity: 8067MiB
capabilities: nofs
id:
power
description: To Be Filled By O.E.M.
product: To Be Filled By O.E.M.
vendor: To Be Filled By O.E.M.
physical id:
1
version: To Be Filled By O.E.M.
serial: To Be Filled By O.E.M.
capacity: 32768mWh
id:
network
description: Wireless interface
physical id:
2
bus info:
usb@1:3
logical name:
wlan0
serial: 64:66:b3:19:5e:5c
capabilities: ethernet physical wireless
configuration:
broadcast = yes
driver = ath9k_htc
driverversion = 3.19.0-49-generic
firmware = 1.3
ip = 192.168.254.33
link = yes
multicast = yes
wireless = IEEE 802.11bgn
Yeah, we don't do hardware acceleration on NPAPI Linux at this point. We do get it on PPAPI Linux, which is why Chrome performs better. We stopped working on NPAPI Linux (aside from security patches) several years ago, so you're also getting the benefit of a few years of active Flash development on Chrome. You're at Flash Player 20 on PPAPI vs. Flash Player 11.2 on NPAPI.
