5 Replies Latest reply on Mar 7, 2009 5:37 AM by Newsgroup_User
    V12 DB xtra V3.4
    Level 7
      Anyone with V12 DB xtra from Integration New Media, please help...
      I was told by tech support at INM that the registration of the xtra is
      stored in the database file ONLY not in Director and not in the xtra. I
      registered the xtra ran the movie in authoring mode as INM suggested, saw
      the size the the db file increase slightly and then ran the projector. No
      splash screen as I had been seeing when the xtra wasn't registered.
      So I sent the files off for testing and the tester on a different machine
      was getting the splash screen. I checked my machine and still, no splash
      screen. So I gave the tester the reg code and he registered his db file in
      Director. When he ran the projector, voila, no splash screen. He moved the
      files to another computer and the splash screen was back. INM insists that
      the only place the registration is done is in the .db file so they have been
      of no help explaining this behavior.
      any clues? anyone run into this before?
      Craig S. Wollman
      Word of Mouth Productions
      159-00 Riverside Drive West
      New York, New York 10032
      (212) 928-9581
        • 1. Re: V12 DB xtra V3.4
          Level 7
          > any clues?
          Gremlin activity seems to have been abnormally high over your way
          recently, but that's the only unifying factor I've been able to discern.
          • 2. Re: V12 DB xtra V3.4
            Level 7
            You hit the nail on the head.
            Craig S. Wollman
            (212) 928-9581
            "Sean Wilson" <webforumsuser@macromedia.com> wrote in message
            news:got4gn$2rm$3@forums.macromedia.com...
            >> any clues?
            • 3. Re: V12 DB xtra V3.4
              Level 7
              Sean or anyone else who's interested in seeing how screwed up the software
              business is.
              I created a fresh database for my project and registered the db file. The
              V12 splash screen didn't come up...perfect.
              Just for the heck of it, I created a fresh db and DIDN'T register it. No
              splash screen!
              It APPEARS that the registration is not just stored in the db file as I've
              been told over and over but that there's some connection to having the
              authoring environment where the xtra has been registered and running the
              files from a projector on that computer, wheter D is open in authoring or
              not.
              So I sent the REGISTERED db file to my tester and it ran on both of his
              PC's, one where Director was installed and one where it wasn't installed.
              I think my contact at INM just doesn't really know how the V12 xtra really
              works.
              But we're not getting the trial version splash screen anymore so although
              I'm curious why I'm getting this strange behavior, the problem seems to be
              solved.
              Craig S. Wollman
              (212) 928-9581
              >> any clues?
              • 4. Re: V12 DB xtra V3.4
                Level 7
                I'm pretty sure that the registration status is stored on the authoring
                machine. Once any database is registered, then the xtra will continue
                to be registered, regardless of which db you are using.
                It is also possible (to explain the issue you saw) that your original db
                was made unregistered, and so unless you remove it and re-add it after
                registration, it may maintain the unregistered-ness.
                Or something like that.
                • 5. Re: V12 DB xtra V3.4
                  Chunick Level 3
                  Yeah, that's been my experience with any sort of tech support because I used to work in that industry. It doesn't matter how much knowledge they have, if they're providing any sort of customer service then they're not the programmer and that means they don't know how it works under the hood other than what they've been told which is never the full - and complicated - story.
