I am in the process of upgrading from 8 to 9. I only have the trial version, because my serial number is not working. Anyway, I have been using conditional actions in 8, but a project I converted from 8 to 9 they are not working in now. I have created a sample file of what I am doing. I think I am just missing a step, but cannot figure it out. Could it be because it is just the trial version?
Is there a way for me to share the sample file here?
You've encountered a known issue with upgrading Conditional Actions from Cp8 to Cp9 version 9.0.0. The conditional actions get converted back to standard actions and therefore don't work as expected.
Your trial version of Cp9 will be version 9.0.0, but Adobe released a patch for this issue and installing that patch would upgrade your trial version to 9.0.1.
Do a Google search for Adobe Captivate 9 hotfix and you should be able to find the blog article from which you can download the patch.
Thank you for the link, but it has not fixed my problem. I am now using the licensed version of 9 (9.0.0.230). I have created a new test file from scratch. I am also working on a Mac. I might point out that in my Help menu, the Updates option is greyed out.
I think I am leaving out a step or something, but this one has got me stumped. Is there anyway for me to share my Captivate file with you for advise?
Here is what I am trying to rebuild:
Menu page with buttons that take you to different topics. For example Red button jumps to Red Intro slide. Green button jumps to Green Intro slide. Students go through each topic and then at end of topic click on button that takes them back to Menu page. This buttons action is a conditional action. Once back on Menu page, a symbol will appear, showing that they have completed that topic. All topics must be complete before the Assessment button appears that jumps to a quiz.
Variables:
red
green
blue
Standard Actions:
red_end
Assign red with 1
Jump to slide 3 Menu
green_end
Assign green with 1
blue_end
Assign blue with 1
Conditional actions:
check_module_completion
IF
All conditions are true
Red_Complete
red is equal to 1
Show red_complete
Else
Hide red_complete
IF
Green_Complete
green is equal to 1
Show green_complete
Else
Hide green_complete
IF
Blue_Complete
blue is equal to 1
Show blue_complete
Else
Hide blue_complete
IF
Assessment_Butt_Show
red is equal to 1
green is equal to 1
blue is equal to 1
Show assessment_button
Else
Hide assessment_button
Am I missing a piece of code or something?
A hot fix is not installed using Update feature, it is mostly a manual work flow.
Your question is off topic for this thread, has nothing to do with it. Why didn't you create a new question?
This topic has appeared so many times everywhere. Here is my last blog post explaining that type of dashboard/menu
Captivate 8 - First Adventures - Captivate blog
Could you please use the Preview button in the Advanced Actions dialog box and post a screenshot of the total Conditional action? I'm totally confused by the way you are writing this down. It is not clear to me which events are triggering the actions. Easiest work flow would be:
Show Bt_assess
ELSE
Continue
Because I was trying to determine if the issue was related to the update or if I had made a mistake in the code. I thought the issues may have been related.
Sorry to have bothered you. I will find my answer elsewhere.
I wrote for you a complete solution, lot easier, and that is your 'thank you'. Great, have a good memory and will not try to help you in the future.
If you read this thread, it was about conditional actions in former versions being converted to standard shared actions before the hot fix. You have installed the hot fix, and your question was about something totally different.
Look, sorry to have offended you, and I do appreciate all the time and effort you put into volunteering on this site.
I did install the hot fix, and it did not solve my problem. Once I installed the hot fix, my version was updated from 9.0.0.223 to 9.0.0.230. My confusion was that in another post response, not yours, that the hot fix would upgrade to 9.0.1. I was not sure if I installed the hot fix incorrectly, or if the original problem was my code.
I stated in the original post that it could just be my lack of knowledge with the code.
This was why I thought the issues may be related and not a different topic. My mistake.
I will try not to make the same mistake again.
After hot fix version is 9.0.0.230. I never told differently... lot of people just don't care about being correct. Only an official patch will change to a 9.0.1 version.
Thank you
This tutorial example might also help you:
Create a Dynamic Menu Slide in Adobe Captivate | Infosemantics Pty Ltd
