I have 2 anniversaries listed for each contact record. They both have a title and they both have a date.
I've set up a customer event email campaign type and based it on the Anniversary 2 date so that the email is sent out 2 weeks before the Anniversary 2 date for each contact record in the mailing list that I specified.
I'm trying to get the Anniversary 2 date to render in the text within the email itself but I'm having problem with this.
When I was reading the documentation I read that you could reference WebApps within email campaigns and also read about creating your own module tags so I thought I'd try to use a combination of a WebApp and a custom module tag to see if I could include the anniversary date within the body of the email. The following is what I came up with:
Unfortunately, when I sent myself the test email, {module_webapps,30987,i,5829714 template="/_settings/renewal-date”} didn't translate into the anniversary date at all - it was just the code itself that rendered.
Can anyone tell me why this didn't work or point out what I may have done wrong? Or is it not possible at all to render an anniversary date within an email via a module tag? If that's the case, then if the anniversary date was in a custom crm form field, would I be able to render it that within an email?
I'd really appreciate any help or advice.
Thanks in advance.
