3 Replies Latest reply on Feb 9, 2016 11:45 AM by Just Shoot Me
    Deleting Exported Files
    cindys70 Level 1
      if i edit a photo in lr then export to desk top , send to where i want , then delete from desk top , will i still be able to edit in lr or is it gone?
      thanks
        • 1. Re: Deleting Exported Files
          Just Shoot Me Adobe Community Professional
          An, any, exported image is a separate file. To Export means to make a copy of the original file with usually a different File Extension, JPG or TIF instead of the RAW file extension, and at the same time apply the edits you have done to that exported image. LR does not really touch the original images. The edits you do on images in LR are saved to the catalog file or to an XMP sidecar file or in the case of DNG, TIF or JPG the edits are actually stored inside the original file in a special area that does not alter the original image. The only time you can see the edits done by LR is when you are viewing the image Inside LR and or when you export an image. Then the edits get Applied to the Exported image.
          So to answer you last question.
          If you edit an image and then Export that image to the desktop and then decide to Delete the image you exported to your desktop the original images remains and yes you could/can still see it in LR and do more edits on it or remove and or change the edits you had previously done on it.
          Please review some of the very good LR tutorial available on the NET and maybe even buy a book on LR.
          • 2. Re: Deleting Exported Files
            cindys70 Level 1
            thank you very much
            • 3. Re: Deleting Exported Files
              You're Welcome.
