5 Replies Latest reply on May 16, 2006 6:42 AM by Newsgroup_User
    Can anyone spot whats wrong with my CSS here? Got a height problem
    Level 7
      http://www.fatgraphics.com/flowers/test.htm
      This is the first CSS layout site I have written from scratch, instead of
      using one of P7s pagepacks and I have come undone a bit. The main problem is
      that the container does not expand with the contents - well it does in IE
      but not in Firefox or Opera. There has to be some height setting that I have
      missed. The second problem is not crucial but I'd like to understand it: in
      order to get the contents div to tuck up snug below the navbar I have had to
      apply a negative margin to it, so again, I must have made a basic mistake.
      The CSS is inline with the file for easy troubleshooting!
      This has to be real simple but I have a hangover today and am a bear of very
      little brain.
      Thanks so much.
      James
        • 1. Re: Can anyone spot whats wrong with my CSS here? Got a height problem
          Level 7
          Why bother with this -
          <div id="footer">Ye Olde Flower Shoppe, 8 Catherine Hill, Frome, BA11 1BY.
          Tel/Fax
          01373 469 869. <a
          href="Templates/&#x6d;ai&#x6c;t&#111;&#58;i&#x6e;&#x66;&#x6f;&#64;y&#101;ol&#x64;&#x65;&# x66;&#x6c;ow&#x65;r&#115;&#x68;&#111;&#112;&#x70;&#x65;&#x2e;&#x63;&#111;&#46;&#x75;k">&#1 05;&#110;&#102;&#111;&#x40;&#121;&#x65;&#x6f;&#x6c;&#100;&#101;&#x66;&#x6c;&#111;w&#101;rs &#104;&#111;&#112;p&#x65;&#46;&#x63;&#x6f;&#x2e;&#x75;k</a>.
          </div>
          Anyhow, change this -
          </div><!-- container close -->
          to this -
          <br style="clear:both">
          and remove the height from all divs.
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "James Loudon" <ixnay@blahblahfatgraphics.com> wrote in message
          news:e4ci9q$hed$1@forums.macromedia.com...
          > is that the container does not expand with the contents - well it does in
          > IE but not in Firefox or Opera. There has to be some height setting that I
          > have missed. The second problem is not crucial but I'd like to understand
          > it: in order to get the contents div to tuck up snug below the navbar I
          > have had to apply a negative margin to it, so again, I must have made a
          > basic mistake. The CSS is inline with the file for easy troubleshooting!
          > very little brain.
          > Thanks so much.
          > James
          • 2. Re: Can anyone spot whats wrong with my CSS here? Got a height problem
            Level 7
            Yay Murray! Thanks so much - I forgot about that fix - I had to use it
            sometime in the past and forgot all about it. Sorted - the stuff in the
            footer is an email scrambling thing I found, an extension. I guess its a bit
            clunky but I think it does the trick. How do you get around the problem of
            hiding mailto: links?
            James
            "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
            news:e4cj0b$ib3$1@forums.macromedia.com...
            > Tel/Fax
            > 01373 469 869. <a
            > </div>
            > to this -
            >> I have missed. The second problem is not crucial but I'd like to
            >> understand it: in order to get the contents div to tuck up snug below the
            >> navbar I have had to apply a negative margin to it, so again, I must have
            >> made a basic mistake. The CSS is inline with the file for easy
            >> troubleshooting!
            >> very little brain.
            >> Thanks so much.
            >> James
            • 3. Re: Can anyone spot whats wrong with my CSS here? Got a height problem
              Level 7
              It's not really a fix. It's just that if you want a container to expand to
              wrap floated content, you must clear the floats before closing the
              container.
              This means that you also believe in the tooth fairy? I mean your confidence
              that spambots cannot undo simple server encoding....
              When protecting email addresses is critical, I use email forms, not mailto:
              links.
              news:e4cjob$j7c$1@forums.macromedia.com...
              > bit clunky but I think it does the trick. How do you get around the
              > problem of hiding mailto: links?
              > James
              >> 1BY. Tel/Fax
              >> 01373 469 869. <a
              >> </div>
              >> to this -
              >>> of using one of P7s pagepacks and I have come undone a bit. The main
              >>> problem is that the container does not expand with the contents - well
              >>> it does in IE but not in Firefox or Opera. There has to be some height
              >>> setting that I have missed. The second problem is not crucial but I'd
              >>> like to understand it: in order to get the contents div to tuck up snug
              >>> below the navbar I have had to apply a negative margin to it, so again,
              >>> I must have made a basic mistake. The CSS is inline with the file for
              >>> very little brain.
              >>> Thanks so much.
              >>> James
              • 4. Re: Can anyone spot whats wrong with my CSS here? Got a height problem
                Level 7
                Oh yeah, no doubt - but it probably keeps some of them at bay. The mailto:
                itself is encoded so theoretically the bots dont try to unscramble the email
                address cos they dont know its there. I believe it worked up to a point. I
                raised this whole issue here last year and got a mixed response then. Most
                people, including you said that it was largely a waste of time, but every
                little helps I guess.
                James
                news:e4ck6c$jpa$1@forums.macromedia.com...
                > to wrap floated content, you must clear the floats before closing the
                > container.
                > confidence that spambots cannot undo simple server encoding....
                > mailto: links.
                >> James
                >>> 1BY. Tel/Fax
                >>> 01373 469 869. <a
                >>> </div>
                >>> to this -
                >>>> very little brain.
                >>>> Thanks so much.
                >>>> James
                • 5. Re: Can anyone spot whats wrong with my CSS here? Got a height problem
                  Level 7
                  I'm glad that I'm so consistent (except when I'm not, of course).
                  news:e4ckj6$k7n$1@forums.macromedia.com...
                  > email address cos they dont know its there. I believe it worked up to a
                  > point. I raised this whole issue here last year and got a mixed response
                  > then. Most people, including you said that it was largely a waste of time,
                  > but every little helps I guess.
                  > James
                  >> container.
                  >> mailto: links.
                  >>> James
                  >>>> 1BY. Tel/Fax
                  >>>> 01373 469 869. <a
                  >>>> </div>
                  >>>> to this -
                  >>>>> snug below the navbar I have had to apply a negative margin to it, so
                  >>>>> again, I must have made a basic mistake. The CSS is inline with the
                  >>>>> of very little brain.
                  >>>>> Thanks so much.
                  >>>>> James
