2 Replies Latest reply on Feb 8, 2016 12:05 PM by franziskaa2084866
    not able to erase Authorization
    franziska.asplund
      Hi
      I can not erase my Computer Authorization on Adobe Digital Edition. It tells: Unable to eraye aouthorization_please try later.
      Wat does that mean?
        • 1. Re: not able to erase Authorization
          cselhost Level 2
          Hi Franziska,
          You need to manually delete the activation file and then resign in. Please follow these steps:
          You must have administration authority.
          On Windows it can be found here:
          Open Windows Registry by using the command prompt and typing 'regedit' or by opening the start menu and searching for 'regedit'.
          Search for the following folder:
          HKEY_CURRENT_USER\Software\Adobe\Adept\Activation
          The 'Activation' folder can be entirely deleted.
          On Mac it can be found here:
          In Finder, find the 'Go' option on the menu bar and click 'Go to folder' and type the following in:
          ~/Library/Application Support/Adobe/Digital Editions/
          Delete the activation.dat file within the 'Digital Editions' folder.
          Restart ADE and it should be deactivated at this point. You should be good to sign back in.
          • 2. Re: not able to erase Authorization
            franziskaa2084866
            Thank you VERY much. After 4h spent in different Adobe support groups - you have
            solved the problem for me. You made my day!!!!!!
