My website has been designed in Muse. I'm wishing to add BC modules but it seems like 2 different systems. When I want to add pages to the menu bar then the website pages aren't there. Can I copy my Muse pages to BC so all pages are in BC and under the same menu structure? Thanks
They are two different systems. I strongly advise against modifying the files Muse generates, or otherwise going around the Muse software.
Muse sites need their pages to be added/managed from the Muse software.
This may help: Video of the Month: Adding Business Catalyst features to your Muse sites
This is not totally correct.
A while ago now there was an update to BC and Muse in terms of relationship on the files.
Under settings there is now an option to sync back and allow changes to business catalyst and Muse. You have to ensure this option is enabled in both and when you run Muse it notifies you and looks to sync back down those pages.
It is still not great process and how Muse works is really only basic compared to Bc though so keep that in mind Jo.
Thank you for your reply Liam.
I have only recently purchased BC so shouldn't I have the latest version?
Also, I don't see anything under settings to sync to Muse? Is it site settings or somewhere else?
But what plan did you purchase. Look on the business catalyst website and you can see different plans.
Thank you Robert for your reply. I am working with the video, it is very helpful.
I assume the same would apply for adding shop module?
You can add BC modules with the HTML Object box in Muse. You can add BC pages to a Muse custom menu with URLs. You can keep blogs and e-commerce in BC and attach a Muse template to them. Make a BC template in Muse using the {tag_pagecontent} Tag on the page (HTML box).
Let me map this out for you pretty plain and clear.
MUSE and BC are 2 different systems. Yes there's been some work done in MUSE so that you can use some BC features and they work on a basic level.
As liam pointed out you can do this with Eccomerce. HOWEVER have you ever seen any decent MUSE/ECOMMERCE implementations? Nope? Neither have I.
In short, Muse is a basic tool thats great for spitting out quick and easy sites that require little or no functionality. It's by no means the scalable, flexible solution that Business Catalyst is without Muse.
So how do you move forward?
Unfortunately once you use MUSE you're stuck with Muse. We prefer to design in Photoshop and to build our Html natively in Business Catalyst so we're not restricted.
BUT...... Quite often we work with MUSE users to do one of the following when they need more functionalty:
1. We convert their current MUSE site to NATIVE BC and therefore unlock the true power of Business Catalyst. From then on you use BC to make changes not MUSE
OR
2. Occasionally we'll leave whats in MUSE online. Then we create modules using BC. This requires creating a Native BC Template that wraps around the BC module. The kicker here is these templates are NEVER updated using muse. We treat them separately and they're managed in BC. You can continue to update the MUSE part of the site in MUSE no problem.
We prefer option 1 but quite often we do option 2.
If you have any questions feel free to reach out
