4 Replies Latest reply on Feb 10, 2016 9:38 AM by Laubender
    Create layer if not exists
    Elmnas
      Hello people,
      How do I create a layer with name "test"
      if not exists?
      I got this code so far:
        for(myCounter = 0; myCounter <app.activeDocument.layers.length; myCounter++)
                  myLayer = app.activeDocument.layers.item(myCounter);
                  if(app.documents.item(0).layers.itemByName("TT_IDML").exists){
                      alert("asd");
      I am not sure what you use instead of .exists
      Thank you in advance
        • 1. Re: Create layer if not exists
          Elmnas Level 1
          I have also tried this code:
          but it still alerts the both messages:
          for (var i = 0; i < doc.layers.length; i++)
          //Set up Variable to access layer name
          if (doc.layers[i].name=="TT_IDML")
          alert("the layer exists")
          else
          alert("the layers does not exists");
          • 2. Re: Create layer if not exists
            TᴀW Adobe Community Professional & MVP
            Use isValid:
            app.activeDocument.layers.itemByName("Layer 14").isValid
            will return true if there is such a layer, false otherwise.
            Ariel
            • 3. Re: Create layer if not exists
              Elmnas Level 1
              I made this instead
              var layer1 = MakeLayer("TT_IDML");
              function MakeLayer(name, layerColor) {
                var layer = docSource.layers.item(name);
                if (!layer.isValid) {
                layer = docSource.layers.add({name: name});
                if (layerColor != undefined) layer.layerColor = layerColor;
                return layer;
              • 4. Re: Create layer if not exists
                Hi Elmnas,
                for questions about scripting InDesign we have a special forum here:
                InDesign Scripting
                Using the "Use advanced editor" feature of the forum and formatting your posted code for JavaScript would always be a good idea.
                Befor posting, select your code and go to:
                >> Syntax Highlighting > javascript
                Here the formatting example with your posted code:
                  return layer;
                Btw.: the Layer Object has a move() method, so you could move your new layer e.g. to the top of the stack.
                Uwe
